Fluid Film - where not to spray
Discussion in 'Detailing' started by neverstuck, Jul 14, 2013.
  1. Jul 14, 2013 at 3:02 PM
    neverstuck
    neverstuck [OP] Well-Known Member
    Vancouver Island
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Before Spraying this stuff all over my truck, underneath and in the engine bay, Are there any places I should avoid spraying?? (such as around gaskets, seals, bearings, certain electrical components etc..
    Also, any spots I should make sure I don't miss?
    Thanks
  2. Jul 14, 2013 at 3:38 PM
    Tacoma Mike
    Tacoma Mike 42 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    Keep away from the exhaust. Some will get on it anyway but don't "spray" it.
    Keep Way from the ft rotors. Myself I spray everything else. Diffs, control arms,backing plates, inside the frame, eccentrics. Spray the body mounts real well. Back of the rear bumper. Complete underbody. Drop the spare and spray the cross braces. If you see it, spray it. As far as elect. Again, don't spray them but don't be afraid of a little overspray. Engine spray again keep away from manifolds and engine. Spray front cross braces around rad and bumper mounts. Myself, just about anything the body color I sprayed.
  3. Jul 25, 2013 at 8:25 AM
    MassAppeal16
    MassAppeal16 Well-Known Member
    Carrollton, KY
    06 TRD SR5 SWB DCSB
    Just got 2 cans of this and will be doing this ASAP
