Fluid Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rwood, Feb 26, 2019.
  1. Feb 26, 2019 at 8:53 PM
    Rwood
    Rwood [OP] Well-Known Member
    Raymond
    WNC
    15 TRD Off-road
    i have been looking and trying to find out what everyone uses for front/rear/transfer case fluid and seen that most use 75w-90. Do you use that in all three or just front and rear and something else for transfer case? Also what is the best type. Going in a 15 TRD off-road. Thanks
  2. Feb 26, 2019 at 10:57 PM
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    I just use mobile for all 3 plus the trans. It’s a 6spd. Just make sure u use the one with the additive for the rear of ur truck has LS
  3. Feb 26, 2019 at 11:56 PM
    ToxicPelican
    ToxicPelican Well-Known Member
    San Diego
    2012 DCSB
    75w90 is good to go for front and rear diffs and transfer case. If you have a 2015 TRD offroad then it's an open diff with the E-locker in the rear, so no limited slip, and no LS modifier (someone please correct me if I'm wrong).
    As far as the best fluid to use? ECGS, which many on here think highly of, recommends Lucas dino, or if you insist on synthetic the severe gear stuff from Amsoil. I think you're probably ok with most any brand, as long as it's the right weight/spec and you change it at the recommended times then you're already ahead of the game.
    I put 75w90 synthetic in mine at 30k. When another 30k rolls around, I'll think about what to put it then.
    Rocksteady1 and Blockhead like this.
  4. Feb 27, 2019 at 2:49 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I use 75/90 synthetic in all three...and change them once a year which equates to about every 50,000 miles. I don’t off-road or tow very often, light hauling mostly...ymmv
  5. Feb 27, 2019 at 7:31 PM
    Rwood
    Raymond
    WNC
    15 TRD Off-road
    Does one use Amsoil 75w90 or Lucas 75w90 and if so which one is better?
  6. Feb 27, 2019 at 7:39 PM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    I’ve used both in all of my Toyota trucks and SUVs over the years and noticed no noticeable difference between the 2 products. I’d say go for whatever is cheaper, and stick to the proper service intervals.
  7. Feb 27, 2019 at 7:50 PM
    Rocksteady1
    Rocksteady1 "This is the way"
    PNW
    2015 Tacoma TRD Sport. DCSB 6 spd MT. 4x4
    Unifilter mod, CAI, Stereo System.
    Just did all of mine transmission included with RP max gear 75-90. Runs smooth with no noise. I didn’t think you need LS additive as the 2015 doesn’t have a true limited slip diff. Isn’t it all brake controlled? Please correct me if I am wrong here.
    Now do it again I think I will just go with Mobil1. Royal Purple was very expensive and probably not any better than Mobil1
    StillNoPickles likes this.
  8. Feb 27, 2019 at 8:32 PM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Just get the proper viscosity brand doesn't matter
    TacomaMike37 likes this.
  9. Feb 27, 2019 at 9:09 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    I used both as well last time. Amsoil Severe Gear in the rear and Lucas dino in the other 2.
  10. Feb 28, 2019 at 4:57 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I use it in all three like the manual says...
