Fly Wheel Rattle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Dec 8, 2009.
  1. Dec 8, 2009 at 2:20 PM
    BSP4x4
    BSP4x4 [OP] Guest
    Does anyone else get a rattle from their transmission while coasting in N or clutched in and driving over bumps. I think it my be the fly wheel ? thoughts?
    is this normal....can i fix it even if it IS normal?
    Suggestions?
  2. Dec 8, 2009 at 2:22 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    That's not your flywheel. Probably the throw-out bearing
  3. Dec 8, 2009 at 2:26 PM
    BSP4x4
    BSP4x4 [OP] Guest
    why do you say? From the research I've found on here.....if i were having thowout bearing issues i'd be hearing a chirping or squeeling. I get no change in noise whether the clutch is in or out. I DO here noise while in N and hitting a bump, or while the clutch is IN and hitting a bump in the road?
    What should I do?
    I thought i read a thread here that said there is a T/O bearing TSB? BUT i still have not seen a PDF or heard from anyone who has had it done!
    HELP!
  4. Dec 9, 2009 at 5:48 AM
    BSP4x4
    BSP4x4 [OP] Guest
    anyone?
  5. Dec 9, 2009 at 5:55 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    If it were you flywheel vibrating, your engine would be shaking in the bay pretty bad.
  6. Dec 9, 2009 at 6:02 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  7. Dec 9, 2009 at 7:07 AM
    BSP4x4
    BSP4x4 [OP] Guest
    They said "it was normal" :notsure:
    I still don't know why you would think it 's the T/O bearing. I thought that issue had more of a chirping/squealing when pushing the clutch in? My issue only makes noise (rattle) when the front end is disturbed (going over bumps)
    any more thoughts?
  8. Dec 9, 2009 at 7:18 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I only stated that because a vibrating flywheel will do a lot more that just make a noise.
    There is a know issue with the front diff too.
  9. Dec 9, 2009 at 7:27 AM
    BSP4x4
    BSP4x4 [OP] Guest
    Wow! I didn't know that...can you explain or tell me more? Could this be my problem?
  10. Dec 9, 2009 at 7:32 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  11. Dec 9, 2009 at 7:43 AM
    BSP4x4
    BSP4x4 [OP] Guest
    Thanks for the link...just spent a few mins reading and my issue seems different. If anyone else is having this issue, please let me know. Or if you have any ideas feel free to share?
    THANKS!
  12. Dec 9, 2009 at 11:12 AM
    BSP4x4
    BSP4x4 [OP] Guest
    Beuler .....beuler? ANYONE?
