Fob Programming Mode/Ignition Lock Cylinder issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hummer14, Nov 27, 2019.
  1. Nov 27, 2019 at 6:59 AM
    Hummer14
    Hummer14 [OP] New Member
    2005 Toyota Tacoma 4WD Double Cab
    Hello Tacoma World,
    Just joined today. I'm a military (U.S. Army) retiree living in the US Virgin Islands. I own a 2005 Tacoma Double Cab 4WD. Having issues getting my truck into programming mode to get new fobs working. Found a thread that speaks about unplugging and plugging a box located behind the glove box. Even after following this step, I'm unable to get truck into programming mode.
    My ignition lock cylinder is worn out to the point that I can remove the key while its in the "ON" position and the engine is running. Wondering if this might be the reason it won't go into programming mode. Any thoughts? Suggestions?
  2. Nov 27, 2019 at 8:04 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Go to the dealer and get the key code from them. Bring the registration with you as they want proof of ownership. Bring this key code and the ignition cylinder removed from the truck and they can rebuild it to the same key. That cost me under $50. Get a cheap normal key without the chip as well.
    Now you can get new keys cut from that. Here, we can go to most hardware stores and they can clone your existing key's chip.
    I did this while on vacation. No locksmith would come out in this downpour as I'm stuck in a strip mall parking lot. You tube to the rescue for removing the cylinder. Then used a screwdriver for a few days to turn the truck on. Place the handle of the key near the ring where key would go normally, then turn the screwdriver. A couple days later, I got the cylinder back and it was like new. I ended up getting new keys when I got home. Between Amazon, a friendly hardware store and a locksmith, I got 3 new keys programmed to the truck for about about $100. when I got home.
    And, thank you for your service...
  3. Nov 27, 2019 at 8:09 AM
    Hummer14
    Great advice Larzzzz, however, I don't have these options in the Virgin Islands.
  4. Nov 27, 2019 at 8:22 AM
    Muddinfun
    Muddinfun Well-Known Member
