Flowmaster duel exhaust American Thunder kit
Discussion in 'Product Reviews' started by DirtyTacos, May 12, 2011.
  1. Oct 13, 2011 at 5:42 AM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    09 pre runner sr5
    the setup for 381 from flow master direct is not stainless. i just ordered from parts geek.
  2. Oct 13, 2011 at 5:38 PM
    DirtyTacos
    DirtyTacos [OP] Well-Known Member
    Dino
    So Cal
    2011 4x4
    You have to special order it. Mine is stainless but the muffler itself is not.
  3. Oct 17, 2011 at 9:35 AM
    hotrod45
    paul
    sarasota fl
    09 pre runner sr5
    i just installed the flow master american thunder setup. 1 1/2 hours taking my time. fit is excellent. entire instal was fairly easy for one person. it is a little louder than i anticipated. however, after a few miles it might settle down a bit. i have an ultra gauge, so i am going to see if the mileage increases at all. seems to have a bit more pep to it. $477 shipped free from patrsgeek.com.
  4. Oct 19, 2011 at 8:55 AM
    hotrod45
    paul
    sarasota fl
    09 pre runner sr5
    after driving for about 40 miles in 2 days, i discovered a problem i have contacted flow master about. will post resolve then i hear from them. my initial run after instal was 12 miles. let it cool and retighten all bolts. after this ride, i smelled rubber. what i found was the hangar welded to the exhaust pipe where it join the inlet side of the muffler, gets very hot and will melt the rubber hanger. toyota uses a hollow tube, to dissipate heat. flow master uses a solid rod, thereby conducting a lot more heat. we'll see what flow master has to say about it, hopefully before it melts through and everything ends up in the street!!!!
  5. Oct 25, 2011 at 7:54 PM
    LBCJ44
    LBCJ44 Well-Known Member
    Clay
    Greenville, SC
    2006 Toyota Tacoma SR5 4WD Double Cab
    6in. body lift, 3in. Pro Comp suspension lift 35 tires, Moto Metal Chrome Wheels, Pioneer Head Unit, Leather Seats, 10 Sub
    is the super 44 or american thunder louder?
  6. Dec 9, 2011 at 10:35 AM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    What did they have to say about this?
  7. Dec 10, 2011 at 3:35 AM
    hotrod45
    paul
    sarasota fl
    09 pre runner sr5
    they didn't respond. must be taking the 5th.
  8. Dec 11, 2011 at 7:32 AM
    Utard
    Mark
    Nyssa, Oregon
    Did it end up burning through? Now that you have had it a while how do you like it?
  9. Dec 12, 2011 at 8:18 AM
    hotrod45
    paul
    sarasota fl
    09 pre runner sr5
    it burned enough to make me concerned enough to go to toyota and buy a new rubber hanger. i really like the system. nice sound.very meooow at low speed low rpm. you get on the throttle and it gets louder, not obnoxious tho,,,, i would buy it again.
