Fluid changes necessary?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jauntee, May 31, 2011.
  1. May 31, 2011 at 8:26 AM
    jauntee
    jauntee [OP] Member
    Uxbridge, Ontario
    07 Tacoma, 2WD
    2007 Red Tacoma Access Cab, 2WD, manual transmission
    I have 44,000 kms on my 2007 Tacoma 4cyl, manual, access cab. I have owned it since new. The Toyota dealer wants to change the fluids in the transmission and the differential. Can anyone advise me about whether or not this is necessary?
  2. May 31, 2011 at 8:40 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Literally JUST did this last week, I will tell you what I've learned:
    The American Petroleum Institute (API) creates lubrication standards. Our Manual Trannys are rated to take API GL-4 or GL-5 Lubricants. I used A Synthetic GL-5. It works well but because of the higher additives in the API GL-5 Lubricant. Shifting can become slightly stiffer but the gears feel like they are running smoother. I would suggest just a Synthetic API GL-4 for your manual tranny.
    For the rear diff, It requires no less then an API GL-5 oil. I used a Synthetic gear oil 75W-90 with a GL-5 rating and added in the LSD (Limited Slip Differential) Additive. IT RAN LIKE SHIT, the clutches weren't engaging and it was grinding to hell. I had to go to the dealership and get the proper LSD Premixed Toyota certified stuff. Afterwards, it ran perfect.
    Any other questions just asked. So glad I did the switch overs to synthetic.
  3. May 31, 2011 at 9:10 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    amsoil severe gear gl5 in my MT. Shifts more smooth.
