Fluid Flushes.. Please help clarify!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drew12, Nov 18, 2017.
  1. Nov 18, 2017 at 5:31 PM
    Drew12
    Drew12 [OP] Well-Known Member
    Andrew
    Sisters, Oregon
    2005 4x4 TRD OR Access Cab
    Bilstein 5100's/Toytec 620 coils, rear AAL, Camburg UCA's, Pro Comp 7069, AFE stage 2 CAI, Blacked Depo Headlights
    Hey guys, I have recently posted about this sort of stuff, but wanted to finalize and get it all laid out. After coming back from toyota the other day, they basically said all my fluids need replacing... Dont know when they had been done last - maybe never (Im at 166K miles). I just want to make sure I will be using the right fluids for the job and how much of each to buy.
    Tranny Flush (Amount: 14 qts):Either Redline D6, Toyota WS, or Valvoline Max Life ATF. (Any other possibilities?)
    Front/Rear differentials & transfer case (Amount: 6qts): Mobil 1 full syn. 75W-90 gear oil
    Power steering flush (amount: ??3 qts??): Valvoline dex/merc? (Any others? I really have no idea on this one because I have heard people argue everything under the sun.. Lemme know what you guys have used and if it works as it should..
    Brake Line Flush (How much fluid to buy?) Also havent researched this one much yet but any info would be appreciated.
    In addition to these tasks I need to complete, I also get to re-seal leaky timing chain cover, replace front drivers wheel bearing/hub assembly, get a new battery, clean and adjust rear brakes. Just keeps adding up. How much is too much as to where I should just sell and buy a newer truck? And how long can a leaky timing chain cover go before any catastrophic issues start to happen?
    I know this is alot of questions, but if anyone can lend some advice and help me finalize all of this that would be GREATLY appreciated!
  2. Nov 20, 2017 at 8:58 AM
    Drew12
    Andrew
    Sisters, Oregon
  3. Nov 20, 2017 at 9:08 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I used 2 quarts when I replace my rack
    brake fluid maybe a quart
    wheel bearing on ebay for 100 bucks or guy on here sells them for 175
    timing cover leak could go on for years or start to leak really bad in a day
  4. Nov 20, 2017 at 9:08 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    do all the gear boxes first.........motor oil......G O O D filter !! SYN !!!!
    worry about PS.....cooling later.......
    someone will chime in
    Drew12[OP] likes this.
  5. Nov 20, 2017 at 9:13 AM
    Clearwater Bill
    Billy
    Largo Florida
    As far as selling and buying new.......
    Your list includes a lot of ignored routine maintenance, along with some normal repairs. If you will keep up with things it won't seem so overwhelming in the future.
    As far as the trans goes. I'd do multiple drain and fills. You'll eventually consume that much fluid, but doing an actual flush/ fill as you propose isn't really a driveway task.
  6. Nov 20, 2017 at 9:17 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I'd recommend getting at least an extra quart of the 75w90 gear oil to flush your diffs and tcase with after draining. If they have really never been changed then there's probably some gunk in there that you might be able to dislodge with some flushing.
  7. Nov 20, 2017 at 10:47 AM
    Drew12
    Andrew
    Sisters, Oregon
    Awesome thanks man. I think Im going to get the dorman wheel bearing/hub from rock auto. I dont want to send too much on the other ones even though they are better.. Lots to do for the truck in the coming future so trying to save as much money possible.
  8. Nov 20, 2017 at 10:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    Caution. Some things are pay once, cry once. Some cheap parts are fine. Ones with little labor and risk of leaving you stranded.
    Some items deserve your full attention.
  9. Nov 20, 2017 at 10:53 AM
    Drew12
    Andrew
    Sisters, Oregon
    Youre totally right. I bought the truck from a dealer used figuring they would have atleast changed all the fluids... I suppose ignorance on my part.. All other routine maintenance is done at regular intervals. Once I do all of this, everything will be done regularly again.
    For the trans, wont doing multiple drain and refills just mix in the old with the new and to get it completely clean would need twice as much fluid? I was thinking of doing the trans flush per the tutorial on TW. Seems like something I could do in the garage. Just curious as to why this wouldnt be a driveway task?
  10. Nov 20, 2017 at 10:55 AM
    Drew12
    Andrew
    Sisters, Oregon
    So basically drain-refill-drive a bit-drain-refill? I was going to get 6 quarts for both differentials and transfer case. I guess I should get more like 8 in order to flush?
  11. Nov 20, 2017 at 10:58 AM
    Drew12
    Andrew
    Sisters, Oregon
    True. Ive heard people on here saying that the dormans have actually lasted them a long time.. Others less. I would take the time to rebuild the assembly, but when pricing out, it was more expensive than the new complete assembly itself. $175 for the bearings by bamatoy or the other dude that sells them on here just seems expensive. Not sure what to do. Id rather get the TW assembly's but all this is adding up to be pretty spendy.
  12. Nov 20, 2017 at 11:09 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    No just drain completely then use a hand pump to forcibly squirt new oil into the empty diff/tcase for a few good pumps. After the pumped oil drains then plug and fill to appropriate levels. That oil is going to smell like liquid death if it hasn't been changed in over 100k miles. ;)
    Blockhead and Clearwater Bill like this.
  13. Nov 20, 2017 at 8:08 PM
    Drew12
    Andrew
    Sisters, Oregon
    Do you think that just a few forcible pumps will really do much? Just rinsing the gears of some metal particles? And does a few pumps mean about 1/4 quart or less?
  14. Nov 20, 2017 at 8:14 PM
    Drew12
    Andrew
    Sisters, Oregon
    Also, for the t case and diffs, do you just refill til they overflow and plug em back up? Or is there a certain amount of oil needed for each?
    boogie3478[QUOTED] likes this.
  15. Nov 21, 2017 at 3:33 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I think it will help a little. Most of the metal shavings should be held by the magnet on your drain plug, but pumping might dislodge some of the thicker burned oil.
  16. Nov 21, 2017 at 3:34 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Yes all 3 have a set amount of oil to use, but you can stop as soon as you see the new oil start to dribble out of the fill plug.
  17. Nov 21, 2017 at 3:52 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Don't overthink it, just drain and fill. It's easy, and stinky, but saves lots of money by DIY. Plenty of good 'how to' info on the the web.
    boogie3478 likes this.
  18. Nov 21, 2017 at 3:55 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    No one should be taking their trucks to the dealership for these fluid changes. :thumbsup:
    Blockhead[QUOTED] likes this.
  19. Nov 21, 2017 at 8:54 PM
    Drew12
    Andrew
    Sisters, Oregon
    Thats exactly my problem sometimes. Im just guna go for it and it should all go well hopefully.
  20. Nov 21, 2017 at 8:55 PM
    Drew12
    Andrew
    Sisters, Oregon
    Totally agree! They wanted $66 per diff and didnt even quote the T case. Tranny Flush $245 and PS flush was another hundred or so. Rediculous if you ask me. I always like to do this kind of stuff myself when I can. I just like to do thorough research before I start. Thanks for all your help!
