Fluid Thermostat for Power Steering & Trans on 3rd Gen
Discussion in 'Technical Chat' started by xCaldazar, Feb 17, 2023.
  1. Feb 17, 2023 at 6:25 PM
    xCaldazar
    xCaldazar [OP] Well-Known Member
    Los Angeles
    2018 SR5 Purple 4x4
    King shocks, Deaver rear leaf springs, Cab mount relocation, Howe TC Pump, 315/75/17, Outgear tilted rear bumper, Tune Outdoor M1 camper, Coastal Offroad Extreme Clearance front bumper & skids (aluminum), Cali raised kick out sliders, Alphaequipt carbon air intake (color matched) Clazzio leather seat covers, Sound Deadening, Dual battery
    I am trying to determine if the 3rd gen has a fluid thermostat for the power steering and the transmission. I recently upgraded the heat exchanger on each.
    I was considering putting in something like the "Derale 13011 Fluid Control Thermostat", that bypasses the radiator/heat exchanger I installed until temperatures rise. I usually am off-roading in the desert, but also make it up to Canada in the winter. So it isn't pressing, but I wanted to do get it done while everything is apart to keep my truck operating optimally in lots of climates.
    In this thread it sounds like the part number is the thermostat for the transmission 224100-4240 :
    https://www.tacomaworld.com/threads/transmission-cooler-thermostat-partially-stuck-open.733563/
    Where as this thread has people adding a thermostat:
    https://www.tacomaworld.com/threads/transmission-heater-and-or-thermostat.780219/
    I couldn't find indication regarding the power steering.
  2. Feb 17, 2023 at 6:36 PM
    xCaldazar
    Los Angeles
    2018 SR5 Purple 4x4
    Ah I think I got an answer on the transmission.
    https://www.tacomaworld.com/threads...l-toyotas-write-up-with-many-pictures.526283/
    Pretty sure the power steering doesn't have one tho.
