Fluctuating idle 2rz
Discussion in 'Performance and Tuning' started by TACOrolla, Mar 11, 2010.
  1. Mar 11, 2010 at 5:26 PM
    TACOrolla
    TACOrolla [OP] New Member
    T3/T4 turbo, apexi SAFCII
    Hello,
    I have a 2rz that has a fluctuating idle when i stop at a stop light it runs fine, it seems like it can't catch its idle. when i first start it up and warm her up it idles at 1k, so its not the idle screw.. I appear to have no vacuum leaks.. I've cleaned my IAC valve. What ealse can i check? I'm really stumped on this one..
    Yes this is a 86 corolla...
  2. Mar 11, 2010 at 5:36 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I had the same problem on my old truck. It ended up being my vaccume spring if thats what its called on the side be the idle adjustment screw, there is this little pump and my boot on that was shot so when I would stop and come down to idle the boot wouldnt go down all the way to regular idle speed. Good luck I know how frustrating this can be. :frusty:
