Flywheel upgrade??
Discussion in '1st Gen. Tacomas (1995-2004)' started by LB trd taco, Apr 22, 2017.
  1. Apr 22, 2017 at 11:39 AM
    eon_blue
    Azusa, CA
    He's our resident transmission expert lol. I'm sure he'll have some good advice
  2. Apr 22, 2017 at 11:56 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    My guess is there is no up-grade for the flex plate other than the material it's made from.
    You need an aftermarket converter with a custom stall, if they are available.
    Good luck.
  3. Apr 22, 2017 at 12:07 PM
    LB trd taco
    LB trd taco [OP] Member
    Vincrnt
    Long Beach
    01 Automatic TRD Pre-runner quad-cab
    K&N cold air intake AirRaid throttle body spacer Flowmaster exhaust JBA Headers 2" Front spacer lift
    Ok
    Thank you Ritchie
  4. Apr 22, 2017 at 12:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    You'll only get a replacement flexplate, if one is even needed.
    If you do drop the trans, a rear main seal for the motor is a good idea.
    cruxofthebisquit and Ritchie like this.
  5. Apr 22, 2017 at 12:42 PM
    LB trd taco
    Vincrnt
    Long Beach
    Ok
    So to confirm..
    There are no flexplate "upgrades?" Only flex plate replacement?
  6. Apr 22, 2017 at 1:14 PM
    gearcruncher
    Canadain bumper technician
  7. Apr 22, 2017 at 2:57 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I will give the benefit of the doubt to the transmission guy. If there's a tic and he seems to think it's coming from the flexplate. I'll go with that.
    Your best upgrade (other than the new flexplate, while the trans. is off is in refreshening the trans. New seals, reset bands flush it out well.
    A new torque convt. is probably not warranted unless visual says otherwise.
    As far as upgrade there, a stock (especially truck) engine won't benefit from a high stall converter and factory is prob. as low as you'll find w/o getting one built cutom.
  8. Apr 22, 2017 at 3:10 PM
    LB trd taco
    Vincrnt
    Long Beach
    Excellent info!
    Thank you brother
  9. Apr 22, 2017 at 3:26 PM
    Ritchie
    I disagree for multiple reasons that I'll share.
    I had my A340F rebuilt which included and aftermarket/ OEM style converter. All was good until the converter let go, literally.
    The trans shop pulled everything apart, cleaned and replaced what was need along with another new aftermarket converter.
    The truck was a complete slug, had zero pick up and mpg's went way down.
    After some time, they took my truck in, replaced the converter and it did give it a bit more pick up, but not much.
    My sister-in-law has a great hookup on OEM parts, so I ordered a new converter from Toyota. She also recommended and great trans shop to do the install as I had lost faith in the previous shop.
    The owner hooked up a SnapOn diagnostics machine to the OBDII port and went for a drive. The converter had the wrong rpm stall which was 2100 rpm.
    After the new OEM unit was installed, the truck ran like new. Stall was 2300 and all was good.
    There is a guy on TW that went through many converters and had one made to his setup/ liking. Pricey but worth it to him.
    I must say I have the 3RZ motor and I need all I can get out of this thing... especially after gaining 1300 lbs over stock form.
    Hope this helps you OP.
  10. Apr 22, 2017 at 6:31 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I said stock, you said stock. No disagreement here.
    Yes, heavier vehicles can use a higher speed or re gear.
  11. Apr 23, 2017 at 9:17 AM
    LB trd taco
    Vincrnt
    Long Beach
    At this point my decision is to drop the tranny, and have the flexplate looked over for cracks and broken teeth.
    Likely one or both have occurred and flexplate needs replacement. While the tech is in there, I will request a flush, new rear main seal, and bands if his expertise warrants their replacement.
    I'm going to stay away from a custom torque converter for now because I feel I will get the power I'm looking for with a supercharger.
    Are any of you running a high flow catalytic converter ? What are your thoughts ?
    Thank you for eveyones input.
