Fluid Film smells so bad
Discussion in 'North East' started by Steevoreeno, Oct 22, 2017.
  1. Sep 24, 2018 at 3:24 PM
    Markcal
    Markcal Well-Known Member
    I have heard people who love their product and are so dedicated to its use as you are, Fluid Film will 1.) Coat your casket upon death for free or 2.) For the real FF fanatics, they will make a casket that looks like a metal drum of FF and your tombstone will get a coating annually before the salt hits the roads in winter.
    cruxofthebisquit likes this.
  2. Oct 6, 2018 at 6:11 PM
    BngdUpTaco’03
    BngdUpTaco’03 Member
    Chuck.D
    Vermont
    ‘03 Tacoma/SR5/V6/ext. cab/Black
    Superbumps, N.West Off-road coils & Bilstein 51’s in front. Timbren SES & Bilstein 46’s in rear. CURT receiver hitch on front & rear. VanGuard lumber rack.
    I use it every other year, great stuff! Then hit the dusty roads to get some grit on it. Was told it goes on best when warmed up and takes less product to get good coverage. According to him an airless sprayer is the best method, otherwise set compressor to 90 psi.
  3. Oct 10, 2018 at 5:42 PM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    Brought my first gen from Colorado to Connecticut, anybody have an idea how many cans I need to coat my frame? Not looking forward to the salt out here. The old xj I drove out to CO was a pile of rust.
  4. Oct 10, 2018 at 5:49 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Depending on how detailed you want to get with coverage, it will probably take 3 for thorough coverage of the exposed sections of frame and then 1-2 more for the boxed sections. I’d also recommend you get an extension hose to spray up into those boxed areas and crossmembers. Overall probably 4-5 cans for good coverage. You can do it with less or more though.
    One thing I would NOT suggest is spraying this shit up into your rocker panel holes. It will heat up in warm weather and your cab interior will smell like slaughterhouse. Use some other product for rockers and door panels that doesn’t smell so damn bad. CorrosionX is my go to but there are about a million others, CRC, boeshield, Amsoil HDMP, etc.
    KY_Rob and lukester78[QUOTED] like this.
  5. Oct 10, 2018 at 6:09 PM
    BngdUpTaco’03
    Chuck.D
    Vermont
    If you buy a gallon and use a compressor w/sprayer you it can be done with 1/2 - 3/4 gal. And you’ll have some left over for the next time. Been the most cost efficient way for me. I use a throw away paint brush to start with to get the nooks n crannies before spraying.
  6. Nov 9, 2018 at 1:45 PM
    KVTaco
    KVTaco Well-Known Member
    I saw a Fluid Film test once and the best was when it was NOT washed during the winter. So apply and let is sit without washing the undercarriage.
    DrFunker likes this.
  7. Oct 20, 2019 at 6:22 AM
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    let’s resurrect this thread...wish I would’ve seen this Friday night. Just gave my truck it’s first Fluid Film douching yesterday, complete with rocker panels. Lol! It smells quite bad. Hopefully it’ll dissipate in a few days.
    I did it in my driveway using 11+ spray cans and the little hose from Amazon. Sprayed inside all frame rails, suspension components, rear fender wells, tail gate, all door latches, inner fender wells under the hood, all exposed ground connections, battery terminals, axle housings, outer floor pans...everything I could get to outside (obviously not the exhaust). These guys saying they did the whole truck with 2 or 3 cans...can’t help but think that coverage would be suspect after doing this myself.
  8. Oct 20, 2019 at 6:33 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I like the smell.
    Markcal and KY_Rob like this.
  9. Oct 20, 2019 at 7:58 AM
    KY_Rob
    Rob
    North East Ohio
    To each their own brother. Lol. I must’ve gotten some overspray on the manifolds, because she was smokin a little this morning. Might go run the I-275 loop around Cinci and try and burn some of that off.
  10. Oct 20, 2019 at 8:04 AM
    jowybyo
    Joe
    Baltimore, MD
    haha yea. I really don’t think it smells all that bad. Everyone says it does, so I’m obviously the weird one.
  11. Oct 20, 2019 at 10:28 AM
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    Switched to WoolWax, this fall. Similar type product, and it doesn't smell !
    Brownie_Man and KY_Rob like this.
  12. Oct 20, 2019 at 11:18 AM
    KY_Rob
    Rob
    North East Ohio
    After searching and searching for a place to Fluid Film my truck locally (without success), I discover that there is a local place that will apply wool wax, the day after I do the ass stinkin Fluid Film myself.
  13. Oct 21, 2019 at 10:08 AM
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    My truck has never been coated but I plan to start this year. Any risk of getting fluid film on non metal components? For example if I got some on the cv axle boot while spraying the front end would that be problematic? Any differences in durability between ff and wool wax?
  14. Nov 20, 2019 at 5:13 PM
    Steevoreeno
    Steevoreeno [OP] Well-Known Member
    Merrimack Valley, MA
    2015 Access Cab TRD Off-road
    This year I used 5 cans.
    I think I’m going to switch to an air sprayer next year
