Fluctuating vacuum - is this bad?
Discussion in '4 Cylinder' started by Matt23, Feb 24, 2023.
  1. Feb 24, 2023 at 10:43 AM
    Matt23
    Matt23 [OP] Member
  2. Feb 27, 2023 at 5:37 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    What year is the truck, and how many miles is on it? Where are you measuring the vacuum? Is this being measured with the engine warmed up or cold? ...
  3. Feb 27, 2023 at 5:48 AM
    Matt23
    Matt23 [OP] Member
    Thanks for the reply! 2016 tacoma access cab 2.7L 4wd
    73,000 miles
    Measuring when cold or warm (not much change) with a mighty-vac hooked into the line that connects the intake manifold to the brake booster (I unplugged the booster side and plugged the hose into the vacuum gauge).
    Vibrates at idle, worse in gear. Better after driving on the highway for 10 min, worse in stop and go driving. I feel it in the back and head of the seats. No codes, zero misfires in OBD2, but it feels like it’s imbalanced or missing slightly even in park. I have replaced spark plugs, cleaned throttle body and MAF and idle long term fuel trim is -3.
    just wondering if I need to pursue this fluctuating needle more or if it’s not related to my vibration problem. Thank you!!
  4. Feb 27, 2023 at 6:05 AM
    Tacorific
    NE Iowa
    Any valve tick? A sticky lifter can cause this.
  5. Feb 27, 2023 at 6:18 AM
    Matt23
    Matt23 [OP] Member
    Yes, a little bit especially when cold. I put marvel mystery oil in the fuel yesterday. The oil was supposedly changed by the Subaru dealer I bought it from last month and it looks fresh on the dipstick.
    If it’s a sticky valve, what else can I do to diagnose it or fix it? Thank you again !!
  6. Feb 27, 2023 at 7:40 AM
    Tacorific
    NE Iowa
    There aren't too many options (for the shade tree mechanic) besides tearing into the engine, or trying to clean the possible varnish causing the sticking. You could try using some Toyota brand "Engine Oil System Cleaner". Or you could try something like MMO or another aftermarket oil additive specifically for quieting sticking valves. If that doesn't work an engine flush may help. Now, this may help your fluctuating vacuum issue "if" the problem is a sticking valve.
  7. Feb 28, 2023 at 5:26 AM
    Matt23
    Matt23 [OP] Member
    Thank you very much! I will try that engine cleaner from Toyota.
  8. Feb 28, 2023 at 6:14 PM
    Tacorific
    NE Iowa
    I hope this solves your issue. Let us know either way.
