Fog and Headlight LED's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnny2525, Nov 18, 2015.
  1. Nov 18, 2015 at 7:32 AM
    Johnny2525
    Johnny2525 [OP] Well-Known Member
    California
    '14 TRD OFF ROAD DCSB
    ICON stage 3 suspension kit, Amp Research retractable steps, LED interior lighting, headlights, fog lights, MB wheels, FlowMaster exhaust. Rigid Industries back up lights, aFe Cold Air Intake with URD MAF sensor Calibrator
    2014 DCSB. I want to change out my fog's and headlights to LED's. Anything I should know? and where can I find them?
  2. Nov 18, 2015 at 7:53 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    LED headlights aren't quite what they need to be yet. You'd be better off with a better quality bulb setup for the timw being. Eventually aftermarket LEDs will be good enough. There's a few threads on the forum.
  3. Nov 18, 2015 at 8:33 AM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    from the research i have done and the people i have talked to, look into some H4 ETI LED 2S Bulbs. These are designed for headlights, and from what i have seen have great output. You would be better doing them in projector housing but they will work in regular housings and give great output. Also there is a guy on here that made a DIY for a reflector bucket out of copper pipe that fits on the end of the bulb that gets rid of all the glare that most people complain about of brighter bulbs in stock housings. I plan on doing them myself soon when money allows
  4. Nov 18, 2015 at 8:40 AM
    moondeath
    Pa, Gardners
    A lot of the big issues with LEDs is life expectancy and high beams being almost non existent. The lows are bright, but that's about where it ends.
  5. Nov 18, 2015 at 9:02 AM
    Johnny2525
    California
    Honestly....The real problem is not brightness. It's that I installed a lightbar. The Led's are a bright white and it makes the fogs and headlights look all yellow and stupid.
  6. Nov 18, 2015 at 9:05 AM
    metrick1215
    Habersham GA..
    lightbars arent street legal, so if your looking for just a look, buy cheap ones off ebay
  7. Nov 18, 2015 at 9:24 AM
    Johnny2525
    California
    I know, but mine is behind the lower grille and pointed sort of down. AND like most Tacoma owners...I'm just a tiny bit OCD about my truck. I just want everything to look good and the OEM lights look bad when lit up next to the bar.
  8. Nov 18, 2015 at 1:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If your goal is just to match the color, you can buy halogens in a matching 5k kelvin range for far cheaper. This was just the first hit by google:
    http://www.amazon.com/Philips-Diamond-Vision-Halogen-Bulbs/dp/B007K6E2TM
    Coated bulbs are not great as they filter out light spectrum, but it will give you the color you want. If you want more light, you can do this instead, but it is a pure performance based upgrade, not for cool looking bulb colors:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-not-led-or-hid.398066/
  9. Nov 19, 2015 at 6:55 AM
    Johnny2525
    California
    I followed the link to Amazon for the halogens. That's probably the way I'd go. Doesn't say they will fit my truck though? Not really looking for cool looking bulbs, just white.
  10. Nov 19, 2015 at 9:35 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The trucks technically take 9003 headlights. The 9003 and H4 bulbs are interchangeable. It short it is an American (9003) vs European (H4) bulb labeling thing. I'm running H4s, I can guarantee you H4s will work in your truck.
  11. Nov 19, 2015 at 1:48 PM
    Johnny2525
    California
    That's awesome. Thank you! Maybe you can help me out just one more time?? Same bulb but for the fogs?
  12. Nov 19, 2015 at 2:40 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes, it looks like the same bulbs are available in H11 (2012+ fog light bulb).
  13. Nov 19, 2015 at 3:08 PM
    Johnny2525
    California
    Great! Thanks man! Really appreciate you help...
    crashnburn80 likes this.
  14. Nov 19, 2015 at 3:13 PM
    Johnny2525
    California
    BAM! Just ordered them...
