fluid film on rust??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nvtaco, Nov 11, 2013.
  1. Nov 11, 2013 at 10:22 PM
    nvtaco
    nvtaco [OP] Well-Known Member
    Vancouver, BC
    07 Double Cap TRD Sport
    Vent visors, backup lights, the loadhandler!
    Yeah right, motor oil came directly from the ground refined with all those chemicals in it so we can run it in our trucks..when done with it just pour it back on the ground "whence" it came from. Wow that was SO helpful. Guess you dont understand the original question so you want to add something to the discussion you know nothing about...
    pavement.is.lava likes this.
  2. Nov 11, 2013 at 10:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    :rolleyes:
  3. Nov 11, 2013 at 10:25 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Op don't be lazy like you were with the por15. Actually put some work in the prep and you'll be happy.
  4. Nov 11, 2013 at 10:28 PM
    nvtaco
    Vancouver, BC
    Just want to stop the current progression..should have krowned or fluidfilm it from the start. I think i will give it a shot too.
  5. Nov 11, 2013 at 10:28 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya... it actually came out of the ground with more chemicals in it than when it came out of his engine.
    But I agree that it is irresponsible to dump used oil on the ground... but the primary reason is groundwater contamination. The oil we pull from the ground is far below the aquifers.
  6. Nov 11, 2013 at 10:33 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    How did the POR15 just "wash off"?
    I'm talking about the full 3-stage process that begins with wire brushing to remove any loose flakes, followed by Marine Clean and Metal-Prep, the combination of which cleans, neutralizes the rust, and covers the metal with a phosphate coating in preparation for application of the POR15 sealant/paint product.
    If you just grabbed a rattle can of POR15 and sprayed a rusted frame... ya... it's not going to last.
    Nessmuk likes this.
  7. Nov 11, 2013 at 10:47 PM
    nvtaco
    Vancouver, BC
    Sounds hard to believe i know. I can only think that after using the metal ready then the h2o rinse, the underside did not fully dry. Used hose to rinse the m.ready per instructions, truck then sat in a heated garage for approx. 24 hrs. Everything looked and felt dry prior to applying the por15.
  8. Nov 11, 2013 at 11:04 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Strange... that should have done the job.
  9. Nov 12, 2013 at 1:01 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    What Toyota needs to do is test their frames better and just take them and dip them in a better coating than paint.
  10. Nov 12, 2013 at 4:01 AM
    PATACO13
    PATACO13 Well-Known Member
    Ian
    Erie, PA
    '03 V6 TRD 4x4
    stock
    Por 15 is for body work. Frame needs completely restored!
    PREP-RUST CONVERTER-INTERNAL RUST INHIBITOR-RUSTOLEUM-LIGHT COAT OIL.
    I'm not worried about rust.
  11. Nov 12, 2013 at 6:45 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    You'd shit if you knew we oil the gravel roads out here, to keep the dust down. Hey, I'm all for no oil in our roads. I wish it was like driving the rubicon going to work, but alas, too many prius driving hippies to let our roads go to pot. (You just pour a little oil on a rag, then wipe the frame down. Similar to oiling the chain on a motorcycle. It's not messy and won't kill any fishies.)
  12. Nov 12, 2013 at 6:57 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Oh OK then you won't mind if I just dump a few gallons of used oil in your yard then.
  13. Nov 12, 2013 at 7:00 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Dumping oil on dirt roads was outlawed decades ago.
  14. Nov 12, 2013 at 7:09 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    :gossip: a lot of places still do it. :cool:
  15. Nov 12, 2013 at 7:52 AM
    #35
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I'll be darned. It's still common practice here.
  16. Nov 12, 2013 at 8:43 AM
    #36
    Rich91710
    Rich
    Los Angeles
    08 Base
    Even here in Commiefornia.
    Not "dirt" roads... but gravel and "light" pavement.
  17. Nov 12, 2013 at 10:00 AM
    #37
    TrdSurgie
    TrdSurgie revised
    Oahu
    As I said sense and logic.:rolleyes:
    Big difference in whiping something down in oil, like the frame of a truck, than an oil spill. Fyi do you know the asphalt is made from oil and tar?
  18. Nov 12, 2013 at 10:10 AM
    #38
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
  19. Nov 12, 2013 at 11:10 AM
    #39
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    :laugh: lol. Hysterical arguments make me laugh.
    I bought some fluid film to put on my frame, but after thinking about it a lot I never used it. I didn't like the idea of the FF, attracting dust and road grit.
    Instead I cleaned the front half of the frame really well with brushes and rags. And then hit with some Krylon rust tuff enamel. I've also used some Rustoleum flat black as well. The Krylon had an excellent applicator tip compared to the Rustoleum can... Anyways, cleaning the frame sucks. :( But the end result is that it looks almost new again.
  20. Nov 12, 2013 at 6:52 PM
    #40
    Rich91710
    Rich
    Los Angeles
    08 Base
