Foam Gun
Discussion in 'Detailing' started by jrallan26, Mar 19, 2023.
  1. Mar 19, 2023 at 10:49 AM
    jrallan26
    jrallan26 [OP] Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Just bought my first foam gun. Can I use any car wash soap?
  2. Mar 19, 2023 at 10:53 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
  3. Mar 19, 2023 at 11:11 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I bought my foam gun and the Honey Dew stuff in 2016. I've never tried any other soap with the gun. The gallon of Honey Dew lasts a loooong time. You dilute it with water before filling your gun reservoir. I mix it in a gallon jug and use it from there.
  4. Mar 20, 2023 at 5:59 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Technically you can any car wash soap, but there are many on the maket made for this specific application, and they would work much better. Search You Tube for "best foam cannon soap" and you'll go down a very deep rabbit hole.
  5. Mar 20, 2023 at 2:22 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Like the OP said, anything will work but best to use something designed for it as it'll work better.
    But, a bit of advice in case your situation is like me. I bought a cheap pressure washer (Ryobi) and foam cannon (Chemical Guys). I was hooked, never going back to regular hose/bucket setup. But, the setup was clunky. The hose sucked, even the upgraded one I bought, the foam cannon would constantly tip over, the wand was too long, the fittings suck and didn't swivel.
    After my cheap pressure washer crapped out I splurged and stepped up into the entry/mid level stuff you'll find on Obsessed Garage. HOLY CRAP, what an improvement. This higher end stuff seems like a waste of money until you actually use it. Specifically, the hose, wand, nozzles, correctly sized orifices, higher end fittings...etc. It's a night and day difference in ease of use, much more efficient in terms of your time washing, and higher performance. Before actually using it I just didn't comprehend how these little components would make such a big difference.
    gotoman1969 likes this.
  6. Mar 20, 2023 at 5:59 PM
    tstad9i
    tstad9i Well-Known Member
    2022 Blue Tacoma Off Road
    I had this stuff left over from pre-cannon. Figured I'd throw it in the foam cannon and if it works great, if not I'll get something with 'foam cannon' in it's description. Works perfectly fine, it produces a nice thick foam but not before changing the orifice nozzle to a bit smaller from what came with the cannon.
    The bottle says "shampoo and conditioner". I wonder what it's conditioning, the taco doesn't have hair. Sounds like it's for people.
    Meguiar's Gold Class Car Wash
  7. Mar 20, 2023 at 6:06 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Get a 50ft Flexzilla hose. The standard 25ft hose is worthless.
    Venom and T378 like this.
  8. Mar 25, 2023 at 4:43 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Is the Flexzilla hose known for mold issue?
  9. Mar 25, 2023 at 12:28 PM
    gotoman1969
    I have zero issue with mine.
    Venom[QUOTED] likes this.
  10. Mar 25, 2023 at 1:37 PM
    Venom
    Kevin
    Massachusetts
    Most of the bad reviews are from mold.
  11. Mar 25, 2023 at 4:43 PM
    gotoman1969
    I’d had seen that with their garden hoses. But no issue with my pressure washer one but it also gets hung to dry in the garage.
  12. Mar 26, 2023 at 4:14 AM
    Venom
    Kevin
    Massachusetts
    Thanks for the replies!
  13. Mar 28, 2023 at 4:46 AM
    bboggio28
    bboggio28 Well-Known Member
    2020 TRD Sport
    check out IamJoshV on youtube and dig into his foam cannon reviews and some of the pressure washer reviews too. you will want to check and see if your foam cannon has a 1.1MM orifice and the foam screen. if you aren't using a pressure washer and just a regular garden hose and the foam guns, you wont get the thick foam you will see on the videos. for thicker foam it comes down to GPMs in your pressure washer and the foam cannon itself.
    for soap you will want to look for snow foam styles. the Chemical GUys honeydew is good and i think they have another one called Mr Pink (maybe).
    pinktaco808 likes this.
