FN FX Pro wheels
Discussion in 'Wheels & Tires' started by TacoMafia, Jan 1, 2016.
  1. May 12, 2016 at 7:34 PM
    #341
    BigRed42
    BigRed42 Well-Known Member
    Cody
    Texas
    2017 INFERNO DCSPORT
    Here's a closer up pic, I had to edit and I think it's best I can get. Thanks!
  2. May 14, 2016 at 8:45 AM
    #342
    TRD4WD
    TRD4WD Supreme Leader
    Micah
    Gonzales, LA
    2004 Double Cab TRD
    Do you have a direct side profile picture?
  3. May 14, 2016 at 8:49 AM
    #343
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I don't sell them. If you want a price call Kyle at Cochrane Toyota in parts. He is a Canadian dealer for FN.
    Mine were defects (they look perfect, I can't find the defects lol) so I paid a lot less than most people.
  4. May 14, 2016 at 9:50 AM
    #344
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
    Dustin hooked me up with a defect to use as a spare at a steep discount. It had a slight scrape inside the hub that was not visible if it was mounted. I hit it with some flat black rattle can before hoisting it up under the truck. I would not have hesitated using it as a main wheel.
    I wanted it as a spare in case someone else got a flat and didn't know to use different lug nuts on the stock spare.
  5. May 14, 2016 at 10:38 AM
    #345
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yeah, Kyle at Cochrane Toyota had a whole set of defects but honestly I couldn't find a single thing wrong with them. I snagged them for under 1K CAD including sales tax. I honestly couldn't find anything wrong with them and now that I've wheeled them lots I've made enough of my own scratches that any that might of been there are well hidden.
  6. May 14, 2016 at 10:51 PM
    #346
    shadowkhan
    shadowkhan Well-Known Member
    2016 Barcelona Red TRD Sport 4x4 Prem/Tech w/JBL DCSB
    SilverII and Hankstone like this.
  7. May 15, 2016 at 1:12 PM
    #347
    jeffreywanderson9
    jeffreywanderson9 Well-Known Member
    Jeff
    Portland Oregon
    2016 TRD OR DCLB Super White
    OME w/ dakars, Method NV 17", 275/70/17 Cooper AT3
    So whats the difference between these wheels and the 4 runner TRD wheels besides one being 7 inches and the other 8 inches?
  8. May 15, 2016 at 1:16 PM
    #348
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    ^ different color options, flat center cap(plain or TRD), and wider
  9. May 15, 2016 at 1:22 PM
    #349
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    The offset and width are the biggest differences. These wheels sit a bit farther out to help clear the UCA's when lifted and they are wider allowing you to run wider tires if you want. I have them paired with 255's though and the tread is still a bit wider so there is lots of versatility.
    Bottom line, if you are going for looks on a truck that will never see the trail there isn't much difference between these and what TRD makes. If you want to wheel on them though these have several notable advantages.
  10. May 23, 2016 at 10:17 AM
    #350
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Anyone have an update on prices and shipping times?
    Is it still "call to order only"?
  11. May 24, 2016 at 11:11 PM
    #351
    Mat1hew
    Mat1hew Member
    Matthew
    2016 Quicksand Tacoma TRD Sport 4x4
    @JoeyDel Nice setup, eventually I'm going to be doing the exact same thing you have done with the rims and tires. Have you encountered any problems with rubbing on the front air dam yet?
  12. May 25, 2016 at 12:23 AM
    #352
    niko5055
    niko5055 Well-Known Member
    24 Underground Sport Premium 4x4
    I called yesterday and they said early to mid next week
  13. May 25, 2016 at 6:33 AM
    #353
    JoeyDel
    Joe
    South Jersey
    Nothing rubs on the front air dam but they did have a slight rub on the mud flaps, it did look minor but I hadn't done any close to aggressive driving yet so I took some others advise and got some RokBlokz which took care of that problem. I could have modified the stock guards but like the look of the RokBlokz better, plus they are a custom fit. I also have read Plasticolor will work also.
    Honestly the reason I think people report no rubbing on the stock mud guards is because it is so minor. Some might not even notice it. I heard an intimal rub on the drivers side the first time it happened then never heard it again. I never heard a rub on the passenger side but when I took them off there were rub marks.
  14. May 26, 2016 at 7:19 PM
    #354
    Otis1382
    Otis1382 Well-Known Member
    warren
    Chelsea Al
    '16 DCOR 4x4 quicksand
    which stock wheels are 32 lbs?
  15. May 26, 2016 at 8:47 PM
    #355
    Tacohotshot
    Tacohotshot Well-Known Member
    Love the wheel and ko2s great choice
  16. May 27, 2016 at 1:54 AM
    #356
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Did the tpms modules transfer over ok with these wheels? tire shop I spoke with
    said they need a small "kit" with a couple washers/nuts to secure them in the new wheels.
  17. May 27, 2016 at 10:18 AM
    #357
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    Stock 16's on the TRD Off Road model are 32 lbs? whooaaa... please confirm.
    Otis1382 likes this.
  18. May 27, 2016 at 12:49 PM
    #358
    Otis1382
    warren
    Chelsea Al
    That's my question. Asked on 2 different threads so far. Haven't heard an answer
  19. May 27, 2016 at 1:04 PM
    #359
    Otis1382
    warren
    Chelsea Al
    This guy says 24lbs
  20. May 27, 2016 at 1:43 PM
    #360
    Hellapeno
    Austin
    2016 TRDOR
    Choice Goodies
    Sounds more like it. You'd think someone could just stand on a scale with one of these...
