Fluid Film
Discussion in 'Detailing' started by A7xschecter6661, Oct 16, 2013.
  1. Oct 16, 2013 at 2:52 PM
    A7xschecter6661
    A7xschecter6661 [OP] InSight Retrofits Official
    Pete
    13901, NY
    Hey guys!
    I have some questions for those who have sprayed fluid film.
    Where do I want to spray this stuff?
    I am going to be spraying the whole chassis, but I want to do the engine bay too. For now I am doing every single nut and bolt in the engine bay until I get some feedback.
    Should I just spray the crap out of everything? I wanted to hose down the inner fenders, firewall, oil lines and all.
    I see it says it's flammable? Does that mean I have to keep it off the engine? Or is it just the propellant that's flammable?
    Any help is appreciated, there isn't much info on applying this stuff!
  2. Oct 16, 2013 at 2:55 PM
    169.254.255.201 Well-Known Member
    Interwebs
    I second the not much info on application..
    Bump
  3. Oct 16, 2013 at 3:06 PM
    A7xschecter6661
    Pete
    13901, NY
    I have 12 cans and a BRAND NEW RUST FREE truck.
    Lets get some feedback and spray!!
  4. Oct 16, 2013 at 3:40 PM
    A7xschecter6661
    Pete
    13901, NY
    just sprayed every bolt in the engine bay not on the engine, every screw, hood hinges, edge of the underside of the hood, oil lines, brake line clips where salt catches and corrodes lines, abs block and brake fittings and battery terminals and ground wires.
    Then did the tail gate hinges, cables, bolts, bed screws and tracks.
    Then did all the 4 door hinges, screws, bolts.
    Then the cab to frame chassis bolts and bushings.
    Also sprayed random things around the house, hose fittings, locks, hinges, water meter, the lens for the electric meter that was fogged over, the mail box and a couple other things to show people.
    I only used 3/8 of a can!
  5. Oct 16, 2013 at 11:40 PM
    sr5vic
    sr5vic SR5vic
    Vancouver Island, BC, Canada
    '13 Access Cab SR5 4x4
    285/75/16 Duratracs, 16" Konig Countersteer Offroads, 1" Bora Wheel Spacers, Bilstein 5100's, Total Chaos UCA's, OME 884's, Wheelers's Offroad 2" AAL, Wheeler's 10mm Enhancer Kit, Wheeler's Extended Brake Lines, Trail Gear Diff. Breather, TRD Skid Plate, Morimoto XB LED Fog Lights, Ultra Gauge, AVS Step Shields, 2014 Entune Premium Audio Navigation Head Unit, 2014 Steering Wheel Controls, Leer 100XR Canopy, D2S X Beam HID Retrofit with BLHM, Bolt-on Sliders, TRD PRO Grill, Leer 100XL Canopy, US Offroad Winch Mount, SmittyBilt X2O 10k winch
    i sprayed my entire frame and every weld.
  6. Nov 6, 2013 at 6:01 PM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Before my new truck saw rain I sprayed the entire undercarriage and suspension. After running it through the rain, a lot of it washed away, but a light film was left behind. I don't know if it needed more time to set up or what. I'll probably hit it again though before the weather really turns nasty.
  7. Nov 6, 2013 at 6:08 PM
    Interwebs
    :D
