fluid film on rust??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nvtaco, Nov 11, 2013.
  1. Nov 17, 2013 at 4:25 PM
    #141
    talisker
    talisker Well-Known Member
    Scott
    Vermont
    06 TRD Off Road SR-5 W/1 Ton wood pellets
    Firestone Ride Rite airbags
    The plugs were something like $30.00 including shipping. Shipping was steep making the whole purchase feel like I got little carried away with this whole thing.
    In terms of a light oil to penetrate the frame, that sounds logical and will work well between layers of welded frame but it's only going to last a short time before evaporating and/or washing off under wet driving conditions. A light oil is not something that is going to protect through a winter in northern New England. That's why undercoating materials are thick.
    Bar and chain oil won't penetrate and wick into knooks and crannies? I have to disagree because I can't imagine any reason why it would not. It might be bar and chain but it is also still oil.
    If my truck were new I'd use an undercoating material that would have a more waxy, dry surface. My truck is an 06 from MA with 100k on the odometer. It has little surface frame rust but it does have some and I'm sure it has some between layers of welded frame. I'm apprehensive toward using an undercoating material because it won't penetrate between the layers of frame as fully as bar and chain oil.
    Yes, oil makes a mess and it does build up with road dirt but, this is something that I can pressure wash off whenever I want and will protect the frame over the winter. If I decide to pressure wash, I'll still keep the oil protection that has wicked between layers of steel. I didn't oil spray the leaf springs and they are the only moving part that I can think of that might have an issue with dirt attraction. I did spray the rear end and as many brackets and other surfaces that were showing signs of surface rust. So far the rear end itself hasn't accumilated much of anything in terms of dirt.
    Paint, no matter how well the frame is prepped, will do nothing to stop the rust that is already occuring between the welded layers of steel and the damage will continue. This isn't a solution for me in Vermont with wet road salt being sprayed over everything under the truck and into the cracks between layers of frame material. I've greesed chrome wheels in fall and seen them turn black through the winter with road grime, only to clean them in the spring to find that they were in better shape with less surface rust than the fall before. While it may not be pretty, it works and is easily removable.
  2. Nov 17, 2013 at 4:44 PM
    #142
    talisker
    Scott
    Vermont
    That's good information. I've never heard the 10c. double rate of oxidation before.
  3. Nov 17, 2013 at 6:19 PM
    #143
    talisker
    Scott
    Vermont
    It looks like Por15 and the Eastwood products have mixed reviews. They have few reviews too. If they work, great but not everyone says they do. Fluid film looks like it has a solid non-biased/third party group of multiple reviewers who give it good ratings. It can also flow between layers of steel.
    I haven't had much luck with rust neutralizers and won't trust them till auto body shops are using them instead of sandblasting. Even with sandblasting, auto body shops prefer new replacement parts.
  4. Nov 17, 2013 at 6:49 PM
    #144
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Any drawbacks to spraying silicone on the frame/suspension?
    Silicone will not harm rubber items like dust boots and bushings.
  5. Nov 17, 2013 at 6:50 PM
    #145
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Doesn't chain oil eat rubber ?
  6. Nov 17, 2013 at 7:50 PM
    #146
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Doesn't last long at all. It would wash off within a couple of days driving in the wet.
  7. Nov 17, 2013 at 7:52 PM
    #147
    Rich91710
    Rich
    Los Angeles
    08 Base
    Doesn't hurt o-ring or x-ring motorcycle chains.
  8. Nov 17, 2013 at 8:20 PM
    #148
    OZ-T
    Peter North
    British Columbia
    Interesting
  9. Nov 18, 2013 at 9:42 PM
    #149
    OZ-T
    Peter North
    British Columbia
    How is it that motor oil will eat rubber but chain and bar oil , which is essentially motor oil won't ?
    That's been bugging me all day
  10. Nov 18, 2013 at 9:45 PM
    #150
    Rich91710
    Rich
    Los Angeles
    08 Base
    The chain oil that I used on my motorcycles is clear and pretty thick. Almost a Vaseline consistency, but much stickier. It's really more of a grease than an oil.
  11. Nov 18, 2013 at 9:46 PM
    #151
    OZ-T
    Peter North
    British Columbia
    The previous poster was talking about bar and chain oil ie chainsaw chain oil , it's purple
  12. Nov 18, 2013 at 10:15 PM
    #152
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ahh... I saw "chain" and was thinking motorcycle chain lube.
  13. Nov 18, 2013 at 10:17 PM
    #153
    OZ-T
    Peter North
    British Columbia
    That's what I figured
    So , yeah. , pretty sure bar and chain oil is going to have the same effect on rubber as motor oil
    Anybody dispute that ?
  14. Nov 18, 2013 at 10:50 PM
    #154
    OZ-T
    Peter North
    British Columbia
    Treehugger bar oil , never heard of it
  15. Nov 18, 2013 at 10:53 PM
    #155
    Rich91710
    Rich
    Los Angeles
    08 Base
    'Couple of spotted owls should grease up the frame nicely :p
  16. Nov 18, 2013 at 11:10 PM
    #156
    OZ-T
    Peter North
    British Columbia
    You forgot the Rust Cure Formula 3000 in your recap
  17. Nov 18, 2013 at 11:12 PM
    #157
    OZ-T
    Peter North
    British Columbia
    I'm sure it works fine as a lubricant for chainsaw bars , not sure how it would work for frame coating besides attaracting the local rodent community
    IDK
  18. Nov 18, 2013 at 11:12 PM
    #158
    OZ-T
    Peter North
    British Columbia
    Not yet , I'm going off island next week and I'll be able to go to Crappy Tire then
  19. Nov 18, 2013 at 11:15 PM
    #159
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ding, that frame looks as good as mine.
    That's great for living where you do.
    Says a lot for Fluid Film.
    The dust wouldn't bother me a bit.
  20. Nov 18, 2013 at 11:24 PM
    #160
    OZ-T
    Peter North
    British Columbia
    I use a vegetable based form oil for my concrete forms and when we weren't watching my friend's black lab drank the whole paint tray of it , he was fine but he shit a lot , like a lot a lot , everywhere for about 2 days
