Fluid leak on front passenger side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Daxdagr8t, Apr 25, 2016.
  1. Apr 25, 2016 at 10:18 PM
    Daxdagr8t
    Daxdagr8t [OP] Well-Known Member
    Socal
    07 prerunner
    None
    Whats up guys. Im leaking fluid in my passenger side thought i just spilled something. Read around and all point to a heater core leak and it sound expensive. My coolant is kind of low but its been 3 yrs since i did a coolant flush. I do get a musty odor from time to time when the heater is on.
    Im gonna experiment something this week and put absorbent pads on the passenger side, top off the coolant and run the heater from time to time to confirm.
    Any other ideas is welcome. Also read to run a wire or zip ties on the hose but dont know which one lol. Pics will greatly be appreciated. Thanks.
  2. Apr 26, 2016 at 2:12 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  3. Apr 26, 2016 at 7:01 AM
    Daxdagr8t
    Socal
    07 prerunner
    None
    Thanks. Checked my coolant before i went to work this morning and it was below the low line. I put water in it for now until my coolant comes from Amazon later.
  4. Apr 26, 2016 at 5:47 PM
    spp
    spp OC, Kalifornia
    OC California
    You did not ID the fluid. Coolant or just something wet and clear?
    I once had a Corolla that had a cabin air filter that I did not know about.
    Hot spell driving along the coast and the AC was barely cooling and restricted flow of air.
    Pulled over and found , with the help of the owners manual, the filter was clogged but the reduced flow caused the coils to ice up.
    The drive home the ice melted and dripped on the passenger side.
    Smelled musty also.
  5. Apr 26, 2016 at 6:00 PM
    Daxdagr8t
    Socal
    07 prerunner
    None
    Might be coolant. Its pink. Going to clean the rubber mats and put a white absorbent pad. Going to top off the coolant tonight and run the heater tomorrow and see if any leaks come out. Looked at the glovebox its bone dry so as the area around it. Hopefully its a spill but cant remember what kind.
  6. Apr 27, 2016 at 5:52 PM
    spp
    spp OC, Kalifornia
    OC California
    If the overflow tank in the engine compartment is pink then it IS coolant. Probably time for a new heater core.Any fogging of the windshield?
  7. Apr 27, 2016 at 6:13 PM
    Daxdagr8t
    Socal
    07 prerunner
    None
    No fogging. Just toped coolant off. No leaks with the ac and heater off. Will run the heater later on the way home.
  8. Apr 27, 2016 at 7:29 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it is coolant it doesn't matter if the heater is off it will still leak. The coolant still circulates even with the heat turned off. I think you have a backed up condensate drain tube.
  9. Apr 27, 2016 at 7:30 PM
    Daxdagr8t
    Socal
    07 prerunner
    None
    How do i check? Thanks for all the help.
  10. Apr 27, 2016 at 7:35 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Locate the hose where it exits the firewall under the hood on the passenger side. Poke a tye wrap or a stiff plastic stick or ... up into it and see if anything starts draining out.
    Run the air conditioner on high and watch to see if liquid flows out, it should.
  11. Apr 27, 2016 at 7:42 PM
    Daxdagr8t
    Socal
    07 prerunner
    None
    Aight thanks will do tomorrow.
