FN Overlander Wheels spec A and B , show em if you got em
Discussion in 'Wheels & Tires' started by illusivema70, Nov 7, 2016.
  1. Sep 24, 2017 at 8:01 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    @illusivema70 Old post to bump, but any chance you recall the specs on this trucks lift/tire setup?
  2. Oct 6, 2017 at 1:17 PM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    @JdMeF9SiR2
    Can we get a comparison of your Overlander vs OEM 2012-2015 Pro/Baja wheels like you did with the above FN FX Pro? :D And when can we expect to see the Overlanders on your website?
  3. Oct 17, 2017 at 5:53 PM
    illusivema70
    illusivema70 [OP] Well-Known Member
    4xSlow
    Las Vegas
    15 MGM D-cab TRD Offroad 4x4
    Stage 6 Icon Suspension With CDC, Total Chaos upper control arms, All-pro expedition leaf packs, All-Pro extreme-duty APEX sliders, Pelfreybilt front aluminum bumper with full skid set, CBI rear bumper with tire carrier, CBI bed rack and CVT Mt. Shasta tent. 285/75/17 Nitto Trail , Mcneil Racing +2 Fiberglass fenders
    Icon lift kit with 285/70/17 Ridge grapplers
    let me know if you need any other info or a kit.
  4. Oct 17, 2017 at 6:03 PM
    illusivema70
    4xSlow
    Las Vegas
    you have to cal FN wheels, they are not on the web site yet.
  5. Oct 26, 2017 at 12:12 PM
    thewalkingdead
    thewalkingdead Well-Known Member
    Are those oem trd pro wheel center caps? thanks.
  6. Nov 1, 2017 at 7:18 AM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Where'd you get those center caps?
    thewalkingdead likes this.
  7. Nov 2, 2017 at 8:32 PM
    illusivema70
    4xSlow
    Las Vegas
    Import Equipment decals made specifically for the FN caps
  8. Jan 7, 2018 at 1:28 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Saw these on on 80 series. Really like them.
  9. Jan 7, 2018 at 1:34 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  10. May 22, 2018 at 9:04 PM
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    Moar pics of these please, really curious about this elusive 16 incher....
    BassAckwards likes this.
  11. May 25, 2018 at 6:07 PM
    ThomasMore66
    Are there 16’s?
  12. May 28, 2018 at 9:25 PM
    firedawg89
    firedawg89 Member
    torrance
    2019 MGM Taco 4x4 TRD offroad DCSB
    Curious as to what size tires you have on these
  13. Jun 1, 2018 at 9:57 PM
    illusivema70
    4xSlow
    Las Vegas
    265/70/17 , just looked back on the original picture. Customer rig.
  14. Jun 1, 2018 at 10:05 PM
    illusivema70
    4xSlow
    Las Vegas
    I don't believe there is going to be a 16 inch version - I would imagine at that point the TRD wheel would be the choice since they already offer a decent width and offset.
  15. Jun 1, 2018 at 10:22 PM
    #35
    illusivema70
    4xSlow
    Las Vegas
    new finish in case you haven't seen them yet.
  16. Jun 2, 2018 at 7:49 AM
    #36
    Hellapeno
    Austin
    2016 TRDOR
    Choice Goodies
    How’d you get? Contact Dustin? Looks incredible in that color
  17. Jun 4, 2018 at 8:34 PM
    #37
    illusivema70
    4xSlow
    Las Vegas
    yup, just call him up and he can take care of you. I love them!
  18. Jun 13, 2018 at 5:52 AM
    #38
    Straus7
    Straus7 New Member
    If you go with the simulated beadlock I would stick with the ones that are painted. The bolts and bolt holes don't appear to like water sitting in them. I noticed the issue with the bolts a couple of months ago, not sure how soon it started.
  19. Jul 7, 2018 at 11:16 PM
    #39
    illusivema70
    4xSlow
    Las Vegas
    not sure what we are looking at?
    I usually wash and just drive away without drying, I haven't had any issues with water. I noticed you said painted won't have an issue, but I don't see an issue on you wheels. Let's see some action shots of your truck!
    banditcamp, Road Bull and Biscuits like this.
  20. Oct 1, 2018 at 10:13 AM
    #40
    420taco
    420taco Well-Known Member
    Justin
    PA
