Flutter Noise while Accelerating
Discussion in '1st Gen. Tacomas (1995-2004)' started by bcrooms, Jun 26, 2018.
  1. Jun 26, 2018 at 7:19 AM
    bcrooms
    bcrooms [OP] Well-Known Member
    Brandon
    Georgia
    1999 Toyota Tacoma XCab 2.7L SR5 4WD
    I've searched the interweb extensively about this annoying noise that my 1999 Tacoma 2.7L 4x4 makes when accelerating.
    The best way I can describe the noise is that it sounds like something is fluttering in the exhaust or engine. Almost sounds like something fluttering in the wind.
    Only happens under acceleration. When accelerator is not pressed it immediately stops.
    I recently had the exhaust manifold replaced due to the typical cast iron crack in the stock manifold.
    Any ideas what would be causing this noise? It also seems to affect performance in my opinion but it may not that much.
    Thanks,
    Brandon
  2. Jun 27, 2018 at 7:15 AM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    I would first go back and make sure everything is tight. All nuts, bolts and stuff like that.
  3. Jun 27, 2018 at 7:17 AM
    bcrooms
    Brandon
    Georgia
    I'll check those
  4. Jun 27, 2018 at 1:46 PM
    Glamisman
    Glamisman Well-Known Member
    there are 2 rubber idolators that keep the exhaust heat shield/lower intake system separated. If not those, I would start by examining the air filter housing... take the filter out/off and see if it is seated properly and the pieces go together correctly or something is broken/cracked, clamps are tight etc.
  5. Jun 28, 2018 at 10:27 AM
    bcrooms
    Brandon
    Georgia
    It does have an airy sound to it, so I'll check the air filter housing and tubing to the throttle body as well.
    I'll look under the truck at the exhaust too, the guy that replaced the manifold did drop the entire exhaust while he was doing the repair to check for other leaks.
  6. Jul 2, 2018 at 7:33 AM
    bcrooms
    Brandon
    Georgia
    I checked the air filter housing and replaced the air filter (needed it anyway) and all those clamps and pieces are snug and no apparent leaks or cracks that I can see.
    I didn't remove any parts to inspect the bottom (didn't have much time to check that in depth)
    I drive the truck every day to work, so this morning I still hear it while I'm accelerating.
    Also the truck just seems to struggle with the slightest incline on the road. And I mean the SLIGHTEST incline. I would expect the truck to have a harder time with steeper inclines, but around my area. the degrees of incline aren't drastic. maybe a few degrees
  7. Jul 2, 2018 at 7:47 AM
    Glamisman
    OK, it seems the easy and obvious has been looked at. I am wondering if the catalytic convertor(s) have fallen apart. Banging on them with a rubber mallet and listeneing for rattles is one way, the other is to take them out and look. A good muffler shop can take a look also. They can put a back-pressure device on the exhaust to see if it/they are broken apart.
  8. Jul 2, 2018 at 7:54 AM
    bcrooms
    Brandon
    Georgia
    I've also thought the same about the Cat. I thought about buying a MagnaFlow direct fit Cat to replace it, but didn't want to drop dough on that yet if it isn't the cause.
  9. Nov 6, 2018 at 7:31 AM
    bcrooms
    Brandon
    Georgia
    Had the Cat replaced with a universal fit MagnaFlow, noise is still present under acceleration (it sounds like a mixture of noisy lifters and a leaky exhaust header in my mind) 90% of the noise is from the engine bay of course.
    I just replaced the valve cover gasket as the factory gasket had a leak near rear passenger side corner of the cover. I also replaced the spark plugs while I was at it. One of the old ones was shot, couldn't even get the gap tool in it.
    Anyway, any further advice is appreciated.
  10. Nov 6, 2018 at 7:46 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    Airy sound is 99% of the time going to be an exhaust leak. Let the truck idle with the AC on (so that the RPM was a little higher) and go underneath. Put your hand around all exhaust connections but dont touch the exhaust obviously to see if you feel any air blowing out of the connections. Also, check the muffler weep hole. It is a common place where the stupid sound can come from. I've had that issue and I know it's there to help keep condensation from building up inside and rusting the muffler out but it was so irritating that I put a self tapper in the hole so it would stop making that noise. Just an idea.
  11. Nov 6, 2018 at 7:50 AM
    bcrooms
    Brandon
    Georgia
    I'll check the muffler drain. The truck does have 244k miles on it, it wouldn't surprise me if the muffler also needs replacement. With the new Cat on, the truck does have a better tone to the exhaust due to better flow.
    Most of the noise (while driving) is coming from the front/engine area though.
  12. Nov 6, 2018 at 9:12 AM
    TSAP
    TSAP Well-Known Member
    1999 Toyota Tacoma SR5 4x4 3.4L
    it will go away it’s just the changing of the weather mine went away and I don’t hear it anymore. It’s the 1999 Tacoma’s that’s all
  13. Nov 6, 2018 at 9:14 AM
    bcrooms
    Brandon
    Georgia
    Lol, I wish the weather change would make it go away, but its been doing this for a good while now.
  14. Nov 6, 2018 at 9:17 AM
    TSAP
    Same mine went away on it own I know exactly what ur talking about it’s been going on for about few months now but it stopped out of know where
  15. Nov 6, 2018 at 9:21 AM
    bcrooms
    Brandon
    Georgia
    I'm gonna do the positive pressure method of checking for more exhaust leaks too.
  16. Nov 6, 2018 at 10:27 AM
    TSAP
    But I just recently got a new exhaust so that’s why it probably went away
  17. Nov 7, 2018 at 11:27 AM
    bcrooms
    Brandon
    Georgia
  18. Nov 11, 2018 at 3:03 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    My truck started doing this last year after I installed new spark plugs and fuel filter, but it was intermittent and eventually stopped on its own.. I never could identify the cause of it.
  19. Nov 12, 2018 at 8:44 AM
    bcrooms
    Brandon
    Georgia
    Again, I wish it would just go away but it won't. Been this way for quite some time now.
  20. Mar 23, 2019 at 6:30 AM
    Phnguyen7
    Phnguyen7 New Member
    Peter
    2005 Tacoma double cab 4x4
    Did you figure it out? It might just be engine noice coming through the firewall. Check the steering shaft seal. Yours might be toast
