Fob not working. SRS & Slip indicator lights on. Trip Meters auto reset. Fuse 23
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kel882, Apr 20, 2025.
  1. Apr 20, 2025 at 11:42 AM
    Kel882
    Kel882 [OP] New Member
    2015 Tacoma
    Was wiring my dash cam into power source in overhead counsel. Got it working but obviously shorted something. Symptoms:
    - SRS and Slip Indicator lights on in tach gauge.
    - Key Fob not unlocking doors.
    - Trip meters resetting themselves with each engine restart.
    Couldn't really ID what fuse or relay may responsible in owners manual but found a thread on a Tundra forum to remove and replace fuse in front of under hood fuse box even if they looked good.
    With engine off used a multimeter to check resistance /ohms for a blown fuse without having to pull every one out and sure enough Fuse #23 was the culprit.
    Replaced the 7.5 amp fuse and all systems restored.
