fluid change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brecking, Jan 14, 2018.
  1. Jan 14, 2018 at 10:16 AM
    brecking
    brecking [OP] Member
    TRD Sport LB
    i have a 12 sport with 95,000 miles. had oil changed this week. service center tells me time to change fluids asked them to note it on receipt course they didn't. sounded like four fluid changes costing 200 a piece. 800-1000 for fluid. i did my plugs after they wanted 180 for around 50. any suggestion will be appreciated.
    Rambo54 likes this.
  2. Jan 14, 2018 at 10:32 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Rear diff, front diff, and transfer case are easy to change yourself. Just a matter of unscrewing the drain bolt and then refilling. Use a little hand pump with a hose that screws onto the quart bottles to get the gear oil back in. If it’s a manual transmission, then it’s not much different tthan the others. If it’s auto, it’s bit more involved but can still be done. There is a write up on this site on how to do it, or you could do the other 3 yourself and have Toyota change the auto transmission.
    Rambo54 likes this.
  3. Jan 14, 2018 at 11:33 AM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    Go to AMMCO for Tranny Flush, Dealers fuck it up twice on me !Do all others yourself. Easy to do, Youtube if any questions or by a Hayes or Chiltons Manual to read on how to do !
  4. Jan 14, 2018 at 11:53 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Just do a search on here for each one, there’s good info and I’m sure after you read through everything you see that’s its something you can do.
  5. Jan 14, 2018 at 5:46 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I hope they didn't charge you $200 for an oil change.
  6. Jan 14, 2018 at 5:52 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
  7. Jan 14, 2018 at 6:45 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    At that mileage I would recommend the coolant as well....there is a drain port on the bottom of the radiator and likely another on the block somewhere (Not sure about the v6) let all the stuff drain out into pans. Close drain plugs and refill with 50/50.
  8. Jan 14, 2018 at 6:46 PM
    kidthatsirish
    Oh and the pcv valve and fuel filter (If it has one...like I said, not sure about the 6cyl
