fluid extractors: griot's or mityvac or other
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chrisg, Oct 11, 2014.
  1. Oct 11, 2014 at 7:25 PM
    Chrisg
    Chrisg [OP] Well-Known Member
    Bay area, ca
    2012 Off road sport
    Stock
    Hey guys, I'm thinking about getting one of these if they work. Maybe use for axle and transmission, and p/s fluid. I have a boat also, so if that works for the oil, that would save money from the boat mechanic.
    Thoughts?
  2. Oct 11, 2014 at 7:38 PM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    I bought the Griot's version for changing the transmission fluid on my BMW. Worked great. I've used a lot of their products and have never been disappointed.
  3. Oct 11, 2014 at 7:48 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    The exchanger/extractor from mighty vac will not push heavy fluids; gear oil and such. Works great for lower viscosity oils.
  4. Oct 11, 2014 at 8:24 PM
    Chrisg
    Bay area, ca
    2012 Off road sport
    Stock
    Thanks for the replies. I was hoping to get one that does everything. Next year plan on doing axle fluid, and was hoping one of these worksites
  5. Oct 11, 2014 at 8:34 PM
    ntilehman
    Seth
    Charlotte, NC
    I haven't found a pump like that to push heavy fluids. There is an inline air ratchet operated pump with a tube coming out of either end to pump the heavier stuff.
  6. Oct 12, 2014 at 11:59 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I've used the Griots extractor for quite some time. It works great for oil, auto transmission, brake; power steering fluid.
    If you are trying to remove gear oil from a differential that has no drain/refill plug, use a hand pump and be sure to first warm up the vehicle so the gear oil has thinned out some.
    I know a lot of people like to fill differentials from underneath the vehicle with a preloaded pump. I prefer to do it topside. Buy some large heater hose - maybe 6' to 8' in length - depends on your situation. Install a plastic tube in one end and lock down with hose clamp. Plastic tube is inserted into diff. refill hole. Snake hose up and over top of tire. Put a funnel in the other end of hose and slowly pour in your gear oil. Have a clean pan under diff. just in case. Been doing it this way for years. Works great. Gravity does the work.
  7. Oct 12, 2014 at 7:48 PM
    Chrisg
    Bay area, ca
    2012 Off road sport
    Stock
    Thanks lugnut, so, your saying use a hose on top to the drain plug? I've used one of those pumps on a quart of gear oil on my old suburban, and got that crap all over.. mess.. thanks for the tip.
  8. Oct 13, 2014 at 8:26 AM
    Lester Lugnut
    Again - a long stretch of heater hose with a plastic tube in one end fastened down with a hose clamp. That is placed into the refill port on the diff. Snake the hose up over one of the tires. Connect a funnel to the other end and slowly pour in gear oil. The oil will move slowly - but it will move. You can take whatever measures to like to ensure the hose end connected to the diff. does not slip out. A catch pan underneath the diff. would not be a bad idea in case it does.
  9. Oct 13, 2014 at 12:50 PM
    Chrisg
    Bay area, ca
    2012 Off road sport
    Stock
    Lugnut, that's a good idea. Gonna take your advice
    . Thanks again, Chris
