Fluid film question
Discussion in 'Product Reviews' started by Foozer, Nov 27, 2020.
  1. Nov 27, 2020 at 5:52 PM
    Foozer
    Foozer [OP] Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    I’ve heard fluid film smells like shiz. I just got a new 2021 Pro, does the smell fade if you use it just on the undercarriage, or should I go with an alternative like T9?
  2. Nov 27, 2020 at 5:54 PM
    cseigh
    cseigh It's time for the smug face!!!!
    Carter
    Eastern NC
    '17 TRD OR DCSB 6MT MGM
    Smells for a couple weeks, then it goes away. Works great. Will make you filthy every time you work on the truck.
  3. Nov 27, 2020 at 5:55 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Anyone have experience with T-9, I’ve heard it works well
  4. Nov 27, 2020 at 5:56 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
  5. Nov 27, 2020 at 5:57 PM
    cseigh
    Carter
    Eastern NC
    I use that for other application like outboard motors. Works well, but would be pretty expensive to coat a whole truck and I find it washes off easier.
    Foozer[OP] likes this.
  6. Nov 27, 2020 at 5:58 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Truth. I now make sure I have gloves on when I work under my truck.
    doublethebass and Foozer[OP] like this.
  7. Nov 27, 2020 at 5:59 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    This work pretty well?
  8. Nov 27, 2020 at 6:00 PM
    cseigh
    Carter
    Eastern NC
    Same thing, Woolwax is the new name for Fluid Film. Same product.
    Foozer[QUOTED][OP] likes this.
  9. Nov 27, 2020 at 6:01 PM
    Iwilltaco
    Under development
    Not true
    SilverBulletII and doublethebass like this.
  10. Nov 27, 2020 at 6:02 PM
    Iwilltaco
    Under development
    Yes, it’s thicker, doesn’t make as big of a mess when spraying it on, and doesn’t have that horrible smell.
  11. Nov 27, 2020 at 6:03 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    During the winter do you just leave the underside alone and not wash it? Does it have any color or drip off?
  12. Nov 27, 2020 at 6:07 PM
    cseigh
    Carter
    Eastern NC
    I rinse the underside weekly with the soapy water nozzle at the carwash in the winter. Just don't blast it with high pressure. Sprays on as sort of opaque film, but I think Woolwax carries a black version now that might blend better. No drips, the stuff is pretty thick.
  13. Nov 27, 2020 at 6:09 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Worried fluid film is going to stank..
  14. Nov 27, 2020 at 6:11 PM
    Iwilltaco
    Under development
    Yep, light spraying is fine with Woolwax, it took a lot of undercarriage washes this spring and summer and held up well, but don’t go crazy in the winter. And yes, black is available
    doublethebass likes this.
  15. Nov 27, 2020 at 6:19 PM
    Iwilltaco
    Under development
    It does, that’s why I said Woolwax. I did 5 years of FF, worked fine, no real complaints, but it stinks and messy when applying. Woolwax the last 2 years, I like it better, because solves those 2 issues, and it holds up a little better.
  16. Nov 27, 2020 at 6:23 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  17. Nov 28, 2020 at 3:48 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I used FF it's a little bit cheaper. You can get a 6 spray can pack with a long hose for about $66 on Amazon. Since I don't have a compressor I used those. Wool wax is more expensive and they say thicker and less stinky.
    Mine smelled funny for few days and then in a week you could not smell it at all. I park outside but if you use a garage you might notice it more than I did and the smell might linger longer.
