Fluid changes before storage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SaltyTaco74, Sep 17, 2022.
  1. Sep 17, 2022 at 12:06 PM
    SaltyTaco74
    SaltyTaco74 [OP] Member
    2019 Super White Tacoma TRD Sport, MT
    So I am about due to start swapping out all my drivetrain fluids. Currently at 55k miles on a 2019 Sport, MT. In 5 months I'm getting sent overseas for 2 years and have to put my truck in storage.
    Questions is, do you think it'd be better to swap the fluids before storage for 2 years, after or doesn't matter?
    I read oil is recommended before storage but haven't considered the longer lifespan fluids. My initial gut leans towards before so that everything is sitting still in clean fluid
  2. Sep 17, 2022 at 12:10 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here are some thoughts on storage.
    https://www.edmunds.com/car-maintenance/how-to-prep-your-car-for-long-term-storage.html
  3. Sep 17, 2022 at 12:12 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I am no expert I would like change the fluids a few weeks before you leave then change them when you get back.
  4. Sep 17, 2022 at 12:14 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    2 years? It’s the gasoline I would worry about, not sure how to drain the system. Maybe a gas extender can last/work for 2 years.
    Big tall dave likes this.
  5. Sep 17, 2022 at 12:15 PM
    Bishop84
    Bishop84 Well-Known Member
    Engine oil is the only one I would change, leave the other fluids, change them when you come back. Even then, it will likely be fine.
    Some people say leave the tank empty so you can put new fresh fuel in when you return. I agree with them. Get it as low as you can before storage.
    One thing that I would do, https://tiremeetsroad.com/2020/01/07/does-irish-spring-soap-keep-away-rodents-for-car-storage/ it's a "myth" by definition, but I haven't personally heard of it NOT working. Just had a co-worker come back after 3 years, no mice.
    I would charge the battery, and disconnect it. No trickle charges. I'd rather have a dead battery than a charger hooked up for 2 years.
    All opinion of course.
  6. Sep 17, 2022 at 12:16 PM
    SaltyTaco74
    I am worried about that too. Trying to figure that piece out. Hoping they send me home before 2 years lol.
  7. Sep 17, 2022 at 12:20 PM
    TA2016
    Oregon
  8. Sep 17, 2022 at 12:21 PM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    Exactly. Much better to find someone who you could trust to drive the truck every few weeks to keep it maintained. I don't allow any of my vehicles to sit any longer than two weeks...and that includes my two motorcycles.
    Storage is a recipe for disaster, including rodent damage, tire rot, moisture issues, etc. The idea of also having minimal gas in the tank might also be a bad idea. The fuel could evaporate and allow the fuel pump to go bad. I sometimes go for more than two years not using my generator, but it doesn't have a battery, doesn't have a fuel pump, doesn't have a wire harness, etc...and I can run the engine till all the fuel is gone.
    If I had to put a vehicle in storage, I would at least fill the tank with non-ethanol fuel, make sure to run the vehicle to purge out any of the ethanol, and disconnect the battery.
    SaltyTaco74[OP] likes this.
  9. Sep 17, 2022 at 12:21 PM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    If you have someone who periodically check on your vehicle then it's all fine but if left alone in storage too long without checking on it, then fluid will be not good that time frame.. you will need to flush them as soon as you get back to your vehicle. It would be better if leave it at your parents, siblings, etc instead of leaving it at rental storage facility.
  10. Sep 17, 2022 at 12:23 PM
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    Man I'd recommend having someone you trust drive it once a month rather than shelf it for 2 years. That can't be good for any part of your truck
  11. Sep 17, 2022 at 12:25 PM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    Take advantage of the market. Sale it, then buy a new one when you get back when cars are back to normal prices. That’s what I did before my last deployment. Just my two cents.
  12. Sep 17, 2022 at 12:25 PM
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    What about flat spots on tires.
    also (if i recall correctly) for aircraft reciprocating engines they open up the spark plugs and spray a preservative for the cylinder bores that helps prevent corrosive action on the steel cylinder bores.
    sorry my comment has nothing to do with fluids i had also considered long term storage in the past but for a different vheicle.
  13. Sep 17, 2022 at 12:25 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Engine oil for sure, it's designed to keep particulates in suspension but in storage they still settle to the pan. Oddly it's difficult for the oil to pick them off the oil pan again.
    I've had good really good results with Chevron marine fuel stabilizer. It has corrosion inhibitors as well. Need to sell them, have a motorcycle with nearly 3 year old fuel in it.
    The other option, I have left vehicles with friends. Just ask them to drive it once in awhile. Burn off the fuel and refill with a few gallons of ethanol free and fuel stabilizer.
  14. Sep 17, 2022 at 12:27 PM
    TAZMINATOR
    2017 Tacoma
    You can put your vehicle on 4 jacks in corners and take those tires off and place them aside or on floor.. so you wouldn't worry about vehicle weighting the tires down over time.
  15. Sep 17, 2022 at 12:28 PM
    RustySocket
    RustySocket Professional Cat Herder
    SW Washington
    2022 Celestial Silver SR5 DCSB
    I'd sell it and take advantage of the market. I left a vehicle in storage on the mainland for a few years in the early 90s. It was climate controlled... which meant the mice were warm when they chewed my wiring harness and built nests inside my new truck.
    AZ Pete and SaltyTaco74[OP] like this.
  16. Sep 17, 2022 at 12:29 PM
    myn75
    Nor Cal
    He said his was a manual. Manual may not be available in the future and i dont know how he feels picking up a used one.
  17. Sep 17, 2022 at 12:30 PM
    Sonofliberty92
    Mark
    Maryland 4 South
    Yea, personally, I'd sell it then store the money instead. Buy another when you're ready
    Gatafly likes this.
  18. Sep 17, 2022 at 12:30 PM
    eurowner
    eurowner Duke Sky
    Scoty
    First run a tank full of non-ethanol gasoline through the truck and then get 5+ gallons of aviation gas in it! Enough that when you are running it you can smell the change in the exhaust.
    Update!
    Do Not use Aviation gas in this trucks!
  19. Sep 17, 2022 at 12:30 PM
    myn75
    Nor Cal
    100LL? I thought you’re not supposed to have lead in modern gas cars.
    what about boat gas (not sure what its called) thats ethanol free
  20. Sep 17, 2022 at 12:31 PM
    TAZMINATOR
    2017 Tacoma
    That is fine but after COVID pandemic, all markets are crazy with prices which gone up. OP may have hard time finding a truck when he gets back.. It would be better if he keeps it as long as he finds someone who he trust to maintain it for him.
