Fluctuating idle 2.7 manual
Discussion in '2nd Gen. Tacomas (2005-2015)' started by enjoy.every.sandwich, Jun 13, 2017.
  1. Mar 19, 2019 at 5:07 PM
    #61
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes unlike the days of yore the voltage regulator is built into the alternator. Back in my younger days the voltage regulator was a separate component.
  2. Mar 19, 2019 at 5:57 PM
    #62
    Markcal
    Markcal Well-Known Member
    Thanks for updating this thread OP, I wish more TW members would do the same when making a thread. :hattip:
    I may be having the same problem, would there be any way of rebuilding the OEM alternator by buying a replacement voltage regulator? OEM alternators are so expensive that if replacing parts is possible it would save a lot of money. I say this after watching "Timmy the Toolman" replace the bushings in a failing alternator on his YouTube Channel and looked very simple.
    Blais03 likes this.
  3. Mar 19, 2019 at 6:52 PM
    #63
    Jimmyh
    SC
    2012 Prerunner SR5
    Usually unless you have a connection for the parts you will find that they are too expensive or hard to get.
  4. Mar 21, 2019 at 12:06 PM
    #64
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    noce post/thread! I am glad the overall problem was corrected and thatvyou let us all know what the fix was.
    I just hit 170k miles and will tuck this bit of info away for later.
  5. Mar 21, 2019 at 12:18 PM
    #65
    enjoy.every.sandwich [OP] Active Member
    2009 Tacoma 4WD access cab
    That was a route I wanted to take, but they aren't separate, and the parts aren't readily available to a carport mechanic like me. Just another way for us to spend more money in the name of simplicity.
    The Denso I bought is going strong still with close to 15k on it. Rockauto.com has them for ~$130 plus a $70 core charge, not too bad for a quality non-OEM replacement.
    Markcal[QUOTED] likes this.
  6. Mar 21, 2019 at 3:45 PM
    #66
    Markcal
    OK, Thanks for that information. :thumbsup:
  7. Mar 27, 2019 at 7:38 AM
    #67
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    I put a "new" (reman) alternator in the other night. No change. I think these autozone alternator's are garbage. I know this is my issues because if i unplug the alternator while the truck is running, it runs very smooth with no idle fluctuating at all.
  8. Mar 27, 2019 at 7:50 AM
    #68
    Blais03
    Nick
    Easthampton MA
    I did the prior. I took the whole thing off and cleaned it very thoroughly. I have cleaned the MAF, replaced the PCV, new (reman) alternator as mentioned, seafoam treatment, ive checked for a bad ground, ive checked for vacuum leaks. nothing. the only thing that makes a difference with the idle is unplugging the alternator. unplug it and it runs like its brand new.
  9. Mar 27, 2019 at 10:37 AM
    #69
    Jimmyh
    SC
    2012 Prerunner SR5
    Crappy remanufactured alternators really suck. Most of these places remanufactured = dusted off cleaned and placed back in a box to resell.
    Blais03 likes this.
  10. Apr 8, 2019 at 10:21 AM
    #70
    Blais03
    Nick
    Easthampton MA
    I replaced my alternator yet again with a Reman denso, (i guess they dont sell new ones???) Now my truck runs perfect. except the battery light comes on occationally!!! Im getting so sick of this BS lol time to go bitch at Autozone.
