FlowMaster...
Discussion in 'Performance and Tuning' started by CrowMagnumMan, Aug 15, 2009.
  1. Aug 15, 2009 at 6:50 PM
    CrowMagnumMan
    CrowMagnumMan [OP] Member
    I have an 09 Toyota Tacoma. Want to put a FlowMaster on. I have the hood scoop with the cold air intake. What do I have to do/order? Thanks!
  2. Aug 15, 2009 at 6:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    depending on sound...order either a 40 or 50 series/2.5inch offset in center out muffler, and either install yourself, or get a shop to cut the stock muffler out/weld in the new one.
  3. Aug 15, 2009 at 6:55 PM
    CrowMagnumMan
    Thanks! That's all? I don't have to do anything else? Sounds too easy. LOL! Thanks!
  4. Aug 15, 2009 at 6:56 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    50 series dual exhaust!;)
  5. Aug 16, 2009 at 6:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What exactly do you mean by...'Flowmaster' ??
    You can get a muffler only and put it in with your stock pipes.
    You can get a cat back muffler kit with single exit.
    You can get a cat back muffler kit with doul exit.
    You can get different types of mufflers - 40 series, 50 series....
    Do you want something that's loud?
    Do you want something that not so loud?
    What are you looking for in an exhaust?
    I have Flowmaster kit #17432 (50 series catback with dual exits)
  6. Nov 26, 2009 at 7:02 PM
    Elliebarley1978
    Elliebarley1978 Well-Known Member
    canada
    weathertech floor liners, wet okole fronts, leer 100xq cap, trd exhaust
    where do you find the single out flowmaster 50? all i c is duals.
    and is the duals easy to install?
  7. Nov 28, 2009 at 11:40 AM
    Janster
    Jandy
    Lancaster, PA
    If you go to their website.. http://www.flowmastermufflers.com/
    Click on PRODUCTS and then MUFFLERS.
    You'll see all sorts of different mufflers including 50, 70, 60, 40's, etc.
  8. Nov 28, 2009 at 11:47 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I went with the FM Super44 lol...its sounds angry as hell :)
  9. Nov 28, 2009 at 11:49 AM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    well as for choosing which series you want, it depends on your motor size, ie... if you have a 4 banger or 6. now i have the 2.7 and have the 40 series with no tail pipe and just put a down pipe on the end and have it dump before the axle. at first it sounded like a civic but now that it's broke in it doesn't sound have as bad. as for the dual you can go for it, it's a little bit more work but can be done (have to go around the spare tire and everything else) but if you are going to have a shop weld it on (i would suggest welding it) then they should be able to do, it will just more.
  10. Nov 28, 2009 at 11:52 AM
    kadukukilla671
    kadukukilla671 Well-Known Member
    Jon
    Las vegas
    08 SR5 4x4
    TRD drop in filter, flowmaster 50series muffler
    i have an 08 v6 DC i want a flowmaster but i want that deep sound ... what series should i go with with just stock pipes and weld the new muffler??
  11. Nov 28, 2009 at 11:53 AM
    ColtsTRD
    Scott
    AZ
    super 40 or super44...I went with the super44 and its gotta nice deep growl
