Fluid Film or Rust Check
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buster888, Oct 28, 2018.
  1. May 5, 2020 at 10:12 AM
    ME OFF Rd
    ME OFF Rd Well-Known Member
    Jim
    Maine
    2013 TRD Off Road Edition
    - Digital Fit WeatherTechs - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's with ToyTec 2" AAL
    I've used both, I started putting FF on as DYI when I first got my truck but now I take it to Rust Check. The cost for Rust Check to perform the task was worth it to me because I don't have the mess to clean up nor do I have to crawl around under my truck trying to hit everything.
  2. May 5, 2020 at 10:16 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Fluid film goes on the undercarriage, not the exterior paint. Do they want to paint the undercarriage?
  3. May 5, 2020 at 11:35 AM
    Bit
    Bit Member
    1996 Silver Tacoma
    No they are worried about it getting into the air and creating fish eyes in the paint as well as getting into their filters when in the paint room. I talked with others who say that it won't be an issue after removing most of it. So I am going to do that and take it to a different shop. Just something for people to consider when picking what to use to protect against rust.
    spitdog[QUOTED] likes this.
  4. May 9, 2020 at 9:40 PM
    bob1008
    bob1008 Active Member
    69L46Vert likes this.
  5. May 10, 2020 at 4:03 AM
    FRE1809
    FRE1809 Well-Known Member
    Long Island,N.Y. ; USN ( Ret.)
    Thank you for the info
  6. May 10, 2020 at 6:05 AM
    69L46Vert
    69L46Vert Well-Known Member
    Rick
    Maine
    2007 Regular Cab 4x4
    Very happy with fluid film. Coated my new frame with it, bought the gun and did several more cars. Easy to refresh it every year or two.
  7. May 10, 2020 at 6:40 AM
    Normshark
    Normshark Well-Known Member
    Great White North
    2014 Tacoma DCLB Limited
    I'll toss in a vote for Krown. I've been using it regularly for years and have had good luck with it. My '05 Tundra still has almost zero rust living in salty Southern Ontario. None on the body. It's a little thinner and drips a bit but it seeps into the crevices and seams. I have the underside done every year which is a little cheaper, and the body every few years. Just another option.
    Cheers.
  8. May 11, 2020 at 5:01 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    HI, Code not working for me ... ???
    INVALID COUPON
    Your coupon is not valid!
  9. May 11, 2020 at 6:20 PM
    spitdog
    It works, 5 bucks off. Did you spell tacoma right?:yay:
    Markcal likes this.
  10. May 11, 2020 at 6:47 PM
    Canufixit
    New England
    Ah ! it has a minimum. will not work for 3 spray cans ....
  11. Jan 14, 2023 at 6:18 PM
    tacomadome
    tacomadome Well-Known Member
    I know this is many, many years late, but what they are saying would be true of silicone, where even the smallest bit could ruin the entire shop https://www.nationalcollisionrepair...s-the-issues-with-silicone-in-the-paint-shop/
    I don't know that Fluid Film contains any silicone, so they may be mistaken.
  12. Jan 16, 2023 at 7:45 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Use woolwax same as fluid film but doesn’t wash off nearly as easily (extensively used both)
  13. Jan 16, 2023 at 7:51 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    I bought chain lube for my snowblower and used it last fall on the spare-tire up/down winch gizmo and chain parts. While I had the spare tire down and off I sprayed the inside and outside of the wheel with Fluid Film. I might use the chain lube on the trailer hitch and the inside of the rear bumper. Those two items just laugh in your face when it comes to collecting rust. I swear you could use an entire can in the fall on the hitch and it would still have flaking paint on it the next spring. I think I'll try the chain-lube in the spring on the laminated sections of the frame. I have the Toyota CRC treatment on the truck, but they kind of mailed it in on the application in some spots.
    Marc70 likes this.
  14. Jan 20, 2023 at 9:06 AM
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
    Surface Shield is better than both....
  15. Jan 22, 2023 at 9:40 PM
    #35
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    got some fluid film and got some overspray on my exhaust. got home from work tonight and thought my truck was on fire it smelled like burning paper/cardboard. Guess it's just the fluid film burning off but I definitely panicked for a second.
    I had a piece of cardboard get lodged on top of my exhaust last year and it caught on fire and caused over 1k in damage so I'm a bit paranoid. Got a fire extinguisher ready but it's hard to tell your exhaust system is on fire until you see flames in the rear view mirror.
    Marc70 likes this.
