Fluid Checks Done On An '18
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brohloff, May 23, 2018.
  1. May 23, 2018 at 9:33 PM
    brohloff
    brohloff [OP] '18 DCSB 4x4 Sport Cement
    MN
    '18 DCSB 4x4 AT Cement
    Been quite a few asking if the '18s still having various low fluids as seen on some of the '16s and '17s. Just finished today checking mine.......
    '18 Sport AT, made in Mexico 01/18.... now reading 1463 miles
    1. Rear diff was 1/4" low. Ok w me as going to be changing the fluid at 4-5k anyway.
    2. Transfer case. Remove plug, fluid flows out fast. OK.
    3. Front Diff was 1/4 low. OK.
    4. AT trans fluid. About 100 ml low. Basically OK/full. Used the paper clip in the OBD port
    method outlined in rowsdower's post. Transmission has been shifting great.
    5. Re-torque prop shaft bolts. Should be 65#. Both front and back were 60-70#'s. OK.
    6. Lube prop shaft. Both zerks on the front shaft were LOW. Ea took 10-14 full pumps from a
    15" gun (thats a lot of grease) to show old grease purge.
    7. Hood bracing adhesive check. It's a Sport so seems not as critical as the OR's but all
    seemed bonded well as could see.
    8. Re-torque leaf spring U-bolts. Spec is 52#. Found to be a little lower. Took'm to 60-65#.
    All in all looks like, with the exception of the driveshaft zerks, this '18 was in pretty good fluid shape.....So far pretty happy w the truck. My third Taco ('99, '07, '18) first AT. Happy w the AT so far. Very smooth shifting up and down. Better mpg than expected. Only 1500 miles on the truck so far. First 4 tanks were 22.9(22.4), 20.5(21.8), 22.7(21.7) and 22.5(21.3)....first # is hand calc # and the (...) # is the comparable dash reading...... 50/50 city/hwy light foot driving ....
  2. May 24, 2018 at 2:11 PM
    GimmeATaco
    GimmeATaco Active Member
    Do you have the tow package?
  3. May 24, 2018 at 7:54 PM
    brohloff
    MN
    Yup...Got the V6/AT....All '18 V6's automatically have the tow pkg unlike earlier models where it was a 600$ option.....
    GimmeATaco likes this.
  4. Jul 7, 2018 at 11:50 AM
    jekerskel
    jekerskel Well-Known Member
    Zach
    Bellingham WA
    2004 SR5 Extended cab 2wd 5 speed
    V-LED low and high beam headlights.
    Just checked the transmission level on my 17 built in August. At 98 degrees I put maybe a half a cup in it. I figured at 113 degrees it would drip out so in my opinion it was full. Fluid was very red and clean. Used carista with fusion on my iPhone to check temp.
    Where are the zerks for this propeller??
  5. Jul 7, 2018 at 11:53 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    On your truck, front driveshaft only.
  6. Jul 7, 2018 at 12:00 PM
    jekerskel
    Zach
    Bellingham WA
    Ok I see one of the front drive shaft, front u joint in the center of the joint. Is there one in the rear as well?
  7. Jul 7, 2018 at 12:34 PM
    badhabit2break
    badhabit2break Well-Known Member
    Stephen
    Houston, TX
    2018 Red Tacoma TRD Off-Road
    Stock
    Thanks OP.
    I will need to check mine over, I have 2200 miles.
  8. Jul 7, 2018 at 12:46 PM
    brohloff
    MN
    4x4's have a front and rear driveshaft. Front driveshaft has a zerk on each end.
    If can't find use a flashlight and it'll show but it's in there. Tough to get a gun fitting
    on them but it will go on......
    Rear driveshaft no longer had greasable fittings... sealed.
  9. Jul 8, 2018 at 4:37 AM
    raadkins16
    raadkins16 Member
    2018 Cement TRD Sport
    I found one of them rather easily, but is the other zerk under a cover that needs to be removed by chance toward the back portion of the front driveshaft ?
  10. Jul 8, 2018 at 10:38 AM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Yes.
    raadkins16[QUOTED] likes this.
