Fluid extractor to change oil ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JONNY TACO, Apr 16, 2009.
  1. Apr 16, 2009 at 3:44 AM
    JONNY TACO
    JONNY TACO [OP] Well-Known Member
    PA.
    DARK METALLIC GRAY -DOUBLE CAB SHORT BED
    ADVANTAGE TONNEAU COVER,TOYOTA BED LINER, POP&LOCK TAILGATE LOCK, SIDE TUBES, WIFE IN PASSENGER SEAT
    Anyone use fluid extractors to change their oil ? Seems with the oil filter on top- changing oil and filter could be done in a Tuxedo if an extractor worked.
  2. Apr 16, 2009 at 3:55 AM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    are you planning to change your oil in your Tuxedo?
    I guess my question is; are we all really that fucking lazy we'd need to use a fluid extractor and work against gravity? Why not just keep changing your oil the old fashioned way?
    I could see using one if you were a crotchedy old man with back problems no one liked, and everyone refused to lay underneath and drain it for you...
  3. Apr 16, 2009 at 4:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's called 'Gravity'
    How fast do you want it to come out? The oil gushes outta there like niagara falls.....I can't imagine you'd make the process any faster using an extractor. In fact, you'd probably slow the process down. Power assisted with suction? That'd be interesting..... but too much extra crap to clean up afterwards.
    I'll stay in the stone ages and use my drain valve, my bucket, and my dirty old jeans. :thumbsup:
  4. Apr 16, 2009 at 4:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Plus climbing under the truck gives you a reason to look at everything else under there. I got the "included" service form my truck...so I have to remember to take a look under the body every once in a while (lucking I did-Noticed a crankshaft oil leak...)
    And Jan is right...HOORAY for dirty old jeans!!
  5. Apr 16, 2009 at 4:24 AM
    Rickochet
    Rickochet Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    I have used these before and they work fine. I did not have an easy way to get under my vehicle so this was better than nothing. It takes a bit longer than gravity draining them but not a big deal. There are several different types using an electric drill, hand pump and vacuum pump. My houseboat also has twin V-8s and the drain plugs are not accessable so the dip stick tube has a built in threaded hose fitting at the top. Run the engine to warm the oil and pump away.
  6. Apr 16, 2009 at 6:08 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I wouldn't use a fluid extractor but I did buy a Fumoto Drain Valve. Attach a tube to it and drop the other end in an empty container. Open the valve (using your hand) and you never contact the oil.
    Also, attach a tube to the filter catch pan drain and run into the same bottle.
    The messiest part will be refilling. Use disposable funnels and you have a very clean process. Not a single drip and you don't even need a towel around (except to check the stick when finished).
  7. Apr 16, 2009 at 6:14 AM
    JimKellyfan
    JimKellyfan Active Member
    da South
    09 Access Cab SR5 2.something
    ARE LSII Tonneau cover
    I would only use the extractor set up say in transmission fluid type exchanges ( or similar events or concerns ), and only if you did it for a living....You know, some of those old tranny pans with no drain plugs and you always take a bath at some point...To avoid that..
  8. Apr 16, 2009 at 12:34 PM
    JONNY TACO
    PA.
    bUT EVERY TIME i GET ON MY BACK- MY WIFE GETS IDEAS AND WON'T LEAVE ME ALONE.
  9. Apr 16, 2009 at 2:23 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Your wife isn't a man is (s)he? LOL! sorry sorry, just kidding, all jokes aside, I wish my wife was still that 'active'.
  10. Apr 16, 2009 at 5:10 PM
    JONNY TACO
    PA.
    I did alot better the second time around.:D
  11. Apr 16, 2009 at 5:15 PM
    Janster
    Jandy
    Lancaster, PA
    And you consider that a problem? :eek:
    Damn, most men would get out in the garage and pretend like they need to change their oil every 1000 miles. ;)
  12. Apr 17, 2009 at 3:31 AM
    JONNY TACO
    PA.
    Gives a whole new meaning to LUBE JOB.
  13. Apr 17, 2009 at 6:58 AM
    Rickochet
    Rick
    Kentucky
    Years ago my mothers boss was under his truck working on it with his legs sticking out. His wife yells to him that she is going to the store. When she returns his legs are still sticking out and in a frisky jesture reaches up his shorts and give his tool a good shake. She then goes inside and finds her husband standing there with two beers in his hand. He couldn't get the part loose and his neighbor was under the truck trying to get it loose.
  14. Apr 17, 2009 at 7:01 AM
    brianr
    2010 4x4
    then I'd say go hit that shit.
    yeah, if everytime I layed under ym truck, I was gonna get ridden...I'd be out there everyday.
    thats some funny shit right there.
  15. Apr 17, 2009 at 7:02 AM
    JimKellyfan
    da South
    She obviously knew who he was as we all are not identical...
    I keep taking my wife out, but she keeps finding her way back home...:eek:
  16. Apr 17, 2009 at 7:05 AM
    tacogator
    tacogator Active Member
    Florida
    12 TRD Sport 4x4 Mag Gray
    lmao
