Fluid film
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, May 14, 2019.
  1. Mar 28, 2020 at 6:29 PM
    01lon
    01lon Well-Known Member
    My first Toyota Tacoma
    Wow! I always heard good things about this company. That is a disaster. Thanks for sharing this.
  2. Apr 16, 2020 at 11:48 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    [​IMG]Wow there is another person who has thought about this as much as me. Great post and I will be lookin for that blocked area real closely when I flush out my frame . I sure hope I didn't miss it with fluid film.
    GQ7227, ontarioyota and 2002Tacoma4x4 like this.
  3. Apr 16, 2020 at 6:08 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    Have you ever flush it out before?
  4. Apr 17, 2020 at 8:48 AM
    Actionjackson
    Jack
    MA
    2004 Tacoma
    Well since I got some time..... I flush the frame every spring then fluid film in fall. I got my 04 in South Carolina 3 yrs ago. When I first got it here in MA,
    I flushed the frame, painted the interior of all the square sections with the green eastwood internal frame coating, then wire brushed all welds and the few areas of surface rust then painted those with a brush and eastwood rust converter. Then I painted the hole frame as best I could (applied it with a rag and stick on top, because I did not remove the bed) with black rust bullet paint. Finally I fluid filmed the crap out of it and do that every fall .
    I just hope I got that area mentioned , good enough with flushing and coating......
    Kind of obsessed with preventing rust but it was my first free vehicle and I've been fighting rust in cars and trucks my whole life. The other incredible benefit of using Fluid film is that usually it seals the area where bolts go into nuts and clips and situations like that and seal out the salt water. It makes things come apart much easier when replacing / upgrading parts. I can't believe how easy stuff comes apart on my truck .
    2002Tacoma4x4, cruiserguy and GQ7227 like this.
  5. Apr 17, 2020 at 8:51 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    so you have not ever experienced the original internal coating peeling off inside (for whatever reason it does idk yet)
    that happened the first time i flushed mine out last year and now i have a bit of a mess on my hands :(
    i can definitely use some help with it
  6. Apr 17, 2020 at 11:11 AM
    Actionjackson
    Jack
    MA
    2004 Tacoma
    To be honest, I don't know if the green internal coating is flaking or falling off. I probably wouldn't because it is all mudded up with fluid film if it is. I don't have a boroscope. Would like to get one. It might not be able to stick good on your frame, and if thats the case, just keep it coated with FF.
    But i am gonna look real close at that area mentioned and see if I can figure a good way to flush it oul
    ontarioyota and GQ7227 like this.
  7. Apr 18, 2020 at 9:38 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    Yes I still am in contact with Eastwood tech help to see if the internal frame coating product will adhere well to naked steel with minimal if any rust present idk lol
    If not I will need to find another coating to spray inside to seal it up good as can be
