Focal 165 v30
Discussion in 'Audio & Video' started by tractng, Dec 3, 2012.
  1. Dec 3, 2012 at 2:03 PM
    tractng
    tractng [OP] Well-Known Member
    For anybody that has them on the taco, what spacer size is needed for the fronts?
    Also, do I need a spacer for the tweeter? Thanks in advance.
  2. Dec 3, 2012 at 8:47 PM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Eibach Springs with Billstien 5100's - Full Katzkin Leather - Back Flip Roll-X bed cover - Custom Projector/Dual Halo Headlights by ambiguous - Eagle Eye LED tail lights - LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Rear AAL TSB - 4 Tie Down Mod - Pop N Lock - Running Boards - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    I have a set of the KRX Components, I used a 1" thick baffle. I made my own tweeter mounts based off the stockers.
  3. Dec 3, 2012 at 9:12 PM
    tractng
    I am guessing just grab a generic one and modify according to the holes, etc.
  4. Dec 4, 2012 at 7:24 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    it was roughly an inch but i dont recall, it was more for fastening purposes than anything else. i did not get photos
    nice selection you picked.
  5. Dec 4, 2012 at 9:26 AM
    tractng
    Thanks man. I have all the tools required to make the circle.
    I might do something different this time as I was sitting at a dinning table last night and found an idea :D. I might use the wife's large size coasters.
    Easily cut down to shape and paint them.
  6. Dec 4, 2012 at 4:27 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    +1 on the painting... do something to seal the wood up well. Over time they are subject to moisture and MDF can break down if you're using it.
  7. Dec 5, 2012 at 6:39 AM
    Canes58
    Canes58 Well-Known Member
    Pensacola
    09 RC 4x 5spd
    magnaflow - k&n - fact alum wheels - back up mirror - intermit wipers - JVC 800 w/focal 165's - oem fogs - 5100's fr & rear.
    Don't think you need a spacer for tweets.
