Fluid Film questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shocked, Aug 1, 2021.
  1. Aug 2, 2021 at 6:48 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yup, you'd like to see a freshly black painted frame if possible with not even any light surface rust. Don't worry about some areas in the chassis that weren't fully painted. Also recommended to avoid any rust inhibitor coating on plastic, or rubber components when possible.
  2. Aug 2, 2021 at 6:54 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I used Woolwax. It's Fluid Film but thicker. No one has questioned me and most of it (if not all) is still on there from when I applied it last November. Time will tell how well it works but I'm planning to touch it up before this winter. It also gives you a good excuse to crawl under the truck and inspect things.
    zoo truck and Aqualoon like this.
  3. Aug 2, 2021 at 8:19 AM
    zoo truck
    None
    Not as much to worry about that stuff if not living in the rust belt. Its a different ball game living up here.
    RedWings44[QUOTED] likes this.
  4. Aug 4, 2021 at 5:45 PM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    You will need more than three for the initial application. I used 10 cans. Also order the flexible wand so I could get into the interior frames spaces ad such.
    No, it is not a gimmick. It prevents rust.
  5. Aug 4, 2021 at 8:11 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    I use fluid film on my vehicle. Spray every fall, never clean the old off. Some areas that get high spray and road debris will wear off the film, but just reapply as needed. I used 5 cans initially on first application, and every fall 4-5 cans again. Make sure to spray in every hole and crevice inside the frame and drop the spare tire. Road wash really hits the spare tire area. And don't apply on your driveway or garage floor unless you have the floor covered well as it makes a slippery surface. I always apply mine in the yard. Try to get the spray wand nozzle off Amazon to add to your setup, it makes getting it inside the frame easier.
    FloridaCementTaco likes this.
  6. Aug 5, 2021 at 10:51 AM
    mhornco
    mhornco Well-Known Member
    I bought a setup off ebay or Amazon (cannot remember which) and it came with a gallon can of the stuff, two rattle cans, and a sprayer with extensions that connects to my air compressor. The sprayer came with two bottles you could refill from the gallon can. Ended up being about the same price as a bunch of rattle cans. You can also use woolwax, which is essentially the same stuff as fluid film and made by the same company. It is a little thicker. Supposedly it also smells less but my nose could not tell the difference.
  7. Aug 5, 2021 at 11:03 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Getting the bucket and sprayer is the way to go. I didn't bother with the cans. Much cheaper in the long run. Assuming you already have a compressor.
  8. Aug 5, 2021 at 11:07 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Just Do It
  9. Aug 5, 2021 at 11:26 AM
    robe689
    robe689 Well-Known Member
    Bob
    SE Connecticut
    2020 Silver Tacoma SR5 Access Cab V6 4WD
  10. Aug 5, 2021 at 12:19 PM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Fluid Film guy here. I love the stuff, does the job but don't pick a windy day...and wear goggles!
