Fluctuating idle 2.7 manual
Discussion in '2nd Gen. Tacomas (2005-2015)' started by enjoy.every.sandwich, Jun 13, 2017.
  1. Aug 17, 2017 at 9:07 AM
    enjoy.every.sandwich [OP] Active Member
    2009 Tacoma 4WD access cab
    So, still have this fluctuating idle. About 3 weeks ago the CEL came on and the code was P0420. Replaced the O2 sensors figuring that if I was going to have to replace the cat I would replace the sensors as well. Well the sensors didn't fix the problem, so I took it to the dealer, told them about the code and the fluctuating idle, they hooked it up and monitored the sensors pre and post catalytic converter. Told me the catalytic converter is failing, so I decided to replace the catalytic converter. No codes, but still have an idle that fluctuates between 700-500rpms and the truck shakes when it reaches these low rpms.
    The truck is a manual 2.7l with 200k miles. I replaced some parts (plugs and coils) because of the mileage and not knowing when they were changed last; the old plugs were in rough shape.
    Things that I've replaced:
    Oil and oil filter
    NGK iridium spark plugs
    Denso coils
    Denso A/F sensor
    Denso O2 sensor
    All vacuum hoses
    Things I've cleaned:
    MAF sensor
    Throttle body
    Could it be that the throttle body is going bad? Is this something only the dealer can diagnose?
  2. Aug 17, 2017 at 9:09 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Modern vehicles tend to cycle the AC compressor even when the AC is not turned on. Keeps the components from seizing up from lack of use. Have you checked to see if the AC clutch is kicking in when the RPM's rise or drop?
    TireFire likes this.
  3. Aug 17, 2017 at 9:17 AM
    I've not checked that. I'm familiar with the rise and drop in rpm's from an AC compressor and the fluctuation I have would seem to occur at a greater frequency. It goes from 700 to 500 to 700 to 500 within seconds and continues this pattern. I would imagine an AC compressor kicking on would cause a momentary drop in rpms, but this would stabilize until the compressor kicks off?
  4. Aug 17, 2017 at 9:32 AM
    Noelie84
    Noel
    Wales, Maine
    Hm. Within seconds seems like it may be something else; usually the compressor will kick on for 10-30 seconds and then back off, depending on the level of freon in the system. The only time I've seen them cycle rapidly like that was when they were nearly out of freon
  5. Aug 17, 2017 at 9:37 AM
    Yeah, I'm familiar with the rapid cycle of an AC compressor when it is low on freon. This seems to me to be even quicker, I also don't hear the audible click when outside the vehicle when the compressor clutch would engage or disengage.
    My biggest fear is that this idle problem is what led to the catalytic converter going bad and that if I can't get it fixed, I will end up destroying the new converter.
  6. Aug 19, 2017 at 4:17 PM
    marazaii
    marazaii Well-Known Member
    Mario
    Helena
    '16 DCSBOR4X4
    Have you tried and explored anything out of the engine bay, fuel pump? Clogged fuel filter maybe? :notsure:
  7. Oct 23, 2017 at 7:15 PM
    Resurrecting this oldish thread because I still have a fluctuating idle. What I mean by this is that the idle fluctuates from about 700 to 500rpms cyclically when the engine is warm and when it reaches the low rpms the engine stumbles enough to shake the entire truck. It is a 2.7l manual transmission 4x4 regular cab with 207k miles.
    I recently took the truck to the dealership for them to diagnose. They told me it could be a bad TB because there was a recall, but couldn't pinpoint that as the culprit and told me to wait until whatever was causing the problem to get worse, i.e. the throttle body going out completely. They quoted me $2k to replace the throttle body (because I was outside of the allotted mileage for free replacement). Instead of waiting for the problem to get worse and paying the dealership, I bought a new TB and replaced it myself only to have the problem remain. Prior to this, the truck had a CEL for the catalytic converter and I had that and the accompanying sensors replaced.
    Things I have done to try and fix this problem:
    New throttle body
    New catalytic convertor
    New A/F and O2 sensor
    OEM spark plugs
    OEM coils
    Cleaned MAF sensor
    All new vacuum hoses
    New PCV valve
    I have decent gas mileage (~22mpg on the highway) and the truck does not have any performance problems while running, hence I don't believe it to be a problem with getting fuel to the engine (fuel pump, fuel filter, injectors).
    I'm hesitant to take it back to the dealership, but I don't want this problem to lead to me having to replace anything that isn't broken. Any ideas on what could cause this problem? Thanks.
  8. Oct 29, 2017 at 3:03 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Dis you ever find the fix to this problem? I'm having a similar issue.
    Forgot to mention mine is the same engine but an 06 with less miles.
  9. Oct 29, 2017 at 4:06 PM
    Nope. Still have the fluctuating idle. Seems to have increased in it's occurrence as well, almost every time the truck is at idle.
  10. Oct 30, 2017 at 4:45 PM
    05toytaco
    05toytaco New Member
    Roy
    05 Toyota Tacoma
    mine does it too. 05 tacoma. 122,000mi. very annoying.
  11. Oct 30, 2017 at 4:56 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Mine does it too. 65k miles 2010, also 5spd 4x4. Not enough to shake the truck and it never stalls so I'm not worried about it.
    The cat should have been replaced under recall. Mine was last year.
    Do you have any info on the throttle body recall? I haven't heard of that at all
  12. Oct 30, 2017 at 5:20 PM
    JohnWR
    JohnWR Active Member
    2006 Indigo Ink base Access Cab 2.7L 4X4
    That was only 2010-15 trucks anything older was not included. i loved that recall made a lot of money off that one.
  13. Oct 30, 2017 at 5:24 PM
    JohnWR
    It's really hard to even start to give help for this without proper data logs. i would want to see multiple logs at idle and just see what every sensor in the engine data list is doing. But i'll through one out there did you replace the PCV when you did the plugs they are plastics and tend to fail and can cause some weird shit to happen.
  14. Oct 30, 2017 at 5:31 PM
    TireFire
    Olympic Peninsula
    Which one?
  15. Oct 30, 2017 at 6:41 PM
    #35
    JohnWR
    The F0U campain 2.7 trucks.
  16. Oct 30, 2017 at 6:55 PM
    #36
    TireFire
    Olympic Peninsula
    ? I meant which recall for the 2.7
    Cat or Throttle Body? I'm looking for details on the throttle body recall that was mention and want to see if my 2010 Taco is affected
  17. Oct 30, 2017 at 7:26 PM
    #37
    Yeah, I replaced the PCV valve and was careful in doing so.
    How do you think I should go about approaching the dealer in this situation? Last time I was there, I had to ask them to run a diagnosis to check out the fluctuating idle.
    As for the Throttle Body recall, I'd not heard of it before, it just something that was mentioned to me by the representative in the shop last time I was there.
  18. Oct 31, 2017 at 6:07 PM
    #38
    JohnWR
    Honestly i work for the dealer so my advice is this. Go in and ask to test drive with the tech and duplicate your concern multiple times during the road test. If you can duplicate a concern easy and numerous times any problem can be fixed eventually. Driveabliity concerns are super hard to diag and takes time so understand it make take a few hours.
  19. Nov 1, 2017 at 11:11 AM
    #39
    I can try the test drive approach, thanks. However, last time I was there, it wasn't that the truck idle wasn't fluctuating while they were problem solving, the technician experienced the problem. They also had the truck for 8hrs or so.
    I forgot to mention that both him and I could get the fluctuating idle to alleviate slightly by just turning on the AC. What about increasing the load or RPMs would cause the fluctuations to minimize?
    When I have some free time again, I will take it back to the dealer.
  20. Nov 22, 2017 at 4:47 PM
    #40
    Update.
    Took the Tacoma to the dealer and test drove it with them. The idle would not fluctuate with them in the vehicle, of course. While driving home I noticed that they had turned off the heat, and the head lights which I usually leave on... Turned those both on and low and behold, the fluctuating idle began again. So, I thought it may be a problem with the charging system and I took the truck to the local parts store and had them check the alternator and battery, both passed their tests... Removed the grounds associated with the battery and the alternator and cleaned the contacts to ensure a good connection. After that, I confirmed that the idle fluctuations occur when the accessories are being used.
    Could it still be a problem with the charging/electrical system?
