FN FX Pro wheels
Discussion in 'Wheels & Tires' started by TacoMafia, Jan 1, 2016.
  1. Apr 19, 2016 at 6:14 AM
    #301
    SidZer0
    SidZer0 Well-Known Member
    NE FL
    2019 Cavalry Blue TRD Sport 4x4
    16×8 FNW / Konig Countersteer Type X 265/75/16 KO2's
    @13txtaco you'll need to call Dustin @ FN for pricing and availability.
    Here's the specs:
    FN Wheels ƒ(x) Pro
    Diameter: 17"
    Width: 8"
    Offset: 0mm
    Backspacing: 4.5"
    Load rating: 955KG (2,100lbs+)
    Weight: 24lbs (approximate) (vs. 27lbs + for the OE wheel)
    Certification: JWL-T, VIA, SAE J-2530, DOT approved
    Colors: Matte gunmetal, dark gloss gunmetal, matte black and matte bronze
    Toyota specifics: 106mm hub centric for Toyota hubs, lug holes drilled for 12mm Toyota wheel studs for a snug fit, and center machined to accept flat snap-in OE center cap* (not the raised OE Pro cap).
    Positronik likes this.
  2. Apr 19, 2016 at 6:34 AM
    #302
    Witte
    Witte Well-Known Member
    Cory
    Joplin, MO
    2016 TRD OR - Inferno Orange
    Custom Tacoma Decals, Custom TRD Decals, Dipped Grill, OPT7 LED Low Beams, OPT7 LED Foglights, Tailgate Pop & Lock, 15% Window Tint
    FN Wheels ƒ(x) Pro
    Diameter: 17"
    Width: 8"
    Offset: 0mm
    Backspacing: 4.5"
    Weight: 23.88lbs (approximate)
    Toyota specifics: 106mm hub centric for Toyota hubs, lug holes drilled for 12mm Toyota wheel studs for a snug fit on all 6x139.7 Toyota hubs.
    Naveronski likes this.
  3. Apr 19, 2016 at 7:02 AM
    #303
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    Thanks for the details.
  4. Apr 19, 2016 at 8:46 AM
    #304
    007TRUCK
    007TRUCK Well-Known Member
    Is that factory suspension? No lifts?
    And wow be frank with 0 shame i wanna say that I just may copy the flag look! Where did ya buy it?
    More pics of the truck pretty pls!
  5. Apr 19, 2016 at 12:00 PM
    #305
    jhawkoma
    jhawkoma Active Member
    2016 TRD Off Road/2009 Prerunner/1997 4x4 V6
  6. Apr 19, 2016 at 1:27 PM
    #306
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Suspension is Fox 2.5 front coilovers(about ~3" total lift)
    Rears are Fox 2.0 with 3Leaf progressive (added ~1.5")
    Subdued flag I got here; http://www.ebay.com/itm/Subdued-Ame...ash=item464c34a000:g:8n8AAOSwZd1Vap6l&vxp=mtr
  7. Apr 20, 2016 at 3:23 AM
    #307
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
    I ordered my wheels last night. Now I'm wondering if I should have ordered a fifth for a spare. My thinking is they use a different lug nut and if I didn't it might cause a problem if someone down the line if someone tries to use the FN FX lug nuts on my factory spare.
    Any opinions?
    Will this wheel fit in the spot for the spare tire?
  8. Apr 20, 2016 at 8:49 PM
    #308
    illusivema70
    illusivema70 Well-Known Member
    4xSlow
    Las Vegas
    15 MGM D-cab TRD Offroad 4x4
    Stage 6 Icon Suspension With CDC, Total Chaos upper control arms, All-pro expedition leaf packs, All-Pro extreme-duty APEX sliders, Pelfreybilt front aluminum bumper with full skid set, CBI rear bumper with tire carrier, CBI bed rack and CVT Mt. Shasta tent. 285/75/17 Nitto Trail , Mcneil Racing +2 Fiberglass fenders
    it should fit under the truck no problem, you can also carry 6 lugnuts for the factory wheel....your call.
  9. Apr 20, 2016 at 9:07 PM
    #309
    RedbirdsTaco
    RedbirdsTaco Well-Known Member
    Tyler
    SW MO
    2016 MGM SR AC MT
    Black Reflective Vinyl Tailgate Inserts Intermittent Wiper Mod Inferno Vinyl Glove Box Inserts SR LED Fog Light Mod Custom St. Louis Cardinals Bedside Decal Clazzio Leather Seat Covers
    Be cheaper to just throw six lugs in a plastic bag and keep them next to the jack or in the glove box so you can use with spare.
  10. Apr 21, 2016 at 4:11 PM
    #310
    SSM Taco
    SSM Taco Well-Known Member
    Mesa, Arizona
    2016 SR5 4x4 DCSB
    Overland Bound #4340
    Hey I have done some searching and I was curious what the part number is for the Silver TRD Pro Center Caps? I want to make sure I am ordering the right size to fit the FN Pro 17x8 Wheels!
    Not sure if it is: PTR18-35092 or PTR45-34071?
  11. Apr 21, 2016 at 4:50 PM
    #311
    MESO
    State of Jefferson
    ^ Mine were PTR18-35092
    TacoTodd78 and TacoMafia[OP] like this.
  12. Apr 21, 2016 at 5:32 PM
    #312
    SSM Taco
    Mesa, Arizona
    2016 SR5 4x4 DCSB
    Perfect, thanks!
  13. Apr 23, 2016 at 4:51 AM
    #313
    JoeyDel
    Joe
    South Jersey
    I have a question about lug nuts on these wheels. I was fairly certain Dustin mentioned the stock Tacoma lug nuts won't work with these wheels but I see people using stock ones. Which is it? I ordered black but now I kind of like the chrome nuts with the TRD center a little better. Can I use the stock nuts?
  14. Apr 23, 2016 at 10:08 AM
    #314
    SSM Taco
    Mesa, Arizona
    2016 SR5 4x4 DCSB
    To my knowledge they have to be spline lug nuts to work due to the dimensions of the wheel where the lugs are inserted. You can order a set of chrome spline nuts through Dustin instead of the black!
  15. Apr 25, 2016 at 7:37 AM
    #315
    neoflex
    neoflex Well-Known Member
    Anyone have a photo of these on an '16 Inferno TD Sport?
  16. Apr 27, 2016 at 10:44 PM
    #316
    illusivema70
    4xSlow
    Las Vegas
  17. May 4, 2016 at 12:27 PM
    #317
    Damage Inc
    Damage Inc Well-Known Member
    Ian
    Maple Ridge, BC
    2016 Magnetic Grey TRD
    Ironman Foam Cell lift kit, BakFlip G2, DIY Tailgate remote lock.
    Could anyone advise if these look like legit FN FX Pro wheels? Looking at internet 2nd hand purchase and there are just a couple red-flags. Main one is the center caps look OEM raise which according to Dustin's description should not fit. Also the box does not look quite right...?
    61ragtop likes this.
  18. May 4, 2016 at 12:37 PM
    #318
    SSM Taco
    Mesa, Arizona
    2016 SR5 4x4 DCSB
    I just got a set from Dustin a week or so ago and are currently waiting to be installed. I snapped a picture of the box and wheel itself. Like you said the wheels from Dustin don't have a raised center cap and the box looks different as well on mine.
    SilverII likes this.
  19. May 4, 2016 at 12:50 PM
    #319
    Damage Inc
    Ian
    Maple Ridge, BC
    Thanks for the quick response.
    Maybe these are a knock off of the FN FXs?
  20. May 4, 2016 at 12:52 PM
    #320
    JoeyDel
    Joe
    South Jersey
    These look like the one I got last week also, those others @Damage Inc posted look like fake FN FX Pro, TRD Pro wannabes.
