Flywheel torque spec
Discussion in '1st Gen. Tacomas (1995-2004)' started by ant2man8, Jan 13, 2022.
  1. Jan 13, 2022 at 6:38 AM
    ant2man8
    ant2man8 [OP] New Member
    Anthony
    2001 Toy Tacoma 1Gen. TRD
    I have a 2001 5VZFE TRD 3.4L Supercharged manual Tranny. Replacing my performance Clutch. Anyone know the Torque Specs for Flywheel to Engine Block?
    And I Thank You, for any other info that would be helpful.
  2. Jan 13, 2022 at 6:48 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    I have this from when I did my clutch.
    Trasnmission oil MT90 (redline)
    Oil Capacity 2.35qts
    Washers 2 x 90430-18008
    Clutch pressure plate cover 14 ft-lbs
    Flywheel bolts 61ft-lbs Red Locktite
    Transmission bellhousing to engine: 53 ft-lbs
    Starter mounting bolts: 29 ft-lbs
    Transmission crossmember to frame: 48 ft-lbs
    Transmission mount to transmission housing: 48 ft-lbs
  3. Jan 13, 2022 at 7:00 AM
    ant2man8
    Anthony
    Thank You and love the pics of your trucks.
    Rucas likes this.
