FN FX Pro wheels
Discussion in 'Wheels & Tires' started by TacoMafia, Jan 1, 2016.
  1. Jan 6, 2017 at 7:11 AM
    #661
    Roundarc
    Roundarc Born again Tacoma Owner
    Allan
    Virginia
    2025 TRD Sport Premium
    From left to right: Matte Black, Dark Gloss Gunmetal, Light Matte Gunmetal.
    Here's a side view of the Matte Light Gunmetal mounted up.
  2. Jan 6, 2017 at 3:07 PM
    #662
    Cowpoke
    Cowpoke Active Member
    Owasso, OK
    '17 TRD OR (Inferno)
    Can the center caps be swapped out without removing the tire?
  3. Jan 6, 2017 at 3:17 PM
    #663
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
    There may be a way but I was told by Dustin that the wheel needs to be taken off to switch the center caps. I bought both styles because I wasn't sure what direction I was going.
  4. Jan 6, 2017 at 3:19 PM
    #664
    Cowpoke
    Owasso, OK
    Thanks, I was going to buy both as well, was hoping I could just pop one out and stick the other in as I please ;-)
  5. Jan 6, 2017 at 3:58 PM
    #665
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    265/70r17 toyo open country at2s. 100% stock no lift no problems...
    I did the rough math for the inertia. With the wheels being lighter than stock, the toyos were as well. But the overall size being taller and wider ends up being a 3 percent increase. This a simplification with a few assumptions. I put these on with 16 miles on the truck so I won't be able to compare to stock, but I did the speedo recal so we shall see how the mpg is. With only a 3 percent increase in the inertia, I would guess it's still gonna be pretty good
    Jaggerbub, arnette64 and 61ragtop like this.
  6. Jan 6, 2017 at 4:40 PM
    #666
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    It's definitely possible, but the risk of either ruining the paint, or even the cap itself would be too great.
  7. Jan 6, 2017 at 4:51 PM
    #667
    Roundarc
    Allan
    Virginia
    Why not get the TRD caps and cover them in 3M film? Lots of colors to choose from - even carbon fiber if you want. Peel them off when you want to change over and make a template for the future.
    Biscuits likes this.
  8. Jan 6, 2017 at 7:34 PM
    #668
    Cowpoke
    Owasso, OK
    Thats a good point.
  9. Jan 6, 2017 at 9:42 PM
    #669
    61ragtop
    61ragtop Well-Known Member
    They look a lot darker on the truck than off of it!!
  10. Jan 7, 2017 at 5:20 AM
    #670
    Roundarc
    Allan
    Virginia
    It really depends on the lighting. This was taken near sunset. The color is just a little lighter than MGM.
    61ragtop[QUOTED] likes this.
  11. Jan 9, 2017 at 2:58 AM
    #671
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    yup it depends on lighting. certain angles too. hard to capture them in pics, they stand out nicely against mgm.
  12. Jan 9, 2017 at 6:36 AM
    #672
    6172crew
    6172crew Well-Known Member
    New Mexico
    4X4 TRD sport
    I did a check on the MPH using the signed on the freeways and saw no change or actually I see it right on the money using the same wheel, and same sized LTX defender tire. The wider wheel might pull the tire down a little. I did a fuel up and math read on the truck and found it almost the same as the dash board which was around 17mpg. My response to your post is only giving others info when deciding to change the stock wheels or tires.
  13. Jan 9, 2017 at 7:08 AM
    #673
    roth_nj
    my first tank was right on the money too before installing the calibrator. (not enough since yet)
    im going to guess that the 1 inch taller tires essentially made up for the difference on how the stock set up reads slightly slower
  14. Jan 9, 2017 at 10:04 AM
    #674
    thechadd3
    thechadd3 Well-Known Member
    16 Inferno DCSB MT TRD Sport
    34x10.5 KO2s LR UCAs and Toytec Boss
    SilverII and Biscuits like this.
  15. Jan 9, 2017 at 8:48 PM
    #675
    61ragtop
    Gloss Dark Gunmetal? I don't think there is a gloss black after Talking to Dustin today.....
  16. Jan 9, 2017 at 11:04 PM
    #676
    AngryOscar
    AngryOscar Well-Known Member
    Ben
    Sumter SC
    2016 Silver Tacoma TRD OR Manual
    34x10.50 aye? Any rub? Looks good.
  17. Jan 10, 2017 at 6:52 AM
    #677
    6172crew
    New Mexico
    4X4 TRD sport
    I just filled up and so far this tank is showing 14.2 avg lol. Maybe the tire and wheel combo really wacked the system out.
  18. Jan 10, 2017 at 7:17 AM
    #678
    roth_nj
    my first tank was 18.2 before the speedo recal. but that was with the tank from the dealer. I like to do the fill to click/trip meter reset to figure it out.
    given the cold/warming up time/use of 4 wheel drive for the tank, i probably would have been around 17.5 on my 2nd gen. so to be just higher with these rims/tires under these conditions... ill take it. with warmer temps/summer blend gas, it should end up around 23-24 mpg. i usually averaged around 21-22 on all my 2nd gens
  19. Jan 10, 2017 at 2:45 PM
    #679
    Silver taco 09
    Silver taco 09 Well-Known Member
    2009 silver Tacoma
    Can anyone post a picture of the blems if you bought one as a spare ?
  20. Jan 10, 2017 at 2:52 PM
    #680
    JoeyDel
    Joe
    South Jersey
    Not sure it will help you seeing other blemishes since they can be random. Mine was a mark inside the hub and could have been used as regular wheel and no one would have ever seen the blemish.
    Maybe Dustin can give some more insight on the particular wheel he is sending?
