Flywheel access panel or area on Automatic transmission
Discussion in '1st Gen. Tacomas (1995-2004)' started by tercel89, Nov 29, 2016.
  1. Nov 29, 2016 at 7:30 AM
    tercel89
    tercel89 [OP] Well-Known Member
    2003 Tacoma 2.7 4wd
    I am away from my truck but I need to know if there is any type of "access window" or access area to the flywheel so I can put a screw driver in the flywheel teeth to keep the engine from turning. Like I said I am away from my truck at work and it eating me up not knowing this. For reference it's a 2.7 liter with an automatic transmission. Thanks for any help .
  2. Nov 29, 2016 at 11:50 AM
    eon_blue
    Azusa, CA
    FYI if you have an automatic transmission then you have a flexplate, not a flywheel. Flywheels are in manual transmissions
    Not sure about your question though, maybe @gearcruncher can help ya out
  3. Nov 30, 2016 at 4:40 AM
    gearcruncher
    Canadain bumper technician
    If memory serves me correctly , you can not jam the the teeth of the ring gear with a screwdriver in the 2.7 application . Possibly by removing the starter and a using chunk of wood ,but that would be rather archaic .
    I am assuming you are trying to remove some frozen bolts on the front of the engine ?
    Got an impact gun ?
  4. Nov 30, 2016 at 4:49 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    There is a plate. Its small.
  5. Nov 30, 2016 at 5:42 AM
    tercel89
    2003 Tacoma 2.7 4wd
    Yeah , I am trying to re-torque the crankshaft bolt back to spec after putting on a new harmonic balancer . I may end up making a tool to hold the pulley
  6. Nov 30, 2016 at 6:36 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    There is a sticky thread at the top of the forum, Homemade Crank Pulley Tool. The tool I made only requires drilling, no welding. I've used it on other cars after changing the timing belt, so it's paid for itself.
    tercel89[OP] likes this.
  7. Nov 30, 2016 at 3:57 PM
    tercel89
    2003 Tacoma 2.7 4wd
    Did you thread the bolts in the tool into the holes on the harmonic balancer ?
  8. Nov 30, 2016 at 6:14 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
