Fluctuating idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by fish, Aug 4, 2011.
  1. Aug 4, 2011 at 7:12 AM
    fish
    fish [OP] fish
    winter garden,fl
    04 tacoma 4x4 4 door
    4'' procomp suspenchin lift 33x12.50x17 procomp x terrans and procomp wheels
    my 04 taco has a fluctuating idle problem with the a/c on while sitting at a stop light. I've tryed seafoam and it doesn't help any suggestions.
  2. Aug 4, 2011 at 7:16 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    check to see if your exhaust manifold has a crack in it.
    thats what caused it in my old truck
  3. Aug 4, 2011 at 7:16 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Sounds like the maf sensor needs cleaned.......or the iac valve on bottom on throttle body needs cleaned.
  4. Aug 4, 2011 at 8:16 AM
    fish
    fish [OP] fish
    winter garden,fl
    but if i turn the a/c off it idles fine.
  5. Aug 4, 2011 at 8:23 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    There is an idle compensator when AC is on to handle load but it should be a "normal" idle then when compressor kikks on, the idle should only slightly "rise".. but be steady. If you have an "erratic" idle, I suspect it's what Will said-the MAF sensor needs a good dose of cleaner.
  6. Aug 4, 2011 at 8:40 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    The AC normally cycles, when it does this the rpm will change during this transition, did this just start or??
    It should cycle once every 10-30 seconds on average.
    If it starts fine in the morning and doesnt have this issue with AC off, it is likely normal if it always did this.
  7. Aug 4, 2011 at 9:14 AM
    fish
    fish [OP] fish
    winter garden,fl
    It hasn't always did this but it's gotten a little worsethe past few weeks only when the ac is on it jumps from 500 to 1100 at a stop light with ac on in the process of it ldling up and down i can turn the ac off and it idles fine.
  8. Aug 4, 2011 at 9:16 AM
    97yota4wd
    Eric
    Mesa, AZ
    oh shit i know what it is! its doing it on my car i just dont want to get it fixed
    okay when you turn on your ac theres this thing thats supposed to kick up your idle. its called.... idle step up solenoid i think. so when your stopped the idle goes really low and fluctuates. i think its like a 40-50 dollar part
  9. Aug 4, 2011 at 10:06 AM
    Ridgerunner
    Frank
    San Francisco
    it is a normal function as described-BUT it is supposed to keep your idle constant as compressor kikks on not raise it higher. I think you should go get the solenoid replaced caise that's a pretty steep jump in idle.
  10. Aug 23, 2011 at 5:55 AM
    Street
    Street Well-Known Member
    jon
    Brevard
    Tacoma
    So did this help your tacoma, My 99 2.4 is doing the same thing
  11. Aug 25, 2011 at 8:50 PM
    Street
    jon
    Brevard
    Tacoma
    it diesels it can't be good sounds like it whats to die and then it sounds like it has a trans brake for a dragster
  12. Aug 25, 2011 at 8:57 PM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Mine does the same thing after it warms up. With the AC on or off at a stop while in gear it is at a low 500-550 rpms. When I first start off before it is warm it is around 700 rpms.
  13. Aug 25, 2011 at 9:06 PM
    Street
    jon
    Brevard
    Tacoma
    I'm told that its the IAC valve and it controls all aspects of the idle, if so i'll just buy one, if not I rather not spend 280 for a whim
  14. Aug 27, 2011 at 4:16 AM
    Street
    jon
    Brevard
    Tacoma
    ok the idle move high and low were not talking about a little jump up or down its a spike, i took the throttle body off and cleaned it but couldn't get the 4 screws out of the IAC valve so I couldn't clean everything, I did order the screws from the dealer. So when they show up i'll cut the damn things off and do one more cleaning.:confused:
    I just don't need to slap some kid @ Mc ie d's b/c he thinks I revving up my truck at him. :mad:
  15. Aug 28, 2011 at 10:55 AM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    When i replace my bolts i went to lowes and got some bolt heads and not phillips heads bolts( the worst design ever i have seen on a toyota)....
  16. Aug 28, 2011 at 11:15 PM
    Street
    jon
    Brevard
    Tacoma
    yeah it is I might try ACE...do you remember the bolt size
  17. Aug 29, 2011 at 8:35 AM
    hayabusa3303
    florence sc
    95.5 taco 4x4
    i dont remember off the top of my head on the bolt size. did mine about a year ago.
    You might try just getting one off and taking it to ace that way.
  18. Aug 16, 2012 at 7:08 PM
    Dman
    Dman Member
    Darin
    South Florida
    5 lug SR5
    I know this is a very old post but i'm new to the board and just picked up a '98 2.4 auto Taco. I was using the search function and this post came up. It is doing the very same thing, with the a/c off it idles nicely just under 1000rpm but with the a/c on the idles goes from 800 to 1100 every time the compressor kicks on. At a traffic light it's abrupt enough to lurch the truck forward if my foot is not firmly on the brake. I understand that it's supposed to raise rpm to compensate but it's definately exaggerated. I looked for an IAC valve but ran out of daylight. sounds like I need to replace it.
