FN FX Pro wheels
Discussion in 'Wheels & Tires' started by TacoMafia, Jan 1, 2016.
  1. Sep 20, 2017 at 10:03 AM
    #1121
    oh crap its him
    oh crap its him Well-Known Member
    Shannon
    OH->SLC,UT->SA,TX
    09 TRD OR
    Lift, Wheels, Lights
    Ha same issue here! Got them all done, and something looked...off. Realized I centered the R in TRD instead of the T and the D so they sit higher than center. Should have referenced the oem center caps before I started. Sigh. Ordered a new set to redo them.
    These are the decals I'm using and they look awesome (other than being centered wrong). I'll post pics once I get them finished.
    http://www.importequipment.com/OnlineStore/product_info.php?cPath=45_27_28&products_id=322
    TRDOBSESSED likes this.
  2. Sep 20, 2017 at 5:10 PM
    #1122
    TRDOBSESSED
    TRDOBSESSED Well-Known Member
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    i just put these on a few days ago...easy and look good.
  3. Sep 28, 2017 at 6:12 AM
    #1123
    mopar2
    mopar2 Well-Known Member
    Franklin TN
    Anyone have the lug nut torque for this wheel?
  4. Sep 28, 2017 at 6:22 AM
    #1124
    TRDOBSESSED
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    pretty sure it's 80...that's what i used
  5. Sep 28, 2017 at 1:52 PM
    #1125
    Pawnstar23
    Pawnstar23 Active Member
    Pawn
    Does anyone have these wheels on a blazing blue tacoma?
  6. Sep 28, 2017 at 2:15 PM
    #1126
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    Here and Here
    Pawnstar23[QUOTED] likes this.
  7. Oct 2, 2017 at 8:54 AM
    #1127
    HOOPSboy
    HOOPSboy Well-Known Member
    Houston TX
    Trying to decide between the bronze or matte gunmetal for my gen 1 double cab in red. Will be mounted on 285/70/17 ATs!
  8. Oct 3, 2017 at 11:03 AM
    #1128
    itsraymondang
    itsraymondang Spam King
    Houston, TX
    2017 White TRD Sport DCSB
    Getting mine installed right now!
    265/70 on 17x8 +0
    No rubbing/clearance?
    BlakeM[QUOTED] likes this.
  9. Oct 3, 2017 at 2:19 PM
    #1129
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    Should be fine even on stock height. At most some rubbing of mudflaps.
  10. Oct 4, 2017 at 11:50 AM
    #1130
    itsraymondang
    Houston, TX
    Anyone here mount them with wheel locks? I cannot find a size that'll fit these small lug holes.
  11. Oct 6, 2017 at 10:49 AM
    #1131
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    We recommend McGard 25357 (black) or 25257 (chrome) "tuner" wheel locks. They use a small diameter key that fits perfectly.
    http://mcgard.com/index.php/automot...4-locks-and-1-key&Itemid=0&category_pathway=0
    Gorilla also makes small diameter wheel locks that fit well with our wheels:
    http://www.gorilla-auto.com/small-diameter-locks
    More than a good set of wheel locks I would suggest a good alarm for your truck. The alarm on my truck is sensitive enough that it will go off before I can even finish undoing the lug nuts if I don't leave the keys in the ignition or one of the doors propped open slightly.
    SAR Taco and seoulja99 like this.
  12. Oct 6, 2017 at 11:34 AM
    #1132
    JdMeF9SiR2
    Corona, CA
    Thanks for going with our wheels @Brenden J. Part of the difference you'll notice will be from the slight (approximately 3%) increase in overall diameter and part will be due to the increase in weight. The E-Rated (10 ply) BFG KO2 is likely going to be way overkill in terms of what you need on a light truck such as the Tacoma. The C-Rated (6 ply) would be much more appropriate for the majority of Tacoma owners.
    With that said, I highly suggest looking into the Toyo Open Country AT-II in P265/70R17 if the truck is primarily street driven. This is still a very capable all-terrain tire, it has a great looking tread pattern and sidewall design, the quality of construction is excellent (they balance out very well, especially compared to the BFG KO2), and the weight in P265/70R17 is only 41lbs per tire. I use them on three of the FN Wheels trucks, and I am not sponsored by Toyo Tires.
    https://www.toyotires.com/tire/pattern/open-country-at-ii-on-off-road-all-terrain-tires
    jmauvais, OCPaisa, Coolerman and 3 others like this.
  13. Oct 6, 2017 at 11:39 AM
    #1133
    JdMeF9SiR2
    Corona, CA
    The OEM TRD caps with part # PTR18-35092 fit. This is the alloy background cap with red TRD logo.
    OEM black or OEM gunmetal TRD caps from the 4Runner Pro OE 17x7" wheels do not fit the FX Pro.
    We elected to use a flat center cap in our wheel to give (what we feel to be) a cleaner look to the wheel vs. the raised, hollow dome, plastic OEM cap that comes with the 4Runner OE wheels. Our caps are interchangeable with the PTR18-35092 caps (as I already mentioned).
    We offer plain color matched caps for all colors other than bright metallic silver (bright metallic silver was a special production run, and we include alloy or black background caps with bright metallic silver).
  14. Oct 6, 2017 at 12:09 PM
    #1134
    JdMeF9SiR2
    Corona, CA
    OEM TRD 4Runner Pro wheels (PTR20-35110BK and PTR20-35110GM) have the following specs:
    Diameter: 17"
    Width: 7"
    Offset: +4mm
    Backspacing: 4.15" backspacing
    FN Wheels FX Pro wheels have the following specs:
    Diameter: 17"
    Width: 8"
    Offset: 0mm
    Backspacing: 4.5"
    For reference, OEM Tacoma TRD Sport 17" wheels are 7.5" wide. OEM 4Runner Trail Edition wheels are 7.5" wide. Most/all OEM FJ Cruiser wheels are 7.5" wheels.
    OEM Tacoma TRD Sport (2005 ~ Present 2018) tires are 265/65R17. This tire size requires a minimum rim width of 7.5", meaning that the 4Runner Pro 7"wide wheels are too narrow to be safely installed. You can of course physically install the tire onto a 7" wheel, but it won't be safe, and the tire manufacturers have not approved it.
    The most popular tire size for the majority of lifted Tacomas, 4Runners and FJ Cruisers that have 17" wheels is 285/70R17. 285/70R17 also requires a minimum rim width of 7.5". As is the case with 265/65R17 tires, this means that the OEM 4Runner Pro wheels will be too narrow to be safely installed.
    The OEM 4Runner Pro wheels more or less limit you to a few tire sizes: 265/70R17, 275/70R17 (and a few less common sizes such as 255/75R17 and 255/80R17).
    The 17x8" FX Pro allows you to safely install any of these popular tire sizes: 265/65R17, 265/70R17, 275/70R17, 285/70R17, 295/70R17, 305/70R17, 255/75R17, 285/75R17, 255/80R17, etc.
    The last part of your question asked about colors. The OEM TRD 4Runner Pro wheels come in two finishes - flat black and flat gunmetal. It has been our observation and experience that the OEM clear coat is VERY flat and porous. This finish looks good when it is new, out of the box. Our experience has been that these very flat clear coats tend to absorb a lot of chemicals, oil, dirt, grim, etc. from driving, and that extremely flat clear coats are usually more difficult to keep clean.
    We offer the FX Pro wheels in multiple finishes: bright silver metallic (gloss), dark high gloss gunmetal, matte black, matte bronze, and matte gunmetal. We offer these colors so that our customers can choose from a broad spectrum to compliment the color of their vehicle. We also offer the two high gloss finishes for customers that would like easier / lower maintenance finishes. Furthermore, our matte wheels have a satin-matte clear coat, which is not shiny or reflective, but is not as flat as the OEM wheels. This makes even the matte clear coated wheels a little bit easier to clean when compared to a full-flat clear coat of the OEM 4Runner Pro wheels.
    In terms of design the FX Pro was inspired by the OEM wheels with a few subtle changes that we felt improved the looks of the wheel. The FX Pro uses a flat center cap in stead of a raised dome cap, the FX Pro has slightly smaller lug journals (lug holes), and the spokes of the FX Pro slope a little more aggressively towards the center of the wheel.
    Many people call us asking about our 4Runner Pro "knock-offs" or "replicas." I tend to shy away from these terms, because it implies something negative and/or unoriginal about the FX Pro wheels. We didn't develop the FX Pro t be a replica or knock-off of the OEM wheels just for the sake of doing it. We spent a lot of time working out improvements to the design and functionality of this style of wheel, so that it would benefit Toyota owners and enthusiasts. It is important to me to let customers know this, because I don't like the idea of lumping us together with the "knock off" wheels that you see on EBAY, Amazon, etc. Those wheels have also have improper specs, are made from low quality aluminum, have a poor finish, no warranty, and no brand behind them. FN Wheels FX Pro wheels have the support and reputation of the FN Wheels brand.
    I hope this helps to clarify the differences of the two wheels. In no way am I setting out to bad mouth the OEM wheels, but since I do know all of the work that went into creating the FX Pro as an improved design I am very proud to be able to explain that the differences go beyond color options and price.
    Fast1, crigg93, PreTaco170 and 10 others like this.
  15. Oct 6, 2017 at 12:32 PM
    #1135
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    How is your stock on these and the Konig six shooters? Can't decide - weight is 24 lbs vs 20 lbs roughly correct?
  16. Oct 19, 2017 at 8:54 AM
    #1136
    Larl
    Larl Member
    Chicago-Land
    So why is it so hard to get a quote on 4 black FN FX PRO wheels shipped to Chicago?? I have messaged on IG, Texted, called, PM'd on here twice.....sheesh
  17. Oct 19, 2017 at 9:29 AM
    #1137
    oh crap its him
    Shannon
    OH->SLC,UT->SA,TX
    09 TRD OR
    Dude is super busy so I imagine best form of communication is to call or email direct. It took me awhile to get through but once I did everything was setup pretty quickly. Very happy with the service and these wheels!
    PreTaco170 likes this.
  18. Oct 19, 2017 at 9:37 AM
    #1138
    oh crap its him
    Shannon
    OH->SLC,UT->SA,TX
    09 TRD OR
    So after having these wheels sitting in my garage for a couple of weeks I was finally able to get them installed. I went with Nitto Ridge Grappler in 265/70r17 E load and had them road force balanced on the Hunter. As far as the lift; I have 5100's set at zero, OME 884 coils, Wheelers three leaf add-a-leaf in the rear and LR UCA.
    Disregard the foggy headlamp. Those will be replaced soon lol.
    Previous wheels were 16" TRD FJ's with Cooper ST Maxx in 265/75r16. I have a bit more rubbing with the new wheels but nothing a little trimming won't fix.
  19. Oct 19, 2017 at 9:48 AM
    #1139
    jholc21
    Colorado
    The website states they are out of town - won't be back until Monday 10/23/2017. FYI.
    oh crap its him likes this.
  20. Oct 19, 2017 at 10:37 AM
    #1140
    Larl
    Larl Member
    Chicago-Land
    I emailed thru their site a couple times. Is there another email?
