FLYZEYE Designs Engineered Lighting 4 Tacoma
Discussion in 'Flyzeye Designs' started by flyzeye designs, Feb 4, 2013.
  1. Nov 22, 2014 at 9:17 AM
    #401
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    So if I get a V2W can I shut it completely off? since it's wired to the interior light?
  2. Nov 22, 2014 at 12:30 PM
    #402
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Yes, it has a 3-position independent switch.
  3. Nov 22, 2014 at 12:42 PM
    #403
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    "Raptor Style" grill mod, aftermarket wheels, 265/75/16 Goodyear Wrangler Authorities, TRD Shoulder pads on seat belts, no mud flaps, AVS Hoodflector bug shield *removed*, Dee Zee Ultrablack Bull Bar w/ license plate mount, dipped my fuel door for no reason, N-Fab Spare tire mount w/ full size matching spare, dipped eyelids onto my headlights for no reason, dipped my hood for no reason
  4. Nov 22, 2014 at 12:44 PM
    #404
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    Thanks, I just placed an order for one.
  5. Dec 11, 2014 at 9:42 AM
    #405
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Any discounts for the holidays?
  6. Dec 12, 2014 at 7:54 AM
    #406
    flyzeye designs
    flyzeye designs [OP] Revised Company Logo
    Darren
    Mesa, AZ
    double-cab long-bed 4X4 debadged TRD Sport
    6 inch lift, tinted windows, custom tail lights, custom Red/White/Red-Black FLYZEYE Designs TCMA-0513 V2W interior light Custom Powder-Coated Devil Horns by Andres
    We are discussing this...
  7. Dec 27, 2014 at 4:36 PM
    #407
    TimberLandTaco
    TimberLandTaco Well-Known Member
    Mason
    Northeast Oklahoma
    2012 Timberland Mica TRD Offroad
    Light, Bumpers, and lots of switches.
    Hey. You should make a light that runs the normal dim but make it to when the door opens the LEDs go to full power with the dome light
  8. Dec 27, 2014 at 8:34 PM
    #408
    robssol
    Rob
    S. Wisconsin
    That could be done. The added cost would probably make it prohibitive.:notsure:
  9. Jan 5, 2015 at 9:53 PM
    #409
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    So this runs standalone on batteries OR can be hardwired in?
    And its dim-able?
  10. Jan 5, 2015 at 11:34 PM
    #410
    flyzeye designs
    Darren
    Mesa, AZ
    The V2W is primarily powered by wiring in the mounting plate to the Tacoma dimmer / lighting circuit. When dismounted, the unit automatically switches to onboard batteries and then back to truck power when re-mounted. ;)
    The V1 unit is a battery-powered unit - it must be controlled (OFF-Primary-Secondary) via a 3-position slide switch.
    BOTH the V1 and V2W are dimmable. The V2W is controlled primarily thru the Tacoma dimmer. The V1, thru the onboard touch-sensitive contacts.
    The V2W, although having the same contacts, does NOT function the same. It will dim as the V1 when dismounted but, it WILL have problems if you try to dim the unit using the touch contacts less than 100%.
    To adjust the V2W, set the Tacoma dimmer up to 100% bright...
    Then, adjust the TSDC (Touch-Sensitive Dimming Control) to the desired output.
    When the Tacoma is dimmed, the V2W will follow accordingly.
    IF you have questions, concerns, please call, PM, or email us for further explanation.
    Hope this helps. :confused:
  11. Jan 5, 2015 at 11:41 PM
    #411
    AR15xAR10
    Oh it more than helped! Thank you. :thumbsup:
    Sounds like the battery powered V1 dash model is more up my alley.....
    I will continue reading up on the website :cool:
  12. Jan 16, 2015 at 7:27 PM
    #412
    flyzeye designs
    Darren
    Mesa, AZ
    All, as the 2016 Tacoma will be considerably different from all previous models, our V1 and V2W LED console lighting will NOT fit.
    Based on current stock, cost of manufacturing, and business needs, we will NOT restock the V1 and V2W materials - Once they're gone, they're gone.
    With that in mind, prices will begin to creep UP as demand will exceed supply.
    We do not know exactly how the pricing will be calculated but, expect significantly higher prices as the units run out.
    At this time, we are expecting to run out by mid 2015. Demand will obvious affect this.
    If you have been considering a V1 or V2W, please do not wait until it's too late. We will NOT be able to produce more units once the cases are gone.
    If you have questions, please contact me.
  13. Jan 16, 2015 at 7:28 PM
    #413
    AR15xAR10
    So which one is battery only? V1? Right?
  14. Jan 16, 2015 at 7:30 PM
    #414
    flyzeye designs
    Darren
    Mesa, AZ
  15. Jan 16, 2015 at 7:34 PM
    #415
    AR15xAR10
  16. Jan 16, 2015 at 7:37 PM
    #416
    flyzeye designs
    Darren
    Mesa, AZ
    NOT a silly question - if you don't know, you don't know. We don't expect everyone to know everything about our products. ;)
  17. Jan 16, 2015 at 7:40 PM
    #417
    andlours
    andlours Well-Known Member
    Andy
    Denver, CO
    09 TRD Offroad
    I ordered one of the V2s. Is there anyway to change out the LED color?
  18. Jan 16, 2015 at 7:50 PM
    #418
    flyzeye designs
    Darren
    Mesa, AZ
    Unfortunately, no. But, being a customer, we could build you a second unit for a discounted price (see PM) and not ship the mounting plate.
    Thoughts?
  19. Jan 16, 2015 at 8:13 PM
    #419
    Ranzid
    Ranzid Member
    Nashville, TN
    2008 Tacoma TRD off-road Access Cab
    How do these work when you have to remove the head unit? It seems like it would be in the way slightly. Other than that I am ready to order.
  20. Jan 16, 2015 at 8:17 PM
    #420
    flyzeye designs
    Darren
    Mesa, AZ
    On the 2005-2011 models, the mounting plate offers only slight interference. On the 2012+ models, the mounting plate does offer some interference but, if done carefully, you can remove the HVAC panel.
