Fluid Film limitation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Actionjackson, Mar 3, 2021.
  1. Mar 3, 2021 at 8:54 AM
    Actionjackson
    Actionjackson [OP] Well-Known Member
    Jack
    MA
    2004 Tacoma
    Been using FF for about 4-5 years now each fall. I have been a walking commercial for this product as I believe it works. But after so many years and build up it is flaking off on some surfaces and collecting crap at the cracks - like poor quality undercoating. This has occurred only on surfaces that get warm:
    The rear differential / axle housing and some of the brake backing plates. In my case these surfaces need to have the loose fluid film removed and replaced. Hoping most will come off with the pressure wash in the spring or I'll have to wire brush/scrape.
    But on the frame and underbody sheet metal - still a mushy , sticky mess - just the way I want it.
  2. Mar 3, 2021 at 9:02 AM
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    I'm not sold on Fluid Film.
    Now days, seems like it's the only commercially applied substance.
  3. Mar 3, 2021 at 11:28 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    GT35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 255/55r18 street, 255/60r16 M&H Racemasters, 7.8 at 93
  4. Mar 3, 2021 at 1:06 PM
    alarka
    alarka Well-Known Member
    WNC/SE GA
    2k X cab 3.4 5spd
    King ex travel, JBA UCA’s, All Pro Springs/shackles, Locked, all new poly bushings & rack, SS brake & clutch lines, ext bumps for starters.
    Black DOG Lila likes this.
  5. Mar 3, 2021 at 1:11 PM
    tirediron
    tirediron Well-Known Member
    2018 4x4 Sport, Auto, BBP
    This is a totally different type of product; Fluid Film, Wool Wax, et al, are meant to prevent rust by providing a barrier between metal and the environment; this, on the other hand is meant to treat metal that has already corroded.
  6. Mar 3, 2021 at 2:10 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    You are 50% correct in that fluid film does protect and Coroseal is for metals that are already rusted.
    Coroseal converts iron oxide into it's inert form, Magnetite, which protects the steel beneath.
  7. Mar 3, 2021 at 2:11 PM
    Black DOG Lila
    Virginia
  8. Mar 3, 2021 at 2:17 PM
    tirediron
    Fair - my point being that FF is for use on non-oxidised metal, while the Corroseal is for use on oxidised metal. In other words, diligent application of the former will hopefully negate the requirement for the latter.
  9. Mar 3, 2021 at 2:51 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Lila, can it be sprayed or is it too thick?
  10. Mar 3, 2021 at 3:10 PM
    Markcal
    Markcal Well-Known Member
    Just curious, what is it about ff that doesn't have you sold?
  11. Mar 3, 2021 at 3:16 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Wool wax is way better than fluid film (I've used both)
  12. Mar 3, 2021 at 3:19 PM
    Black DOG Lila
    Virginia
    Coroseal has the viscosity of heavy cream. Sprays well by cup gun at 30psi.
    Will work in hand held automotive pump sprayers.
    Rachelsdaddy and alarka like this.
  13. Mar 3, 2021 at 4:33 PM
    alarka
    WNC/SE GA
    2k X cab 3.4 5spd
    Yes, I used a electric backpack sprayer and paint brushes to spread it out AND the warmer the easier it is to apply and a gallon will do about 2 trucks I did my Taco and my T4R I had at the time and turned out really good
    Rachelsdaddy likes this.
  14. Mar 3, 2021 at 5:13 PM
    Taco2021LB
    Don
    WA
    2004 DblCab 4x4
    I'm old school.
    FF is too much farking around, having to apply it every year.
    A good old thin coat of rubber based undercoat, then a second coat.
    Do it once, and be done with it.
    Problem is, no one does it anymore, except the "under body" only.
  15. Mar 3, 2021 at 5:16 PM
    Taco critter
    Taco critter #mall crawler , patw and ,ttc#0247
    Pottstown /stowe , pa
    02 tacoma 4x4 full mall crawler,
    Ome 3inch ,rims ,cold air intake ,,4 crawler body lift ,cb in ashtray mod,leds, jet maf,Satoshi grille,led roof bar,yakama roof basket ,smittybilt parts,spare tire mount in hitch ,rago fabrication parts, winch bumper ,winch ,285s on wagon wheels ,traction boards ,hi lift jack,wet oaklies,smittybilt ,bamf bedrack,loads more,TOO MUCH SHIT TO LIST
    Seagull233 likes this.
  16. Mar 3, 2021 at 5:16 PM
    Spare Parts
    Spare Parts Changed
    Southern Maine
    2017 MGM Sport DCSB V6 Manual
    Your right the rubberized coating is awesome, until water gets in through a crack and is stuck in there. There is a reason no one is doing it, it’s not all it’s cracked up to be.
    Markcal and Black DOG Lila like this.
  17. Mar 3, 2021 at 5:20 PM
    Black DOG Lila
    Virginia
    Congratulations
    You just won most destructive suggestion ever
    JeffBoyardee likes this.
  18. Mar 3, 2021 at 5:21 PM
    Taco2021LB
    Don
    WA
    2004 DblCab 4x4
    Frame rails should not be boxed and enclosed full length. they should have open areas for water and debris to drain, and get hosed out.
    "C" channel was the best frame design, and just as, or more rigid.
    Anymore the frames are made so cheaply, they build strength by boxing them in, which gives the water places to stay.
  19. Mar 3, 2021 at 5:23 PM
    Rachelsdaddy
    Southern NH
    My father always sprayed and brushed his van with waste oil. He’d lay a disposable tarp on the floor and commence making a mess of biblical proportions. lol... hey, even oily, greasy cast iron won’t rust...
    Black DOG Lila and Taco2021LB like this.
  20. Mar 3, 2021 at 5:23 PM
    Taco2021LB
    Don
    WA
    2004 DblCab 4x4
    Maybe for the area YOU live. Our region doesn't live with salt on the roads all the time.
    Different uses and applications for different regions.
