FLYZEYE v2w center console LED asssembly red/white
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 2006KJ, Jul 10, 2018.
  1. Jul 10, 2018 at 6:01 PM
    2006KJ
    2006KJ [OP] Well-Known Member
    Front Royal VA
    SOLD
    $50 shipped to lower 48. Selling my flyzeye center console LED assembly that I bought for my 2012 Tacoma. It has Red/White LED’s and white HALOs for the touch sense dim/bright adjustments. White to match the OEM interior and my LED map lights, Red to preserve your Tacticool night vision (but really it doesn’t kill your eyes at night). This unit is very well built and fit flawlessly in my truck. Removed to install a TechDeck for RAM mounts. It may work in the 05-2011 Tacoma’s also. Easy to install and optional hook up to the dimmer circuit is easily accessible right behind the HVAC controls (good instructions available on FLYZEYE website). When connected to dimmer circuit the LED’s come on whenever interior lights are on and dim/brighten with the interior lights. This unit installs right below the radio, above the HVAC. Lights up the consol perfectly and is very OEM in quality. It can also be removed from the magnetic mount and used as a flashlight via battery power.
    UPDATE.
    I just got off the phone with flyzeye. The unit itself is exactly the same for the 05-2015 Tacoma’s just the install is a little different. I believe the 05-2011 just hooks into different wires than the 2012+. Here is a link to the installation for the 05-2011
    http://www.flyzeye-designs.com/v2w_0511.html
    The directions are the photos outlined by the blue box toward the top of that webpage.
    Here is a link to the installation for the 2012+ 2nd gens
    http://www.flyzeye-designs.com/v2w_1214.html
    The directions are the photos outlined by the blue bo toward the top of that webpage.
    CBE86E0B-DE06-432E-958B-4C1484A3216C.jpg 41788812-14A3-4589-A932-58CF01EFF89E.jpg E01AA8B1-445D-43C8-AFDB-9262D24D40A5.jpg 0F4906FA-47F4-4EA7-A3E5-42C4D0A9D6D0.jpg EF18EC07-19D5-4B70-B71D-73488CE95050.jpg 28616851-46FB-4A68-82E8-E0BBF1B54A2B.jpg
    Here are a few helpful links.
    https://www.tacomaworld.com/threads/flyzeye-designs-tcma-0511-v1-led-light.155960/
    DirtJumper14, Slashaar and ChadsPride like this.
  2. Jul 10, 2018 at 6:04 PM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    how does this install? just need power and ground? or
  3. Jul 10, 2018 at 6:10 PM
    2006KJ
    Front Royal VA
    They had good install instructions on their website. In a nut shell you pull out the HVAC controls (literally just pull out its in there with 4 plastic slip clips) and use the wire crimp connectors to attach it to two wires coming out of the plug for the HVAC controls. I assume one is a power and the other is a ground. Not sure which one is part of the dimmer circuit. It mounts to the truck with thin double side tape. You could also just use it on battery power i guess.. the LED’s have so little draw. But you’d have to turn it on every time you wanted it lit. I had it on the dimmer circuit so it was always on with the interior lights.
  4. Jul 10, 2018 at 6:15 PM
    2006KJ
    Front Royal VA
    I dont see the install on their website. I sent them an email requesting them and to see if it will fit a 05-2011 (it should).
  5. Jul 10, 2018 at 6:27 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    This is a excellent product. I have it installed in my 08. Easy install, I recommend wiring it in instead of using the batteries. $50 shipped is a very good price.
    GLWTS.
    2006KJ[OP] likes this.
  6. Jul 10, 2018 at 11:59 PM
    NOLAtaco26
    NOLAtaco26 Well-Known Member
    Blake
    New Orleans,Louisiana
    2013 Double Cab Prerunner 2.7
    If you look in the picture it says its for an 05-11 Tacoma on the bottom side of the light
  7. Jul 11, 2018 at 4:00 AM
    NOLAtaco26
    Blake
    I'm interested if it will fit my 13
  8. Jul 11, 2018 at 4:30 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Have had this since they came out in silver and in black. Also have the glovebox/console ones in all my cars. Great product. GLWS...................
  9. Jul 11, 2018 at 5:21 AM
    2006KJ
    Front Royal VA
    It will def fit your 2013. I had it in my 2012 and they are identical.
  10. Jul 11, 2018 at 11:23 AM
    2006KJ
    Front Royal VA
    UPDATE.
  11. Jul 11, 2018 at 1:59 PM
    2006KJ
    Front Royal VA
    SALE PENDING with NOLAtaco26
  12. Jul 11, 2018 at 2:02 PM
    2006KJ
    Front Royal VA
  13. Jul 11, 2018 at 3:11 PM
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    Damn, pretty cool product. Might have to get this!
  14. Jul 14, 2018 at 7:25 AM
    Aldizzle13
    Aldizzle13 Well-Known Member
    Bay Area
    2012 Tacoma TRD Sport 4x4
    I just bought a kit $95 bucks :spending:
    thanks to TacomaWorld I'm never paying off my Credit Card :sadviolin:
