Fluid film
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, May 14, 2019.
  1. May 14, 2019 at 4:59 PM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    Hello I live in Florida about 20 minutes from the beach .I like to go to the beach on the week ends but I never go in the water the closes i got to the water was about 10 feet it has.never touched sea water I was wondering should I spray my frame I don't want it to.rust it's pretty clean frame so I was thinking Maybe some fluid file to prevent rust only.been to the beach 5 times in my truck since I got her
    GQ7227 likes this.
  2. May 14, 2019 at 5:07 PM
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    Yes. Fluid film inside and out.
  3. May 14, 2019 at 5:09 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Should.i.just avoid the beach lol but should I wire brush the surface there little rust spots here and there no holes just surface rust
    GQ7227 likes this.
  4. May 14, 2019 at 5:14 PM
    rogerman
    Roger
    HNL 808, SPN 670
    Yes. Avoid the salt spray but going to the beach isn't going to swiss cheese your truck right away. You could brush off surface rust and repaint or you could use Por15/Ospho/Rust converting paint then fluid film. The key is to spray inside and out on a regular basis, these frames require maintenance.
    2002Tacoma4x4 and GQ7227 like this.
  5. May 14, 2019 at 5:19 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    O okay thanks man I well for sure use my corolla for beach for now on lol i love my truck but anyway how would i got about spraying my frame what should I use I have never done this I have no problem buying the right tools to do this job is there a special kind of oil I should used
    GQ7227 likes this.
  6. May 14, 2019 at 5:23 PM
    rogerman
    Roger
    HNL 808, SPN 670
    jammer and GQ7227 like this.
  7. Mar 21, 2020 at 6:09 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    it sure woulda been golden for my servicing dealer of nearly 23 years to have educated me of the required maintenance so that i could've possibly avoided the pending procedure under my truck. The only advice they have ever offered to me was to re-undercoat it with the rubber coating stuff! which TW shows to be bunk after extended time in salt-laden streets during the winter months
    this is not to mention the oftentimes extreme humidity and fluctuating temps from warm to below freezing on a changing daily basis at times
  8. Mar 21, 2020 at 8:36 AM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Yes the frames require cleaning ..... and then application of corrosion products. I do this twice a year by scraping, compressed air, pressure washing and even a toothbrush. In Canada I pay Krown to spray late in the summer/early fall. Throughout the year I am constantly spraying fluid film in areas that require it.
  9. Mar 22, 2020 at 4:43 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    Yea the frames require regular attention. Just did a lot of front end work on a 94 Hilux. It was amazing condition underneath. I will be kept up with FF. These are excelent vehicles except for a few weaknesses - frame corrosion resistance, rear parking brake belcrank ......
    2002Tacoma4x4 likes this.
  10. Mar 22, 2020 at 5:03 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    Since you are close to the ocean you will need to keep up with regular cleaning and Fluid Film applications.
    2002Tacoma4x4 and SilverBulletII like this.
  11. Mar 22, 2020 at 5:45 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    wait.... wait... DO NOT APPLY FF YET !!!!!
    IMHO before applying FF and since you said you have no problems getting the equipment and DYI then I would do a different approach....
    * all you know rust need 3 things, water, metal and oxygen
    * all you know the risk is the Rust inside the frame the invisible one
    I saw few years ago an immaculate super clean brand new look frame
    on a TRD green excab super low miles 63K sold for 10K with only ONE hole next to spring holder of passenger side
    https://www.tacomaworld.com/threads/2002-tacoma-trd-with-63k-miles.574247/
    I was shocked to see such new frame with a hole, seller show nice pictures of everything and got sold in 2 days
    but got me thinking ....why for all frames got cavities in the same area.... then....
    I got the boroscope and went down yesterday and found secret pockets of frame build inside the frame
    i FOUND THE reason, .... there is a hard to see interior corner with an interior hole pocket ( not a drain pocket)
    and that is where the 1st place of breakage for these frames....
    no wonder why..... i just noticed by accident.... is a square metal with some angle an a central round hole, kind of reinforcement additional metal section build inside the frame that anyone would miss that, even spraying the hell of the corner minimum with get inside that pocket and that is where the hole to the exterior and interior get build up....in other words...
    I took some pictures ( on my thread ) today, and if you FF the fuck out you will still miss this spot and that is where all rust will continue to expand...
    anyway..... I did my 1st attempt of tackling rust back in 2016...
    I didnt know much so I missed some spots....
    now I know a little better plus the boroscope big help
    I going to copy and paste this new yesterday discover and post it on my build ( signature page) and got plenty of ideas now with how to handle these secret holes... pockets, with some other ways and some other products before FF, actually FF is not on my radar, nope, better clean and paint before an sticky or waxi cover
    I will continue on my signature thread adding links and pictures when the time comes to tackle this project again....
    GQ7227, WrappedTaco and cruiserguy like this.
  12. Mar 22, 2020 at 6:02 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    The spot where the rear most box frame meets the C frame rear is where a 360° wand is essential for corrosion prevention.
  13. Mar 22, 2020 at 8:23 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    are you thinking that far back hidden pocket is a good place for dust turn to dirt buildup that can trap moisture?
    2002Tacoma4x4[QUOTED] likes this.
  14. Mar 22, 2020 at 10:43 AM
    2002Tacoma4x4
    C K
    Maybe , is just the box build inside the boxed frame, I just noticed and picture mine on the signature link....
    now to the OP, my 2 cents below on the ideal how i will work on these projects slowly ,
    Reason why any method fail, lack of prep
    2016 i lack of degreasing that is why even a
    bad ass exterior paint like chassis saver will fail,
    paint don't adhere to oily dirty surface , adhere to rust if cleaned before
    im still missing a lot of equipment to do it better this time,
    ' but daydream to budget in the future like this:
    *Take pics before
    PROCESS FOR THE INTERNAL FRAME
    Remove skid and gas tank skid, and the spare tire, if you have hands and skills then remove THE BED
    im by myself , I don't have any mechanical skills, I barely can do oil changes,
    With an experience friend removing the bed would be ideal but... oh well,,, idont bother anyone just myself
    Park truck in a 45 degree angle
    *Apply directly with a weeder applicator abundant CHEAP GALLONS OF degreaser inside and outside the frame let it work 20 minutes
    *Water pressure in and out the frame ( looking for a water wand pressure tip for house hose)
    Hand scrub with sponge and degreaser the outside frame
    water pressure rinse again,
    spray a gallon of the badass Pure degreaser PO15 in and out , let set 20 min
    water pressure rinse the weck out of it
    let some days to dry
    spray rust converter non toxic ,non abrasive specially ( pending paste the linK)
    rinse water , Air pressure with a wand and compressor the interior of the frame removing excess of water
    Let it dry a whole week\
    Frame is dry , so
    Air pressure again inside to move any dust residual if any
    cover the floor of the garage where you will park to paint interior with newspaper and carbon boxes
    look up with boroscope for just the rusty spots and hard to reach pockets
    apply rust converter (eastwood ) let dry 72 hours
    cover all holes of the frame with painters tape \ paper tape
    I WOULD LOVE TO FIND AN AIR COMPRESSOR TO USE THIS
    NEW TECHNOLOGY PAINT GALLON FOR JUST $72.
    https://www.amazon.com/XIONLAB-Rust...=rust+primer+and+paint&qid=1584899192&sr=8-11
    NEED mix 20% and air compressor and wand gun ( use the woolwax gun new)
    We are going to use a product that can be apply even to dump and rust areas, work as prime and pain in ONE ( SEE LINk)
    tHIS IS GOING to leave the internal frame totally new ORANGE COLOR inside, let it dry some days,
    look inside, paint any missed spot until all is solid orange all around, let it dry some days
    Then, if you want additional coats of paint...then
    lets put a black coat again on top of this
    ( I know it says not necessary but now is clean and dry)
    so , let's paint in black with the eastwood internal frame 6 CANS ,
    let it dry save 1 or 2 can for touch up and second coat on the critical areas
    Let it dry some days
    now check inside again with boroscope,
    all should look clean black paint , touch up if you miss spots ,
    fully black painted inside and totally dry then
    Let's put another THIRD coat WITH another kind of product
    you can use 4 cans , or with compressor buy the air gun and wand,
    complete kit free shipping for $279 WOODWAX clear or black
    the black newly paint will be more shine on the areas that the clear wax is getting apply, look at the process with the boroscope,
    I will not put black woodlax on black because you will miss the contrast since you lack of light inside frame, check with boroscope
    IF I DONT GET HANDS ON A COMPRESSOR
    THEN AFTER 4-6 cans of EASTWOOD INTERNAL FRAME ,
    I WILL HAVE TO just skip to 4 CANS OF WOOLWAX INSIDE :
    EXTERIOR OF THE FRAME SUPER CLEAN
    After finishing the interior you will have some orange and wax to clean up from the exterior holes of the frame
    while the last coat of the interior is drying
    rust convert any rusty spots
    clean with a rag with paint prep liquid , wipe off with that manually the already cleaned frame
    paint manually with brush and sponges using CHASSIS SAVER, couple of cans for hard to reach areas
    or since you have compressor and gun
    why not , get the whole exterior frame with your paint of preference
    with no compressor, buy cans of eastwood chassis rust encapsulator will be ok
    I would not sweat much on the exterior because is easy to see and frames dont get holes for just surface rust
    Rust can not accumulate if you keep it oily with Woolwax
    Spray the heck of if with WOOLWAX :D
    Drive the hell out of it and if you come in contact with salt water
    then just water pressure rinse, let dry
    then apply WOOLWAX
    I will paste this on my signature link and document whatever method I can do in the future with pictures, i probably edit so much for my stupidity in grammaro_O
    The hell with any critics for my ESL, welcome any positive suggestions.... cheers TW:cheers:
    cruiserguy and GQ7227[QUOTED] like this.
  15. Mar 22, 2020 at 11:12 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    you maybe able to find a 'cheap price' air compressor at a pawn shop?
  16. Mar 22, 2020 at 11:23 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Great post brother! It was all great info but I especially loved this line,
    The hell with any criticts for my ESL, welcome any positive suggestions
    :rofl::rofl::thumbsup::thumbsup:
    Seriously though that is good to share what you've done and seen and tried and noticed and learned. Like you say, the number one key above all would be the prep and getting any grime and loose crap out of there
  17. Mar 22, 2020 at 11:39 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Its a wasted effort. I would not bother unless you plan on taking that truck north in the winter.
    You live near the sea, not in it.
    I'm from Michigan so I know exactly what salt does to vehicles. I also vacation in the Keys every year. All those vehicles live near the ocean. I look over lots of vehicles that spend their entire life next to salt water. The frames look fine, in fact so nice I'm envious. The paint not so much. The sun beats the hell out of the paint.
    If your frame is already rusty, not much is going to slow down the inevitable.
    I use Fluid Film on my vehicles because I have to. You won't gain anything by Fluid Filming your frame.
    If you are driving in the surf, then nothing is gonna help. Please don't drive in the surf.
    2002Tacoma4x4 and cruiserguy like this.
  18. Mar 22, 2020 at 1:53 PM
    Black DOG Lila
    Virginia
    @2002Tacoma4x4
    You may want to seriously reconsider recommending application of USED MOTOR OIL to highway vehicles as well as washing it off and reapplying.
    Fluid film and woolwax are non toxic alternatives to pollution from USED MOTOR OIL.
  19. Mar 22, 2020 at 3:24 PM
    2002Tacoma4x4
    C K
    Yeah... my mistake, never thought about it, i got that idea from someone else in the forum but you’re right...more oil on the road.. ... more oil in the water....nope... not a good idea ... just skip that step and stick to the WOOLWAX generous coat yearly basis... tks !
  20. Mar 28, 2020 at 4:42 PM
    2002Tacoma4x4
    C K
