Fly Fishing BS thread
Discussion in 'Boating & Fishing' started by TNDrew, Oct 28, 2012.
  1. Jan 7, 2018 at 3:17 AM
    #4341
    DrFunker
    DrFunker Well-Known Member
    WBF610 and Sig45 like this.
  2. Jan 7, 2018 at 3:46 AM
    #4342
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    While I agree that a LOT of effort is put into these comparisons (I've read several) and a lot of information is provided, I just can't make it through an entire review/comparison anymore. It's just a case of analysis paralysis. I may look at the recommended list and if there's anything in my price point, I may see if I can find one to cast. I'd rather just go to my local fly shop and see which rod suites my casting style for my intended use of the rod (versus reading about what someone suggest I do).
    JJ TACO and DrFunker[QUOTED] like this.
  3. Jan 7, 2018 at 3:49 AM
    #4343
    DrFunker
    Agree. I kind of skim them too. Like you, I find the price point that I can reach and then examine and research from there.
    The great thing about fishing is that what works for one sometimes doesn't work for another. I like that it is truly individualized. That is what keeps us coming back for more, I suppose.
    JJ TACO and Sig45[QUOTED] like this.
  4. Jan 7, 2018 at 3:53 AM
    #4344
    Sig45
    Mark
    Maine
    I fear that fly-fishing gear has gone the way of golf gear....UGH! 99% of people won't/can't tell the difference between a $2000 rod versus a $200 rod (or $300 clubs versus $3000 clubs).
  5. Jan 7, 2018 at 3:58 AM
    #4345
    DrFunker
    Yeah.....
    Coming from a music background - the instrument does not make the musician, but the instrument can make a proficient musician's life a ton easier. That's for sure. :laugh:
  6. Jan 7, 2018 at 5:09 AM
    #4346
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    They are calling for 50* here Friday. I may be sick enough to call off work, but well enough to fish.
    wilcam47, JJ TACO, koditten and 2 others like this.
  7. Jan 7, 2018 at 8:31 AM
    #4347
    JJ TACO
    JJ TACO Well-Known Member
    16 TRD OR DCSB MT QUICKSAND
    You are correct, yet people will keep buying the latest and greatest.
    wilcam47 and Sig45[QUOTED] like this.
  8. Jan 7, 2018 at 11:09 AM
    #4348
    Sig45
    Mark
    Maine
    Is this your first fly rod outfit?
    If so and if you'd only be using it as a fly rod, I think you could do better by piecing an outfit together or buying an entry level outfit from Cabela's, LL Bean or Orvis.
    JJ TACO and truchador like this.
  9. Jan 7, 2018 at 11:15 AM
    #4349
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
  10. Jan 7, 2018 at 11:17 AM
    #4350
    Steves55
    Palm Desert, Ca
    2023 TRD Off Road
    Water I plan to fly fish is small. No real big streams around here. Am I correct assuming I would need a 4/5 wt setup w/ a 7 ft rod or less. Small trout.
    wilcam47 likes this.
  11. Jan 7, 2018 at 11:20 AM
    #4351
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Yes a smaller 4/5wt would be ideal. I use a 4wt, 8’ for small stream fishing.
  12. Jan 7, 2018 at 11:21 AM
    #4352
    Sig45
    Mark
    Maine
  13. Jan 7, 2018 at 11:22 AM
    #4353
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    That would be my choice as well.
  14. Jan 7, 2018 at 11:22 AM
    #4354
    Sig45
    Mark
    Maine
    For water like that...4 Wt is max I'd go with. 3 Wt 7-8 ft would be fantastic.
    la0d0g, wilcam47, truchador and 2 others like this.
  15. Jan 7, 2018 at 11:27 AM
    #4355
    Steves55
    Palm Desert, Ca
    2023 TRD Off Road
  16. Jan 7, 2018 at 11:30 AM
    #4356
    Sig45
    Mark
    Maine
    If you see yourself trying/fishing bigger water....I'd not recommend the 3 Wt. 4 Wt would allow for that.
    koditten, wilcam47 and truchador like this.
  17. Jan 7, 2018 at 11:34 AM
    #4357
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    I use the 4wt, 8’ , small stream, at the lake for blue gills. A little more uses , but a rod for every situation is ideal, but$$$$$.
    Sig45[QUOTED] likes this.
  18. Jan 7, 2018 at 11:34 AM
    #4358
    Steves55
    Palm Desert, Ca
    2023 TRD Off Road
    Another spot. Water clear, lots of leaves from trees, about 10 ft wide here. Fast moving, 50 degrees.IMG_4030.jpg
    JJ TACO, wilcam47 and Sig45 like this.
  19. Jan 7, 2018 at 11:35 AM
    #4359
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    Looks fun, find some deep holes to play in.
    JJ TACO and Sig45 like this.
  20. Jan 7, 2018 at 11:36 AM
    #4360
    Sig45
    Mark
    Maine
    Looks like nice water!
    JJ TACO likes this.
