Fluids, fluids, fluids.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by calico, Feb 18, 2017.
  1. Feb 18, 2017 at 4:36 PM
    calico
    calico [OP] Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
    I recently had my transmission, and front and rear differential fluids replaced. Now, I see mention made of transfer case fluid replacement. Is that something totally different from the others mentioned, or simply another term used for them? Thanks in advance.
  2. Feb 18, 2017 at 4:37 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The transfer case is another unit.
  3. Feb 18, 2017 at 4:37 PM
    Bishop84
    Bishop84 Well-Known Member
    Transfer case uses the same driveline fluid as the front and rear differentials. It's attached to the transmission and distributes power to the front and rear axles.
  4. Feb 18, 2017 at 4:39 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  5. Feb 18, 2017 at 6:59 PM
    calico
    Northeast
    13 Tacoma Limited
    Thank you all. But, based upon the responses I've received, apparently, I need to now have the transfer case fluids replaced? I have 60k miles. Again, thanks for the assistance.
  6. Feb 18, 2017 at 7:04 PM
    markm0311
    markm0311 ________________
    2000 Toyota RAV4
    Transfer case is super easy just pick up some Mobil 1 and a small pump they sell them at any oreilly or autozone. Pump screws right onto the bottle so you can pump it up into the case.
    Transfer Case Oil: Mobil 1 75W-90
    • Fill Plug Torque Specification: 27 ft. lbs.
    • Drain Plug Torque Specification: 27 ft. lbs.
    Take ya a half hour. Take the fill plug off before the drain plug and your good. Stop filling with oil when it starts to spill out of the fill plug hole
  7. Feb 18, 2017 at 7:06 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I changed mine at a little over 25k and it looked brand new. I think the t-case holds about a quart.
    calico[QUOTED][OP] likes this.
