Fluids Freezing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GeoTaco, Feb 2, 2011.
  1. Feb 2, 2011 at 10:26 AM
    GeoTaco
    GeoTaco [OP] the town is back that way
    Freeda Feltcher
    Denver
    '09 4X4 TRD Off-Road
    Lifted and bigger tires
    I didnt know where to put this, so since it is on my 09 i put it here.
    This morning it was -10 out, and has been below zero for over a day now.
    My question is when do fluids, specifically power steering, radiator and transmission start to freeze?
    Im going this afternoon to get my radiator fluid checked because i am originally from georgia and am not sure if there is a winter blend or not, is there anything else i need to check?
    Thanks
  2. Feb 2, 2011 at 10:29 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    coolant is usually checked to be good down to -20, but being from Ga, yours might have been blended a bit different.
    Not sure about the freezing point of the others, but I suspect lower than -20 bc no one ever checks them for, they just turn a bit thicker.
  3. Feb 2, 2011 at 10:30 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    Not sure about the others, but you can get an antifreeze test thing for a couple bucks at the local auto parts store. It looks like a turkey baster with a hollow inside. Suck up some fluid from the radiator and depending on how many of the balls float will tell you the mix of your coolant and the temperatures it's rated at.
  4. Feb 2, 2011 at 10:31 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    You can get a radiator fluid checker that will tell you how low it will protect for a few bucks at autozone. All those should not be frozen at those temperatures. You can look at getting a transmission heater if you are worried about it.
  5. Feb 2, 2011 at 10:33 AM
    GeoTaco
    Freeda Feltcher
    Denver
    Thanks for the quick responses, it took a few seconds to start the engine this morning, and turning the wheel was more difficult than usual, the transmission was sluggish, and the brakes were really sensitive. I live in an apartment, so the block heater is out of the question.
  6. Feb 2, 2011 at 10:39 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Remote start or let it warm up a few mins with you in the truck!
  7. Feb 2, 2011 at 10:49 AM
    GeoTaco
    Freeda Feltcher
    Denver
    I always let it warm up abit, atleast until the air coming out of the vents is not cold. Im really wanting a remots start now.....hmmm next mod maybe??
  8. Feb 2, 2011 at 10:51 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just imagine if you lived up in summit county...it would be even colder.
    I would just check to make sure your coolant is the proper ratio. Other than that, you should be fine.
  9. Feb 2, 2011 at 10:52 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Some oils (engine, gear, transmission) are made for below 0 temps. I'd check with the manufacturer of the fluids to see what temp ranges they are rated for. For instance, on the Mobil 1 website it has a question for if you will be in above or below 0 temps where you are located.
  10. Feb 2, 2011 at 11:20 AM
    wlmuncy
    William
    Knoxville, TN
    Minus the block heater, you can cover the front of the truck to limit windchill to it overnight.
  11. Feb 2, 2011 at 11:22 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    -10?
    wow. that's cold!
  12. Feb 2, 2011 at 11:30 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    yep. driving home last night, the "what it feels like" or "real feel" said -29 and dropped to -33 throughout the night.
  13. Feb 2, 2011 at 11:34 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    hah... if i did that, it would be sitting in my driveway for 15 minutes... hell.... i could be at work in 15 minutes :)
    it was minus 20 last night and the cab of my truck didnt feel comfortable until i got to work :)
  14. Feb 2, 2011 at 11:38 AM
    jester156
    Cumberland, RI
    aside from your fluids, make sure your battery is strong, nothing will kill the battery quicker than the cold weather, and leaving the lights on :rolleyes:
  15. Feb 2, 2011 at 11:38 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Yeah... we get into the -30s here occasionally and I have yet to have anything freeze up on me. You should be okay. Just make sure you know what your antifreeze is rated at as well as your oil. If you just give it a few minutes to start up you should be okay.
  16. Feb 2, 2011 at 11:40 AM
    GeoTaco
    Freeda Feltcher
    Denver
    after about 10 min this morning, i was on the move, the engine did not get to normal temps before i got to work.....never thought that would happen
  17. Feb 2, 2011 at 11:50 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Got down to -10 or so last night with lots of wind... My truck was NOT happy starting this morning. Think it's time for a new battery. Fluids were fine though.
  18. Feb 2, 2011 at 12:07 PM
    Biff
    Biff What could go wrong?
    Winnipeg
    07 SR5 Doublecab
    Bilstein 5100's all around, fronts set to 1.75, 18" Method Race Wheels, 285/60/18 Cooper Zeon LTZ
    It was -30c here last night with a windchill in the -40s. No vehicle starts good in those temps. I have only ever had a fluid problem one time when my gas line froze. Other that that just make sure you have a good quality oil, low temp anti-freeze coolant and let her warm up a bit before heading out.
    Remote car starters are the goods - winter or summer!
  19. Feb 2, 2011 at 12:13 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Oh, and one other thing! Fill your gas tank and use some iso-heet! Gas line freezes seem to be more common than anything else, around here anyway.
  20. Feb 2, 2011 at 1:53 PM
    JKD
    JKD Well-Known Member
    Once the fluids are moving, there's really very little reason to "let it warm up". It will warm up faster if it's being driven. Just go easy on it until it is up to op temp.
