Fly Fishing BS thread
Discussion in 'Boating & Fishing' started by TNDrew, Oct 28, 2012.
  1. Mar 1, 2020 at 3:36 AM
    #6901
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    That’s a healthy fish :)
  2. Mar 1, 2020 at 3:50 AM
    #6902
    riot4wyatt
    riot4wyatt Well-Known Member
    Travis
    Port Allegany, Pa
    '14 TRD off road spruce mica
    Bilstein 6112/5100 1.5" icon aal Dometic cfx40 fridge
    Thanks man! I might have a replica mount made of it. Just a really nice looking brown!
    surfnmoto2 and truchador[QUOTED] like this.
  3. Mar 1, 2020 at 6:48 AM
    #6903
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Either way. I was going to get out yesterday, but it was too windy still.
    riot4wyatt[QUOTED] likes this.
  4. Mar 4, 2020 at 8:04 AM
    #6904
    mcgov303
    mcgov303 I'd rather be in the mountains
    Denver
    2015 BRM TRD Off Road 4x4
    Toytec 3" w/ AAL, Leer 100R, 16" SCS F5s, 265/75 KO2s, pro grille, cmc
    Any on here use a larger rod box/vault? I just snagged a Denver Outfitters 4 vault and am wondering if anyone has had issues with it interfering with the reception from the shark fin antenna.
  5. Mar 4, 2020 at 9:53 AM
    #6905
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    I have a river quiver 2-banger. No issues at all.
  6. Mar 5, 2020 at 11:58 AM
    #6906
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    I had the Dave Scadden Skykomish Sunrise pontoon, and bought a pump very similar to the Outcast Hurricane Air pump (maybe even the same thing rebranded... it sure looked like that) and it would pump up the pontoons in a few moments. I always had to top it off with a manual pump. Only thing is it's 12 volt so I'd just pop the hood and connect to the battery. Super fast and easy.
    https://www.cabelas.com/product/Outcast-Hurricane-Air-Pump/712139.uts
    tomgru[QUOTED] likes this.
  7. Mar 11, 2020 at 3:50 PM
    #6907
    jaystellato
    jaystellato Well-Known Member
    Bethlehem, PA
    Hey guys. I recently bought an Echo Carbon XL 10' 3wt. What reel/line would you recommend on this for a dedicated nymphing setup? I used an old Redington Drift 3/4 (3.70 oz.) on it, but the whole outfit felt tip heavy. I'm fairly novice to nymphing so I wouldn't require seriously high-end equipment.
  8. Mar 11, 2020 at 10:52 PM
    #6908
    iTzWho
    iTzWho Well-Known Member
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    Sliders By @Yamadirtrider and @Red_Baron 265 65 18 Falken Wildpeak AT/3 on Black Rhino Tanay Morimoto Retrofit Headlights Bilstein 5100 w/OME 885 Dakar AAL Victory 4x4 18" w Tepui Kukenam 3 RTT Tech Deck with iPad and Phone mount Soon to be lighting 4 KC C2 Scene lights 4 KC Cyclones
    Reel doesn't matter as much since you're not going to need a really heavy drag.
    I have an Orvis Recon 10' 3wt and an Orvis Helios 10'6" 3wt
    I use a cheapo deluxe Taylor Flyfishing reel that balances them out fairly well.
    But I plan on getting a Line Q full cage reel, And that's only because i'm normally nymphing with a mono leader setup.
    20 ft 0x Rio Mono, Bloodknot , 15 ft 2x Rio Mono, Bloodknot, Sighter material (Orvis, Hanak, etc), Tippit Ring.
    Then onto the tippit ring is where I match the stream, river, etc.
    Let me know if you need any help.
    steveo27 and Kerbouchard! like this.
  9. Mar 12, 2020 at 7:16 AM
    #6909
    Kerbouchard!
    Englewood, CO
    fishin' tank
    That's all good advice. I agree, the reel doesn't matter a ton. I use about 25 ft of 20lb Maxima Chameleon for my butt section. One thing to consider is that a large arbor reel keeps the mono line for spiraling up as much. It still spirals, for sure, but the large arbor is a little easier to manage. I have an Orvis Hydros SL 2.
    If you want something on the cheaper side but still quality, I'd go for the Orvis Battenkill. It's only $98. Only downsides are that it's a standard arbor and drag isn't sealed. I do a fair amount of fishing in below freezing weather...it'll lock up in those conditions. The Battenkill has a full cage, which will save you a ton of frustration with a tight line setup.
    iTzWho[QUOTED] likes this.
  10. Mar 12, 2020 at 7:36 AM
    #6910
    jaystellato
    Bethlehem, PA
    Thank you this definitely helps. I was looking at the Lamson Liquid as a budget reel. Large arbor, sealed drag, only $100. So you guys are both on full mono setups? Does this mean you're forgoing any kind of fly line, including the euro nymph options from Rio and Airflo? Or backing --> fly line --> 30+ ft. mono --> tippet section? Therefore keeping all your fly line on the reel, and only mono through the guides?
    surfnmoto2, iTzWho[QUOTED] and WBF610 like this.
  11. Mar 12, 2020 at 10:14 AM
    #6911
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Definitely stick with a large arbor. I use use an Orvis Clearwater in my 11 footer.
    98tacoma27 likes this.
  12. Mar 12, 2020 at 3:17 PM
    #6912
    Kerbouchard!
    Englewood, CO
    fishin' tank
    The Lamson will do everything you need, 100%.
    My setup is:
    Backing -->regular WF 5wt fly line --> 25ft 20# Maxima Chameleon --> 3ft 15# Maxima Chameleon --> tippet ring --> Yellow 12Lb amnesia --> Red 8 lb amnesia --> tippet ring --> tippet
    Line to line connections are blood knots. Tippet rings get five turn clinches. All the fly line stays on the reel...unless I hook into fatty and it takes me for a ride.
    I like a tippet ring on top and bottom of my sighter. That allows me to clip off the sighter, tie on some tippet, and use the mono-butt section just like a fly line. I'll do that if I'm mainly tight-lining, but I have some open water where I want to use and indicator. Sounds weird, but it works like a charm.
    If you want to go deep down the mono-rig rabbit hole, go spend some time on Troutbitten.com. There are strategies of using the mono-rig for dries, tight lining, dry flies, streamers, and just about every hybrid style you can think of.
    surfnmoto2 and steveo27 like this.
  13. Mar 12, 2020 at 8:37 PM
    #6913
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    I have the Lamson Liquid on my 11.5’ 8wt switch rod that i use for salmon. It is a great reel for the price. Nice smooth drag, sealed, etc.
  14. Mar 13, 2020 at 4:15 AM
    #6914
    jaystellato
    Bethlehem, PA
    Thanks for the words of wisdom!
  15. Mar 13, 2020 at 4:31 AM
    #6915
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My Battenkill has been dropped in the ocean 3 times. :anonymous:
    I just take the spool off and rinse it with freshwater. The drag still works fine. I can't kill it.
    la0d0g likes this.
  16. Mar 16, 2020 at 8:58 AM
    #6916
    Kerbouchard!
    Englewood, CO
    fishin' tank
    It's spawning season in Colorado
  17. Mar 18, 2020 at 8:34 PM
    #6917
    steveo27
    Pittsburgh
  18. Mar 19, 2020 at 1:02 AM
    #6918
    iTzWho
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    What river?
  19. Mar 19, 2020 at 5:00 AM
    #6919
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    steveo27.....what crick??
  20. Mar 19, 2020 at 5:09 AM
    #6920
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    My preferred method of Social Isolation.
    :thumbsup:
