Fluid coming from high side ac / radiator
Discussion in 'Technical Chat' started by Yoshio, Feb 23, 2013.
  1. Feb 23, 2013 at 9:15 PM
    Yoshio
    Yoshio [OP] Well-Known Member
    Scott
    Central Coast, CA
    2007 SW 2.7L 4x4 SR5
    Double Cab Step Tubes, 35% Tint Front Windows, Husky Mud Flaps, Illuminated 4x4 Switch, Debadged, DEPO LED tailights, Undercover SE Tonneau Cover, Panavise In-Dash Mount, Plasti-Dipped Front Bumper Lip, OEM Front Fogs, Rear Fog Lamp, LEDs throughout, Door Sill Protectors, Color Matched Satoshi, Rear Window Security Bar, ImMrYo Rear Mirror Bracket, Added factory DTRLs & DTRL kill switch, Rear Diff Breather Mod, 17" FJ Alloy Rims, Sport shocks coils leafs, DEPO black headlights, off-road recovery hook, skid plate, BT-35 TOY Bluetooth kit
    I have fluorescent yellow/green liquid dripping from the point where the high side ac line goes into the radiator, which is odd as the radiator should have red fluid in it (read: the reservoir definitely has red fluid, pretty sure I flushed the system with red @ 60,000 miles), thoughts? Should I take her in? 2007 4 cylinder 4x4 with 72,000 miles.
  2. Feb 23, 2013 at 9:17 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Looks like your a/c system is leaking. The fluorescent yellow you see is the dye to help find leaks in the a/c system. So either the o-ring/gasket failed or the condenser is leaking. Time to take it in. What's sad is it's probably the o-ring which is easy to replace, but you need the fancy a/c machines to empty and refill the system......
    akaboras likes this.
  3. Feb 23, 2013 at 9:20 PM
    Yoshio
    Scott
    Central Coast, CA
    Crap... Thanks for the quick response :D
  4. Feb 23, 2013 at 9:23 PM
    NelsonTacoma
    Tucson, AZ
    No problem, I work on cars/trucks for a living, 2nd nature. When I read your description I was pretty sure I knew what it was.
  5. Feb 23, 2013 at 9:24 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Exactly what I was thinking off top of my head.....
    Agreed, good job on the quick reply!
  6. Feb 24, 2013 at 5:15 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Most likely Oring is bad. Fill system with new ac gas and pressure wash area. Then go to stealers hip to get replaced.
  7. Feb 24, 2013 at 10:02 AM
    Failure2Comply
    Failure2Comply Well-Known Member
    Virginia, USA
    05 Access TRD/SR5 4x4
    NFab bars, bed mat, Weathertech mats.
    Either the connection is loose or you have a bad o-ring. Put some Dawn dish soap (or any brand) around it full strength (DO NOT MIX WITH WATER). Dish soap and water make bubbles so it makes it tough to see the micro bubbles if the leak is very small. The concentrated dish soap will cling better and any bubbles means a leak is present, unless you have lost the total refrigerant charge already.
  8. Feb 24, 2013 at 10:47 AM
    Yoshio
    Scott
    Central Coast, CA
    Quick update ; can't see any bubbles, but can't see the top of the fitting (the part in the radiator), dealer told me to expect $250-300 for just an o ring replacement... Going to call around, is that a good price?
  9. Feb 24, 2013 at 10:56 AM
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    How many miles are on your truck? Mine was leaking just like this after I took delivery from the dealership. I put a quarter turn on the connecting bolt and the leak went away. Then I had the dealership check the system pressure to be on the safe side.
    RJM
  10. Feb 24, 2013 at 11:08 AM
    Yoshio
    Scott
    Central Coast, CA
    Almost 73,000 miles... I will have to try tightening the fitting then
  11. Feb 24, 2013 at 5:45 PM
    Yoshio
    Scott
    Central Coast, CA
    No go, nut is tight enough I am uncomfortable putting too much force on that pipe it's on...
    ...All the shops I found around here were closed, anyone know if $250-300 is a good price? Break down: $150 for vacuum & recharge system, $100-150 for labor & parts.
  12. Feb 24, 2013 at 5:52 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Filling the system with a DIY kit is going to introduce stop-leak, which will harden in the compressor when the stealership evacuates the system, and it's going to be impossible to get the proper refrigerant levels anyways.
    Save the $40 and just let the dealer handle the whole thing as it is. There's no question of what or where the problem is, and nobody is going to call the enviro-cops on the OP for taking it to the dealer like that.
  13. Feb 24, 2013 at 5:56 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Seems a little high for parts & labor, but that is exactly what needs to be done.
    The $150 for the system evacuation and recharge is not too out of line, R134a is not cheap now that they've decided it's a greenhouse gas.
    Get a few more quotes, but I'd seriously stick with a Toyota dealership for this one. I got fucked to the tune of $1000 on my Suburban by a "local shop"
  14. Feb 24, 2013 at 6:17 PM
    Yoshio
    Scott
    Central Coast, CA
    $1000? :eek: The service coordinator was sketchy on the parts & labor, and as his tech was out for the day, couldn't give me a solid quote, just that a typical problem like this ran in that neighborhood.
  15. Feb 24, 2013 at 6:31 PM
    chriss
    chriss Well-Known Member
    chris
    Is the system still working properly?
    Looks like a minor leak.
  16. Feb 24, 2013 at 7:22 PM
    Yoshio
    Scott
    Central Coast, CA
    Still blowing nice and cold, what's most concerning is I wiped the area clean and the colorant was back the next day....
  17. Feb 24, 2013 at 8:22 PM
    NelsonTacoma
    Tucson, AZ
    That means it will be empty in no time. You could nurse it along for a little while, but why wait when you already know what's wrong?
  18. Feb 24, 2013 at 8:38 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Mine was a complete system rebuild due to a failed compressor and holed condensor.
    The replacement compressor shit the bed within 2 weeks.
    The custom lines that I paid extra for (after telling him that I wanted the regular pickup hoses because I never put humans in the back) to make the rear AC work, never did... complete waste of money.
    Got it back from the 2nd compressor and the engine started running like shit, lost 4mpg and it continued to get worse.
    I managed to dump the thing about 5 months later and bought the Taco.
  19. Feb 25, 2013 at 3:46 AM
    Yoshio
    Scott
    Central Coast, CA
    Only waiting because everyone I called was closed yesterday, (I only discovered the leak on Friday) shooting to get it fixed today
  20. Feb 25, 2013 at 9:37 AM
    Yoshio
    Scott
    Central Coast, CA
    Update: on-base auto hobby shop will vac/refill for $80, leak test $20, and let me do my own work; i.e. Base shop vacuums the system, I fix whatever's wrong, they fill at a later date, same price!
